Projects Finally got an A
Discussion in 'Traditional Hot Rods' started by Malibob, Sep 21, 2014.
  1. Malibob
    Malibob
    from Pittsburgh
    Hotrodmyk likes this.
  2. Malibob
    Malibob
    from Pittsburgh
    Been doing a lot of fine tuning and it seems that everything I do only makes this more fun to drive.
    I moved the spacers out front to give me a little more travel, straightened and adjusted location of the gas pedal- which made a world of difference in drivability, did a DIY alignment and added a smaller wheel- that got rid of the death wobble (thank God) and next is getting the back end up a shade to get a little travel out back (may need a little more out front too- again).
    Ben told me that the F1 steering gears had a tight spot built into them so when I aligned it I tried to get that centered right and think it worked. That and tow in seemed to help me get drivable at higher speeds.
    I got a '35 truck shifter that I need to drill, tap and bend a bit and new floors cut- so when that's all done the inside should be pretty well wrapped up.
    Jade likes this.
  3.
  4. Malibob
    Malibob
    from Pittsburgh
    CNC cut floors are certainly not traditional but it sure was easy. ImageUploadedByH.A.M.B.1433471040.445224.jpg
    Saws all was just in case things didn't go well.
  5. cool, looks great.
  6. Malibob
    Malibob
    from Pittsburgh
  7. Jade
    Jade
    That's the most amazing thing i've seen in quite a while! LOL
    To the OP... Beautiful ride!!
  8. travj31
    travj31
    from Western PA
    Bob... love how the Model A has turned out. Looks awesome
  9. Malibob
    Malibob
    from Pittsburgh
    Thanks man. Me too
  10. Malibob
    Malibob
    from Pittsburgh
    Put a temp gauge on today and a double bend shifter with a knob I made.
    And took the hood sides off. Seems to run cooler. And I think looks it too.
  11. cool.... great start. HP is right, that's the way to start, with a complete running car.
  12. 1931fordtruck
    1931fordtruck
  13. michaelmoore
    michaelmoore
    1. great progress on a fine car . I hope to be there one day!
  14. Malibob
    Malibob
    from Pittsburgh
  15. Malibob
    Malibob
    from Pittsburgh
    Hey guys. Little update... Been messing with a few things, most significantly was putting larger rear tires on. This pretty much eliminated the death wobble I was experiencing by essentially adjusting the caster angle. I have also bought some new speed parts. One of which was an Aeroquad which I am super anxious to find a manifold for and get rebuilt.
    Most noticeable change was the 18" 1932 Ford wheels which I have been working on for a while now. Well finally got them and back from powder coated and tires mounted (that was an effort all on its own). Anyways, mounted them up recently and here are some photos.
  16. waxhead
    waxhead
    from West Oz
    Love the stance, looking good.
  17. 2doorwagon
    2doorwagon
  18. Malibob
    Malibob
    from Pittsburgh
    Few Updates:
    I got my 18" 1932 Ford wire wheels on with 4.50's and 6.50's from Coker.
    Got those stupid sealed beams out of the headlight buckets and added a dropped headlight bar. WHAT A DIFFERENCE.
    We had a beautiful Sunday here so took the boys for a ride through the local park. They were ear to ear in the rumble seat. Here are some pictures I took afterwards.
    [​IMG]DSC_6263 by Bob G, on Flickr
    [​IMG]DSC_6253 by Bob G, on Flickr
    [​IMG]DSC_6261 by Bob G, on Flickr
    Muttley, Jet96, mike bowling and 3 others like this.
  19. Blues4U
    Blues4U
    from So Cal
    Just saw this thread for the first time and went thru it all, it was a thoroughly enjoyable read. Beautiful car! I've been thinking of doing taking the same approach on my next project, and have been watching the auctions for 5 window A coupes. I need to finish the closed cab truck I have now first though.
  20. Stan Back
    Stan Back
    Get rid of those ugly Step Plates. They draw your eyes to them like an ugly wart.
  21. mike bowling
    mike bowling
    Great car- nice to see one NOT CHOPPED and with full fenders- SWEET!
    Fitnessguy and RoddyB34 like this.
  22. Malibob
    Malibob
    from Pittsburgh
    Holy shit. I never even thought about that. You are 100% right.
    hotrodderhaag likes this.
  23. Malibob
    Malibob
    from Pittsburgh
    Thanks man.
  24. Malibob
    Malibob
    from Pittsburgh
    Anyone know where to go for a 10 spline highway gear for a '36 rear? I see 3:25's for 6 spline and would rather not get a new open drive adapter and risk having to get a new driveshaft as well. Figured someone made a 10 spline set but haven't found yet.
    Any help appreciated.
  25. Muttley
    Muttley
  26. 51box
    51box
    from MA
    That's a gentlemans hot rod right there, good job man. Stance is beyond perfect.
  27. hotrodderhaag
    hotrodderhaag
    Just a thought , but I made those axle brackets /ladder bars so you could put a 9 inch in there if you ever wanted to. You will get into big $$ putting highway gears in a 36 rear. Bearings and races are stupid money. I built my winters out of a 36 rear. Very pricey. Get yourself a Lincoln versai 9 inch rear (correct width) , and put any gear you want in.
    Sent from my SM-S920L using H.A.M.B. mobile app
  28. Malibob
    Malibob
    from Pittsburgh
    How much is expensive? I really want to keep the older style rear end in there. Not loving the idea of switching to modern rear.
    What about swapping to another early ford rear with a more readily available 6 spline set of gears? Any other reasonable options?
  29. Hot Rod 50
    Hot Rod 50
    What tranny do you have? I've been told a 46 ford pickup rear end has the look and the strength but is open drive, gears, again will be limited. Being a full fendered car I'd do a 9 inch. Pretty classic look and limitless gearing choices.
  30. Malibob
    Malibob
    from Pittsburgh
    T5. Don't know why I am opposed to swapping, guess I like the look of the old rear. I will have to open my mind a little more to the idea.
