Hot Rods Opinion Piece
Discussion in 'The Hokey Ass Message Board' started by Ryan, Nov 3, 2015.
  1. Petejoe
    Petejoe
    from Zoar, Ohio
    Steelies with the period small ford caps on that thing.
  2. Nailhead Jason
    Nailhead Jason
    Totally Option 3!!
    Paint the wheels to match whatever the interior is, be it black, red, camo.....ok not camo but you get the idea. Chrome lugs, trim rings and spider caps would be killer. But if you really want caps 52 ford hub caps fit those wheels perfect and look way better than the poverty caps. Hell I'll send ya some if you want to run those. I have like 5 sets, I may have a hubcap/wheel problem.....
  3. Atwater Mike
    Atwater Mike
    Familiar look, the 'mismatched' Tork Thrusts on rear only...but the scenario was Fremont Drags in the mid '60s. Street rear wheels & tires (and spare, jack, etc.) were in a pile, in the pits.
    Popular class was "HPU", ('hot pick up') so any pickup with engine mods could run.
    It only took ONE time coming out of the gate with street tires on a light-in-the-ass truck, so damn near all had Mags or wide steels with slicks!
    When done racing, most put their street wheels/tires back on.
    CHP was very active writing tickets for slicks on the way home...(Nimitz Freeway) Got 3 or 4 myself...
    volvobrynk likes this.
  4. chessterd5
    chessterd5
    from u.s.a.
    This seems like a lot of trouble for a " beater, work truck, daily driver, that I don't care about."
    I'll be in the garage.
    Dean Lowe likes this.
  5. SLAMIT
    SLAMIT
    steelies and caps painted a dark maroon... its a work truck. otherwise lower it a bit and go et's all around and dont get to silly on tire sizes.
  6. Gotgas
    Gotgas
    from DFW USA
    I'd go Option 3. Since this is a beater, do the wheels in a dark gray color. They're easy to keep clean, and black wheels tend to make un-clean tires look brown. I'd probably run trim rings but I'm fancy like that. I think the tire height and "stance" are really good as it is.
    IMO '57 Ford caps would look better.
    You did ask for opinions. :D
  7. olskoolrodder
    olskoolrodder
    I have a set of old steel chrome slots that would work... full set of (4) 15x8's different offsets 5x5.5bp
  8. steel rebel
    steel rebel
    My question is if you were trying to save $ why was your first instinct was to call Coker for rims. My first thought would be to go to the local auto wrecking yard and find a set of 15" Ford truck rims for the cheap. Punch ( reverse) two, put them on the back with your 31X whatever (which by the way are a good size for the back of a full size truck) get some matching tires a couple of sizes smaller for the fronts and as Atwater Mike above said paint them a color you like and put the stock small caps on.
    But that is just how an old guy that was raised in the '50s broke thinks.
    Gary
    Atwater Mike and volvobrynk like this.
  9. Ryan
    Ryan
    ADMINISTRATOR
    Cuz I'm an alliance member and I can buy a pair of coker wheels for cheap... And when was the last time you saw a pair of 5 on 5.5" wheels at a junk yard? Our yards here don't have em... And if they do, it's a good chance they are bent and won't balance and... screw all that... I'd rather spend $150 or so on some new wheels.
    Really, I'd much rather just find some vintage E-T wheels in 15x7 or 6 in the right bolt pattern and be done!
  10. Ryan
    Ryan
    ADMINISTRATOR
    Those are rad... But I'm not a chrome guy.
    olskoolrodder likes this.
  11. slowmotion
    slowmotion
    I knew you knew all along. This is the right answer, keep looking man.
    philly the greek and Saxman like this.
  12. leadfootloon
    leadfootloon
    I like #3 but I would paint the rims black. No matter what it's a good looking truck.
  13. VonMoldy
    VonMoldy
    from UTARRGH!
    something tells me this isn't just a tool as you said. You took the time to think about what wheels and make a post asking for opinions. BTW that is no beater! Its beautiful!
  14. joeyesmen
    joeyesmen
    You could paint the fronts a matte warm gray to match the rear spokes and that would look less mismatched. But then you lose the surfer thing. I think I vote for Option 1 because it looks like the truck has a story.
  15. VonMoldy
    VonMoldy
    from UTARRGH!
  16. volvobrynk
    volvobrynk
    from Denmark
    So paint them red
  17. Nailhead Jason
    Nailhead Jason
    Ok that looks bad ass!
  18. both sets of wheels - steelies for work & the mags for when you're feeling fancy - I've always had at least two or more sets of wheels for my cars
  19. slowmotion
    slowmotion
    THAT^^^^^ ain't a bad idea in the mean time until some 5-spokes show up.
    kidcampbell71 likes this.
  20. Sancho
    Sancho
    ^ Like joeyesmen suggested with trim rings on the front would look even less mismatched.
  21. vint
    vint
    I've got steelies with stock caps on my '65 F-100 and it looks perfect. I don't think custom wheels add much to these trucks.
    steel rebel and Atwater Mike like this.
  22. Nailhead Jason
    Nailhead Jason
    Just like that with a board bolted to the front bumper and trailer hitch on the back so it looks like an old drag push truck. I really dig this way, and I voted for all steelies!
  23. flatford8
    flatford8
    from Lyman,ME.
    Yup this one. Same size tires, level stance...MARK
  24. Krash
    Krash
    from Cleveland
    Option 3 all the way! Let some air out of the front tires though dude.
  25. cheepsk8
    cheepsk8
    from west ky
    I sorta like option 1 or 2, the spokes look good on the back. Hard to decide on the poverty cap but you could swap up every so often.
  26. steel rebel
    steel rebel
    Sorry Ryan different generations different thought patterns. I'll bet Atwater Mike has a stack of wheels like this. I know Petaluma Mike has a shed full of them and I bet it you ask Keith, Vern had a bunch of stacks of them. Your way is probably better and less hassle but It's the only way some of us know to do it.
    Gary
  27. MAD 034
    MAD 034
    from Washington
  28. low budget
    low budget
    from Central Ky
    All 5 spokes or all steelies with the caps, or put the 15 inch 5 spokes on the front and steelies with no caps and the bigger tires on the back until you could find 2 more 5 spokes
  29. steel rebel
    steel rebel
    No there is four there the bottom one still has a tire on it.
  30. ZZLEGEND
    ZZLEGEND
    As we use to say back in the 60's and 70's,,,,,,,,,,,,,,,,,,,,,"Sanitary". Option 3
    50Fraud likes this.
