Technical 1946-48 Fords: How did you lower yours?
Discussion in 'The Hokey Ass Message Board' started by RoadFarmer, Nov 1, 2015.
  1. I'd like to see pics of people's cars and hear how they lowered theirs. I've looked at a lot of pictures and have seen some nice stances. Does me no good without knowing how it was done.
    Anyone used the Posies In-Da-Dirt kit?
  2. donno
    donno
    Stock suspension= Shackles. Not stock= blocks and cut coils.
  3. Don's Hot Rods
    Don's Hot Rods
    from florida
    I've got the rear of mine figured out, I have Ch***is Engineering parallel leafs to install and will use blocks to get the stance I want. For the front, I am going to use the stock Ford undropped axle, if I can, and maybe the 3 inch dropped Speedway front crossmember. If that doesn't pan out, I will probably go to a 3 inch dropped axle. In either case, I will probably use a Posies reversed eye spring up front for an inch more.
    Don
  4. craig.maverick
    craig.maverick
    from Australia
    Jag front end, lowered coils & blocks..
  5. hdman6465
    hdman6465
    Old-Soul and Atwater Mike like this.
  6. Don's Hot Rods
    Don's Hot Rods
    from florida
    You got that much drop from a reversed eye only ?
    Don
  7. When I built my coupe back in the 70s, I used a 70 Mustang rear and leaf springs, I notched the frame so the front spring eyes mounted up inside it, used the Mustang shackles and bushings in the rear.
    I modified the front crossmember to raise the stock spring and axle up into it. I just flattened it out some, it has a lot of drop in the stock form. I built a 4 bar setup to use in place of the stock wish bone
    I used a Vega steering box mounted in the stock location and stock 46 drag links and tie rods, had to reverse the taper in the Vega pitman arm for the drag link
  8. RICH B
    RICH B
    Used a stock axle, Posies low spring and a dropped crossmember from 40 Fort in the front; had to C notch the frame for axle and spring clearance and modify the wishbones. Still have to find out how this front will work; maybe need a higher arch spring. Rear is a CE parallel leaf set-up with lowering blocks.
  9. millersgarage
    millersgarage
    I used Ch***is Engineering front and rear on my 47. Their Pinto front, and parallel rear leaf. Ride great, and sits nice
  10. Do you guys that responded without pics have anything you can post?
  11. rusty rocket
    rusty rocket
    Hmmmm! no coils to cut on a 46-48 ford.
    Silverfox Racing and RoadFarmer like this.
  12. rusty rocket
    rusty rocket
    I dont have picyures but I used a ch***is engineering rear leaf with blocks and up front I used a dropped crossmember and old 2"dropped axle.
  13. rusty rocket
    rusty rocket
    You are not going to like the way it sits with a stock front axle and just the dropped crossmember. Way to high for my liking on my old coupe.
  14. phat rat
    phat rat
    Well I'm running a Nova sub in front with CE low ride rear springs plus lowering blocks
  15. Jalopy Joker
    Jalopy Joker
    no pics, again - had a '47 coupe with front reversed eye, de-arched with two leafs removed from stack - used Tokico (really good shocks) shocks designed for use on early 60's Corvette rearend - used panhard bar and disc brake conversion. remember, unless running narrowed frontend, how low you go depends on having clearance for full turning of tires. out back switched to Ch***is Engineering 2" lowered leaf springs with 8" Ford.
  16. Tjames
    Tjames
    My ,41 c-Dan has 4 inch drop beam a d 2 inch drop spring from posie for the front . Rear is leaf springs with 3 inch blocks. 1446437967125.jpg
  17. fordor41
    fordor41
    Stock front spring with every other leaf removed and '40 main with reversed eyes, otherwise front is stock. C.I. rear springs with middle leaf removed
  18. Don's Hot Rods
    Don's Hot Rods
    from florida
    I've wondered about that, but I figured either a 3 inch dropped crossmember or a 3 inch dropped axle were still the same drop. How was it different ?
    Don
  19. millersgarage
    millersgarage
    oops, sorry man.
    RoadFarmer and TheFett like this.
  20. millersgarage
    millersgarage
    action shot...
    41FordSuperDeluxe likes this.
  21. rusty rocket
    rusty rocket
    To me 3 inches just isnt enough. But then again I like all my stuff to low.
  22. slammed
    slammed
    Turn the ft tire all the way to lock, take pix of the axle/leaf.
  23. silent rick
    silent rick
    mine is channelled
  24. Chris
    Chris
    Dropped stock axle, reverse eye spring long shackles front and back
  25. MII front with 2" dropped spindles,325# springs
    Rear is Posies parallel leafs-no blocks
    frt tire is 25.5 inches tall-rears are 29 inches tall
    SERPENT likes this.
  26. Thanks for all the responses. You guys have some *****in cars.
    I should hopefully get a '47 Sedan in the next couple weeks.
  27. Steves46
    Steves46
    from Florida
    20150930_190603.jpg Stock suspension. Front: Posies reverse eye spring; Rear: lowering shackles.
  28. FrozenMerc
    FrozenMerc
    My buddy's '48 sticking it's nose out of my shop. It was dropped the old fashioned way. Drop axle and Posies spring.
    Kelly Burns likes this.
  29. Atwater Mike
    Atwater Mike
    @Steves46: Where did you find those perfect flare skirts? Are they available?
    Steel or 'gl***? Thanks...
  30. Steves46
    Steves46
    from Florida
    Hello Mike. They are galvanized steel and I got them from Agape Auto Part. Their website is www.agapeautoparts.com. Very nice folks to deal with. Steve
