Projects SURVIVOR;Working on my hotrod 28A from 1959,rebuild
Discussion in 'The Hokey Ass Message Board' started by dana barlow, Apr 11, 2013.
  1. dana barlow
    dana barlow
    from Miami Fla.
    The photos were taken by Mark Kline,he was parked one car over with his 32 red roadster,we often try to make the runs to an from shows together,some times we have as many as 8 hotrods in a line running down the highway an is more fun then the shows. Here is another one of his shots of the same red,white an blue pretty gal,testing out Mark's rod. Its better then a 3D photo
    loudbang and 26 T Ford RPU like this.
  2. 26 T Ford RPU
    26 T Ford RPU
    You keep posting car show pics.............but I cant see any cars !!!!!!!:cool::rolleyes:;):D JW
    dana barlow likes this.
  3. loudbang
    And that is a good thing ;)
    26 T Ford RPU and dana barlow like this.
  4. dana barlow
    dana barlow
    from Miami Fla.
    Added a PCV to my old Y-v8,did it so I can move it around a little when I add the 4x2 log set up an run the tube to center cross overs of log. For now it's hook up to the 4bbl intake and seems to work . The old road draft tube just got cut and angled to fit the PCV. Should keep any oil leaks away.
  5. 26 T Ford RPU
    26 T Ford RPU
    Dana, that will need to go to the carb base, as is will make those two cylinders run lean. JW
  6. dana barlow
    dana barlow
    from Miami Fla.
    This PCV is temp tell I put the new 4x2 log on ,and then PCV hose will go to center cross over balance tube between logs,that will even out draw. But even now in 4bbl intake dose not show any lean on the back plugs,my guess is oil vaper makes up any def in mix. But I'm watching it,I don't have a plate for base of 4bbl carb with a hookup an nether dose carb so did it this way for now.Thanks
    26 T Ford RPU likes this.
  7. dana barlow
    dana barlow
    from Miami Fla.
    We got to have some fun running on the super speedway "Miami Homestead",not allwoud to get closer then two car langths to other cars,we just droped backed an closed up again,run just over 100+ in the gap,lead pacecar was running about 50 11885328_10204735211167872_550245759537478017_n.jpg
  8. Dick Stevens
    Dick Stevens
    Wow that would give a guy a rush, much better than they get out of drugs! :cool::cool::cool::cool::cool:
  9. gnichols
    gnichols
    from Tampa, FL
    Pretty cool Dana. What was the event? I bet no one knows you were a stock car racer, either! Gary
  10. 26 T Ford RPU
    26 T Ford RPU
    Real cool Dana, im jealous much :rolleyes::cool::cool::cool::cool: JW
  11. loudbang
    Top down, wind in the hair, at a real race track. doesn't get much better than that.
    kidcampbell71 and dana barlow like this.
  12. dana barlow
    dana barlow
    from Miami Fla.
    kidcampbell71 likes this.
  13. dana barlow
    dana barlow
    from Miami Fla.
    I got back to playing with my home made 4x2 intake. Finished up welding it ,after finely filling my tanks again. So time to test for leaks,made up some block offs from hose an plywood to seal up each part. Add some air psi from tire fill valve stuck in the hose. Then I sprayed them with soapy water an looked for bubbles,sure enough had some leaks to foam up. Marked them with a ***** punch an rewelded,an reground welds to look kind of OK. Had to repet that 3 times before I got no bubbles anymore. So next is to take the two parts over to a buddys that has a two foot+ long beltsander and just make gasket places flat. Leaks at were the plywood seal was didn't matter,just payed no mind to those. 006.JPG 008.JPG 005 (1).JPG
  14. AndersF
    AndersF
    That intake gonna look great on your hotrod when its finnished.
    dana barlow and 26 T Ford RPU like this.
  15. 26 T Ford RPU
    26 T Ford RPU
    That it will. Looking forward to some color and a test drive report. Very cool Dana.:cool::D JW
  16. dana barlow
    dana barlow
    from Miami Fla.
    For those don't want to hunt,the DIY homemade 4x2 intake info starts back at post# 253,,page #9
    HOTRODPRIMER likes this.
  17. HOTRODPRIMER
    HOTRODPRIMER
    What's the problem with that? :D HRP
  18. 26 T Ford RPU
    26 T Ford RPU
    Nothing Danny, nothing at all. :rolleyes::D JW
  19. loudbang
    This is going to be great and all made by your own hands to boot.
  20. dana barlow
    dana barlow
    from Miami Fla.
    I finely replaced my lost CCP,thanks to O'Brien Truckers. Looks good back in place. 015.JPG
  21. dana barlow
    dana barlow
    from Miami Fla.
    For homemade 4x2 intake fun. Got things cleaned up an logs blasted, beltsanded ,plus painted.
    So did ***m. on old motor on enginestand,so it will be EZer to hook up when I change it to my hotrod,here's how its looking now as a completed set up with all the right bolts,clamp,springs I hope. This should mean I will not have to be running around to find stuff when getting in on the car,an cut back on my old back bending over so much. Did some extra details,polished all the clamps and screws,got some Stainless allins and cut the nerling off n added two groves for fun on the intake hold to head bolts,polished acorns hold carbs. 013.JPG 011.JPG 015.JPG
  22. T-DeWitt
    T-DeWitt
    Dana.... looks super *****in.
  23. Dick Stevens
    Dick Stevens
    Looks damn good, Dana! :cool:
  24. dana barlow
    dana barlow
    from Miami Fla.
    Thanks,
    After I get these 4x2's on my hotrod,I'm hoping that the custom aircleaner base's I handmade to hold those pots about 1 in. lower then normal on the carbs will show up as looking kind of cool low, vs sticking up more in to line of site.
  25. pitman
    pitman
    A Suthern Logger! Looks great Dana.
  26. 26 T Ford RPU
    26 T Ford RPU
    Dana, job well done............now lets see how it runs, too cool.:cool::cool: JW
  27. loudbang
    Wow you even spent the time to "color coordinate" the fuel hose and bowl plug gaskets.... that is dedication. :p
  28. dana barlow
    dana barlow
    from Miami Fla.
    12038585_10153591931359845_342475333379636812_o.jpg Went back to my old highschool for some reunion time,had parked my hotrod there last in 1963,but now there is a new cl***room wing built on top of my parking spot. So had to park about 100ft. south of my old spot on were a road ran along the front of school and is now parking lot. Drove down the sidewalk too,as there is no road to run a long front of school now,still punk kid in me! 11029478_10153591934519845_4599624406993595888_o.jpg 12039392_10208078743595519_9015919922919669074_n.jpg
  29. This has been a really good thread Dana, sure have enjoyed watching, good job.
  30. 26 T Ford RPU
    26 T Ford RPU
    That's a cool bunch of pics and to go back with the same Hot Rod 54 years later is the coolest.:cool::D JW
    AndersF and dana barlow like this.
