Technical V8 4 lug maverick 8" rear end for 63 falcon . YES I want to keep it four lug
Discussion in 'The Hokey Ass Message Board' started by Evilfalcon1961, Sep 4, 2014.
  1. Falcon61wagon
    Falcon61wagon
    from Indiana
    Can the explorer 8.8 be converted to 4 lug in any way. I'd rather not deal with the offset of the rangers axle. If I went with a maverick axle how much fab is involved to get it in there. I found a 71' for $150 do you have any idea what the ratios for those were?
  2. roundvalley
    roundvalley
    If you have a 5 lug Maverick, I bet there are a bunch of people who would gladly trade you Maverick 4 lug axles for your 5 lug. They are both 28 spline and same lengths.
    Back to original question. I think a 4 lug would handle a mild 302. Depends how you drive it.
  3. OLDSMAN
    OLDSMAN
    They were in Maavericks and Comets behind 6 cylinder engines. The pumpkin is the same as 5 lug v-8 pumpkins. You won't have a problem using it behind a v-8
  4. gimpyshotrods
    gimpyshotrods
    Yes, the Explorer can go 4-lug, too.
    That Maverick axle is likely 2.79:1 or 3.08:1.
  5. 69supercj
    69supercj
    I've got a 4 lug 8" out of a MII if your looking for one.
  6. gimpyshotrods
    gimpyshotrods
    That is 4-on-4-1/4". Not the correct pattern for the Falcon, which is 4-on-4-1/2".
    slammed likes this.
  7. Evilfalcon1961
    Evilfalcon1961
    from Ma
    Just found a rear out of a cobra mustang II looks like r
    The winner
  8. gimpyshotrods
    gimpyshotrods
    See my previous post.
  9. 38Chevy454
    38Chevy454
    As stated it has a slightly smaller bolt pattern. However, that rearend may have a 3.55 ratio, which is good to get. The 8-inch third member will interchange with any other 8-inch. 3.55 are hard to find, and Must II are one good source for them.
  10. A Smaller bolt pattern in the axles means a redrill to fit those wheels that this entire exersice is based upon - fitting those wheels.
  11. need louvers ?
    need louvers ?
    Just a quick FYI on this deal too.... The axles from a 4 lug 8" 1970 Maverick rear end do not interchange with the 5 lug axles from the same year V8 rear end in the same car. The brake off set is different enough that it won't fly, and if memory serves the bearing diameters are different as well.
  12. Ruben Duran
    Ruben Duran
    Another FYI, Mini-Lite currently produces two 5 x4.5 lug pattern wheels called the MagStyle and EV2000 that are similar to the Rewinds.
    I ran these vintage 15 X7 Mini-Lites as autocross wheels on my '67 Mustang......
    And here they are on an old Boss Trans Am car......
  13. gimpyshotrods
    gimpyshotrods
    Yeah, but he already owns the Rewinds.
  14. Get the super narrow s-10 rear @ 54ish and 1" wheel adapters that go from 5x 4-3/4 to your 4x 4-1/2.
  15. Evilfalcon1961
    Evilfalcon1961
    from Ma
    Those look good ! But I like thr size of mine 16x7. Looks like.will stick to my original though of a maverick 8" rear and have custom 4 lug axels made
  16. Ruben Duran
    Ruben Duran
    No worries, man...yours do look great. For any others interested in the 5 bolt pattern, they're also available in various sizes.....from 13x6 on up to 17x9
  17. Falcon61wagon
    Falcon61wagon
    from Indiana
    Does anybody know exactly which years of the explorer are options for the falcon swap?
  18. falcongeorge
    falcongeorge
    from BC
    Wow! THAT didn't take long...:DI used those Mustang II rears in a couple pintos in the late seventies, but kept the 4 lug axles
  19. Falcon61wagon
    Falcon61wagon
    from Indiana
  20. deathrowdave
    deathrowdave
    from NKy
    If I am thinking the bolt pattern early 4 lug and late 4 lug are different between the years you are wanting to swap anyway
  21. gimpyshotrods
    gimpyshotrods
  22. gimpyshotrods
    gimpyshotrods
    Once more:
    The Maverick was the last Ford car to share the same 4-lug pattern as the 6-cylinder Falcon, Comet, and Mustang, and that was 4-on-4-1/2".
    After that, the pattern went to 4-on-4-1/4".
  23. Falcon61wagon
    Falcon61wagon
    from Indiana
    I understood that swapping the explorer axle would require shortening the long side and it would also be 5 on 4 1/2 bolt pattern. I just wanted to be clear on the years of the explorer that the axle should come from.
  24. Falcon61wagon
    Falcon61wagon
    from Indiana
    As the article says 95'-2001'
  25. gimpyshotrods
    gimpyshotrods
    1993-2001(early). After that, the Explorer went IRS. Before 1995 they had drum brakes.
    There should be a ton in the yards.
  26. Falcon61wagon
    Falcon61wagon
    from Indiana
    So limited slip or open?
  27. gimpyshotrods
    gimpyshotrods
    Most are limited-slip. It will say in the tag. 3 55 isn't. 3L55 is, and so on.
  28. Falcon61wagon
    Falcon61wagon
    from Indiana
    If i had a choice which would be better. I realize the limited slip is basically a positraction.
  29. indyjps
    indyjps
  30. Falcon61wagon
    Falcon61wagon
    from Indiana
