1932 Ford Roadster project, Flathead, T5 So-Cal Chassis
Discussion in 'Cars For Sale' started by englishrodder, Nov 1, 2015.
  1. City: Bellvue
    State: Colorado
    Price: $14,000
    1932 Ford roadster project.
    New SoCal 1932 Ford ch***is
    New SoCal chrome front hairpins
    Superbell dropped I beam
    New Speedway spring, bat wings, disc brake kit
    Ford 8" rear with 3.55 gears
    Early Ford wire wheels with smooth caps (tires are rollers ONLY)
    Adapters for the early ford wheels to late ford 4.5" PCD
    Comes with a good set of 40 Ford front brakes, hubs, spindles and drums
    1953 Ford EAB Flathead with new Bob Drake water pumps.
    New Powermaster 12V starter
    Chrome alternator, plus original Dynamo
    T5 S-10 transmission (likely need a rebuild NO adapter to the engine, you will need to buy!)
    New Speedway black Flathead headers
    Body is a Rod Bods out of AZ before they moved to Denver and became Denver Deuce.
    The body is a kit and needs to be finishing!!!
    It is ONLY tacked together! It needs finishing!!!
    Comes with some Brookville roadster hinges so you can convert to original look.
    Flat dash
    Only selling as moving and have too many cars /projects
    NO ***LE
    Bill of Sale only
    starbucks likes this.
  2. Bump - reduced to $13,200
