Technical Fuel Pump for Flathead V8 with Strombergs 97?
Discussion in 'Traditional Hot Rods' started by cruiserbuddy, Nov 6, 2015.
  1. cruiserbuddy
    cruiserbuddy
    from Germany
    What is the best Fuel Pump for a Flathead V8 with a 2x2 Stromberg 97 Setup? Thanks.
  2. Petejoe
    Petejoe
    from Zoar, Ohio
    The mechanical original style ford pumps work just fine. If you decide to go with an electrical be absolutely sure you use an in line regulator set at 2 lbs pressure.
  3. Blue One
    Blue One
    from Alberta
    Even with a mechanical pump you will likely need a fuel pressure regulator set to 2 PSI.
  4. flathead4d
    flathead4d
    What Blue One said. I run 1-1/2 PSI on my triple 97's.
  5. cruiserbuddy
    cruiserbuddy
    from Germany
    Thanks so far. Had the mechanical pump installed and flooded the carbs.....so a regulator seems to be the way. Any electrical suggestions?[emoji4]
  6. steel rebel
    steel rebel
    Be sure if you run a pressure regulator you run a fuel gauge. Those regulators can swell and change.
  7. Kiwi 4d
    Kiwi 4d
    X2 on that one , especially the little round dial type regulators. We had no power , took a while to figure out we almost zero fuel pressure as the dial had self adjusted back way too much.
  8. steel rebel
    steel rebel
    Exactly same thing happened to me. Took forever to figure it out.
  9. HotRodMicky
    HotRodMicky
    If your mechanical pump flooded the carbs ,you did something wrong......
    You went to pendine this year with three hot rods that run mechanical pumps on 97s ............
    Maybe call me?
  10. cruiserbuddy
    cruiserbuddy
    from Germany
    Call You tomorrow, Micky. Okay?[emoji4]
  11. We run a new mechanical fuel pump on our Holly 94 in the roadster and still use a regulator with a pressure gauge....
  12. AULIZ
    AULIZ
    mechanical + good fuel line + good fuel hose from firewall to pump.
    I do not know right english word, but "flow" must be good.
    pressure is not so important.
  13. Bruce Lancaster
    Bruce Lancaster
    TEST the pressure, mechanical vs electric means nothing! MANY currently available mechanical pumps come with diaphragm springs that are WAY too stiff and thus produce way too much pressure. I would ***ume they are using some common semi-modern spring like SBC, as many pump parts are interchangeable.
    Get your old pump out of the trash can and transplant its spring...you can tell if it's a low pressure one by just comparing effort to squeeze old and new spring by hand!
    I have heard that the Daytona carb parts place has proper pump parts and kits...no personal experience, but several recommendations by people I know. It's silly to put in a pump with wrong spring and then add $$ and extra junk to get back to usable!
    rtsidejohnny and drifters cc like this.
