Features Corvette Gassers
Discussion in 'Traditional Hot Rods' started by bigalturk1, Mar 23, 2011.
  1. MikeC62
    MikeC62
    from Missouri
    Here is a pretty common combo in 1957, 58, 59, 60
    245 HP. Carter WCFB front. Mfg. #2626S Chev. #3744002
    rear. Mfg. #2627S Chev. #3744004
    270HP. Carter WCFB front. Mfg. #2613S Chev. #3741089
    rear. Mfg. #2614S Chev. #3741090
    loudbang, Rat Sass and enloe like this.
  2. Baron
    Baron
    Here are some pictures of the 55-7 Chevy p***enger car headers that Steve had modified to fit his 56 Corvette.
    Steves 56 left header.jpg Steves left header at motor.jpg Steves left header.jpg steves rt header at motor.jpg .
  3. elgringo71
    elgringo71
    They fit very well, thanks for the pictures. It looks like the build is coming along well. The wheel choice looks good on that car too.
  4. Rat Sass
    Rat Sass
    I had a set of early Chevy II fenderwell headers that looked like they might work also but didn't take the time to try them as I already had the ones from Tubular. The early Chevy II is also a narrower car than the Tri-5 p***enger car.
    elgringo71 likes this.
  5. Quain Stott
    Quain Stott
    So far it sounds like it might fit the Southeast g***ers rules. Us 4 speed guys are a dying breed.
    Rat Sass likes this.
  6. Dragger52
    Dragger52
    No straight axle, bad*** nonetheless...
  7. bowie
    bowie
    Would that be Paris Fish? That car inspired a few others like it.
  8. Rat Sass
    Rat Sass
    Am I crazy?
  9. bowie
    bowie
    Crazy like a fox! I know i'll be following your progress.
  10. jimdillon
    jimdillon
    No you're not crazy. Although your midyear is a nice car, it may not stand out as much as a drag car and the fun factor is way up there with the drag car, my opinion of course.
    Baron and Rat Sass like this.
  11. Rat Sass
    Rat Sass
    It's been a racecar for years Jim, most recently a Super Gas car & not really a nice car...nice racecar maybe. The frame has been hacked & beat on over the years & I suspect possibly bent a little...the p*** front wheel is 1.5" higher with the frame blocked up & level.
    I've gone about as far as I intended with the '57...it was never going to be a racecar, just a restored G***er. This car has good safety equipment, roll cage & all the things you want to race with plus converting it only enhances the number of cl***es I can use it for.
  12. jimdillon
    jimdillon
    I had seen the cage but not sure what you had done with it. I figured you were thinking of going similar to the picture with the stack injection and lettered up which I thought was a step up. Cool either way.
  13. Baron
    Baron
    Hey Dan. No crazier than the rest of us (or some of us). I like the car just the way it is. Great look and stance. I'd straighten out the ch***is and turn it into a " really nice racecar". I have a 65 Chevy II that I was going to put an axle under , un-pro-streeted the rear,etc, but the car runs mid tens in street trim just the way it sits, and why go through all that work for a car that does everything I want it to do already. The other deciding factor was I also have 4 other projects waiting for me to find the time to start on. Bottom line is if it is what you want, and you have the time to do it, go for it. I'm going to like it either way,I'm sure.
  14. Rat Sass
    Rat Sass
    Thanks Jim, Baron. Converting the car makes it eligible to race at any of the G***er meets & that is really the only kind of racing I'm interested in at this time. Should I decide at a later time to go back to bracket racing, or Super Gas/Super Comp or anything else, the car will still be just as compe***ive as it is now (actually better because the frame will be square). I'm really excited about it as it presents a new set of challenges.
    Baron, as far as stance I agree it's a shame to change mine...but what if the car's stance is adjustable...as much as...say a foot? It could be as low as it is now in the front, or it could be nose up in a matter of minutes....stay tuned! ;)
    elgringo71, Scottrodsllc and Baron like this.
  15. enloe
    enloe
    from east , tn.
    when you getting started? if you need some help getting things ready call me and I will do my best to get there.
  16. Rat Sass
    Rat Sass
    Baron and Scottrodsllc like this.
  17. enloe
    enloe
    from east , tn.
    What are you going to do with the leftovers
  18. Utahvette
    Utahvette
    Here's a shot my friend took of my wife and me last summer, I like it! 12189369_10206967416576483_3011171761743142318_o.jpg
  19. enloe
    enloe
    from east , tn.
    Here is one from another thread it may be on here already
    hendelec, Rat Sass and elgringo71 like this.
  20. Baron
    Baron
    Guessing this may be the same car at a later date
    hendelec and Rat Sass like this.
  21. enloe
    enloe
    from east , tn.
    either that or it was Photoshoped :)
  22. Rat Sass
    Rat Sass
    Any of you guys hear that the Hayseed has been sold & that the original owner is now building a tribute G***er to look like his old one? 12195792_10206856954055819_4297511580212030852_n.jpg misc71.jpg
    hendelec and elgringo71 like this.
  23. Baron
    Baron
    Hi Dan. Doug sold all the race parts he took out of his car to another guy in NH who is building a clone of Hayseed,using many of the parts that were removed from the Corvette. Been in the building stage for 3 or 4 years ( since I first heard of the build ). The clone should be right on the money.
    loudbang and Rat Sass like this.
  24. Rat Sass
    Rat Sass
    Thanks Baron. So Doug still has the restored version?
  25. Baron
    Baron
    Yes, he does. He just went through the car again 2 or 3 years ago. Now a NCRS Bloomington Gold and Top Flight recipient. The car is perfect. Had a chance to talk to Doug at the Hot Rod Reunion. Super nice guy. And all his cars are flawless. Has a killer 31 Ford Roadster on a Deuce Ch***is, running stack injection, no less. Here are a few pics I took of the Corvette last summer.
    069.JPG 070.JPG 20150829_171422_resized (2).jpg 20150829_171509_resized (2).jpg 20150829_172414_resized (2).jpg Doug Juonis 31 A Roadster.jpg
    loudbang, Rat Sass and Scottrodsllc like this.
  26. PBRmeASAP
    PBRmeASAP
    Neat that it got restored, but man ya would almost thing the value would be in the history as is race car. cool it's still around and do***ented, but looks like all the rest of the restored turds
  27. Rat Sass
    Rat Sass
    Thanks Baron. Beautiful piece of history...just a shame there couldn't be one of each LOL. Personally, I hope he never sells it.
  28. Scottrodsllc
    Scottrodsllc
    from ohio
    First look at the ScottRods Custom 63 vette G***er Ch***is. This one is being built for a 7.50 cert. my vette chassis 5.jpg my vette chassis 4.jpg
    Rat Sass, elgringo71 and Baron like this.
  29. elgringo71
    elgringo71
  30. elgringo71
    elgringo71
