Projects 1934 Ford Sedan Gender Reassignment Surgery
Discussion in 'Traditional Hot Rods' started by flatnasty, Jan 14, 2014.
  1. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    Read this whole thread start to finish including all YT Vids, One Word = PHENOMENAL!!!!!!!!!!
    What a talent all the way around!!!!!!!!
  2. Hey Brad,
    Are you the barefoot metal fabricator?:eek:
    Great job on that grill!:D
    brady1929 likes this.
  3. flatnasty
    flatnasty
    from Vancouver
    Picked up the car from blasting today. Turned out really well. nothing got warped or messed up and it looks so much better just being one colour. 20150923_154504.jpg
    kiwijeff, Pufff, K.L and 11 others like this.
  4. hotrodderhaag
    hotrodderhaag
    that looks amazing
  5. pumpman
    pumpman
    Keep it going man! Looks great.
  6. She's beautiful!
    Wire wheel her to get out any media that's embedded and make sure you use a good 2 component Epoxy primer!
    I once went with cheap stuff after blasting a car and it fell off in big sheets!
    I had to blast it again and redo all the body work, I was devastated!
    Joe
    wedjim likes this.
  7. Outback
    Outback
    from NE Vic, Oz
    Thats not where you user name comes from is it? ;):confused:
    Coupe is lookin great!
  8. flatnasty
    flatnasty
    from Vancouver
    I've decided to go with split bones for the car. so this weekend I got to work on them. I bought a old chrome set of model A bones a while ago off a fellow hamber so I'm going to put them to use. They had some real ****ty tie rod sleaves welded into them so I cut them off. I bought a set of bungs from Ctaulbert here on the hamb and I must say they are very nice and was real happy. I polished them up on the lathe and welded them in and polished the weld. turned out mint didn't burn the chrome at all. After that I made some brackets for the bottom of the frame for them to bolt to with a tapered bung that I made on the lathe at work.
    Brad
  9. pumpman
    pumpman
    Man. that did turn out nice. How are you going to mount your brackets?
  10. 383deuce
    383deuce
    I really like the bones you got.
  11. flatnasty
    flatnasty
    from Vancouver
    20151018_154625.jpg 20151018_134731.jpg 20150925_184131.jpg Got some more work done on the old terd.
    I have been collecting all the front end parts for this car for some time. The stuff I had in it at the beginning of the post was just for mock up. Piece by pain staking Piece I have collected everything for the front end in old chrome. It was a chore. Since getting things chromed was not in my budget and not the look I wanted finding parts that have been chromed and that show their age was the best solution.
    The first thing I did was reverse the eyes on the old chrome spring I got. for that I used the press. some guys build a fancy jig for this but I just press mine into the opening in the press it's ast easy and free.
    after that I mocked it all uposts
    ralphson, kiwijeff, Pufff and 6 others like this.
  12. Old chrome is awesome, It's looking great!
  13. joee
    joee
    hell of a job.....shows a lot of talent and hard work
    Aaron J likes this.
  14. Runnin shine
    Runnin shine
    Yep
  15. flatnasty
    flatnasty
    from Vancouver
    thanks fellas it was a lot of work collecting the stuff piece by piece but I think it will be worth it in the end.
  16. Mart
    Mart
    I bought a press like that recently. I hadn't thought of re-arching springs.... Hmmmm. Thanks for showing the pic. Like the old chrome.
    Mart.
  17. Bad ***. the wishbones ends you bought, did they come with those red ends or did you have those already.
  18. Man, you are building a bad *** hotrod for sure!!!
  19. flatnasty
    flatnasty
    from Vancouver
    Hot rod ron
  20. flatnasty
    flatnasty
    from Vancouver
    Got the motor back in the car this weekend and got going on the exhaust. I bought this cool old set of headers at a swap meet last year so I'm going to put them to use. Somewhere along the way some bone head decided to do the old bash the tube in thing so I started by fixing that. 2015-11-08 16.07.59.jpg 2015-11-08 15.58.37.jpg Im going to use a 36 drive shaft cut in half for the rest of my pipes. Not very original I know but I've always liked it. 2015-11-08 15.59.18.jpg 2015-11-08 16.00.03.jpg 2015-11-08 16.02.15.jpg All I had to do was put in a flange make a couple hangers and get them lined up. pretty simple **** all in all. 2015-11-08 16.02.44.jpg 2015-11-08 16.01.23.jpg
    kiwijeff, Pufff, skatermann and 3 others like this.
  21. rcnut223
    rcnut223
    from wisconsin
    Nice, really like your work!
    Could you explain how you corrected the bashed in header pipe?
    jerseyboy likes this.
  22. wheeldog57
    wheeldog57
    Just found this thread, had go thru the whole thing! Great vision and workmanship, whole project looks very cool. Thanx for posting detailed photos-you are doing a great service for all of us "hacks". Thanx, Ron
  23. flatnasty
    flatnasty
    from Vancouver
    rcnut223
    to fix the beat up tube on the header I just cut out the damage and welded a patch in from another pice of exhaust pipe. took like half an hour it was pretty strait forward.
    thanks Brad
    rcnut223 likes this.
  24. 383deuce
    383deuce
    NICE WORK.....
  25. praffin
    praffin
    from Australia
    Geez this is nice work. I've been thinking about doing something like this for a while, so its good to see someone has actually gone ahead and done it, and such a nice job as well.
  26. flatnasty
    flatnasty
    from Vancouver
    Got to work on the rear shocks this weekend. I am going to make a compromise on this car and use tube shocks on the rear. This is not something I wanted to do but lever shocks are so expensive and such a pain in the *** I decided to cheat on this one.
    For the top shock mounts I used an old headlight bar mounting pad and welded a thick wall tube to it with a threaded insert in the middle. the lower mounts are just a bolt on unit I got here on the hamb.
    all in all turned out pretty good.
    Brad
    kiwijeff, rcnut223, wedjim and 2 others like this.
  27. flatnasty
    flatnasty
    from Vancouver
    This weekend I worked on the hot rod quite a bit.
    Like the front end I'm trying to do the rear end in all old chrome. The only problem I'm having with that is I can't find a old chrome torque tube. So I had to fake one.
    I have 15hrs into sanding and polishing this one lol. From 60 grit to 1200 grit.
    After that I preped my axle bells by changing the spring bushings and bearing races and seals.
    Glad that is over with lol 2015-11-29 22.40.47.jpg 2015-11-29 22.41.18.jpg 2015-11-29 22.41.41.jpg
  28. Damn! Nice work man, looks bad***!!
  29. bengeltiger
    bengeltiger
