Projects A new '32 project of my own.
Discussion in 'The Hokey Ass Message Board' started by hot rod pro, May 3, 2015.
  1. hot rod pro
    hot rod pro
    from spring tx.
    Great. Come on by.
  2. hot rod pro
    hot rod pro
    from spring tx.
    Progress on the top chop. Passenger A pillar almost finished. Just needs some clean up in the corners.
    ImageUploadedByH.A.M.B.1446851492.231560.jpg ImageUploadedByH.A.M.B.1446851502.550558.jpg ImageUploadedByH.A.M.B.1446851514.940464.jpg
    HEMI32 and Dan Hay like this.
  3. hot rod pro
    hot rod pro
    from spring tx.
    Progress on the top chop. Drivers side A pillar almost finished. Just needs some clean up in the corners. #brucesrodshop #32mafia ImageUploadedByH.A.M.B.1446993692.847639.jpg ImageUploadedByH.A.M.B.1446993710.655314.jpg ImageUploadedByH.A.M.B.1446993722.144332.jpg
    CTaulbert likes this.
  4. hot rod pro
    hot rod pro
    from spring tx.
    Passenger door almost finished. #brucesrodshop #32mafia ImageUploadedByH.A.M.B.1447088899.460116.jpg ImageUploadedByH.A.M.B.1447088912.931337.jpg ImageUploadedByH.A.M.B.1447088925.287176.jpg
  5. fatboys69
    fatboys69
    from Tennessee
    Wow !!!! Very Nice !!!! What Craftsmanship !!!!
  6. hot rod pro
    hot rod pro
    from spring tx.
    Thank you for the kind words.
  7. 3wLarry
    3wLarry
    from Owasso, Ok
    note to self...1960's Competition Orange
    kidcampbell71 likes this.
  8. hot rod pro
    hot rod pro
    from spring tx.
    My old roadster. Hugger orange. I built it back in '98. ImageUploadedByH.A.M.B.1447099516.520302.jpg
    invada, 54reno, 3wLarry and 1 other person like this.
  9. alchemy
    alchemy
    Looks like you knew a thing or two about tire sizes even way back then.
  10. Dadio 56
    Dadio 56
    I have learned more from watching this thread than watching all those TV build shows. Keep up the inspiration!
  11. flatheadpete
    flatheadpete
    from Burton, MI
    Dang......keep at it.
  12. hot rod pro
    hot rod pro
    from spring tx.
    Thanks. I strive to hit the perfect stance and tire combination on every build.
  13. hot rod pro
    hot rod pro
    from spring tx.
    I'm glad I can inspire in some way with this project.
  14. Dadio 56
    Dadio 56
    With a BBC and a stick, would a driveshaft loop be a good idea?
  15. 36couper
    36couper
    from ontario
    Now that is the wheel set-up a fenderless coupe needs!
  16. hot rod pro
    hot rod pro
    from spring tx.
    Probably. Knock on wood. [emoji2]
  17. rcnut223
    rcnut223
    from wisconsin
    Danny
    Did you lean the a pillars back?
    If so did you slice the cowl and lean that back as well?
    Thanks
  18. hot rod pro
    hot rod pro
    from spring tx.
    Yes. I leaned the post back. Here is where I cut it ImageUploadedByH.A.M.B.1447261018.316756.jpg ImageUploadedByH.A.M.B.1447261033.437086.jpg ImageUploadedByH.A.M.B.1447261046.559799.jpg ImageUploadedByH.A.M.B.1447261057.996516.jpg
  19. rcnut223
    rcnut223
    from wisconsin
    Thanks for the pictures and the reply
    So you left the bottom of the window trough alone? I've seen it leaned back as well
  20. hot rod pro
    hot rod pro
    from spring tx.
    No. It stayed the same. The little amount I leaned the posts back, it didn't need it.
  21. mgtstumpy
    mgtstumpy
    Love the fabrication, attention to detail and execution
  22. racer_dave
    racer_dave
    phenomenal build...
  23. greaser
    greaser
    Are the hinges twisted, or adjusted to keep both axis in-line?
  24. hot rod pro
    hot rod pro
    from spring tx.
    The upper hinge is slightly out of alignment with the bottom hinge, but the door swings just fine. I plan to leave it.
  25. greaser
    greaser
    Wish my welds looked as good as yours. Nice work!
  26. hot rod pro
    hot rod pro
    from spring tx.
    Thank you. Years of practice, and I still could be better.
  27. hot rod pro
    hot rod pro
    from spring tx.
    A few new shots. ImageUploadedByH.A.M.B.1447841928.561839.jpg ImageUploadedByH.A.M.B.1447841941.133759.jpg ImageUploadedByH.A.M.B.1447841954.239535.jpg ImageUploadedByH.A.M.B.1447841965.062151.jpg
    pscalz and kidcampbell71 like this.
  28. kidcampbell71
    kidcampbell71
    Whoah .... bad neighborhood .... you shoulda' locked your doors, they stole your body !! :) Nice view you have there. Murderer's row of Deuce.
  29. hot rod pro
    hot rod pro
    from spring tx.
    Just a few new pictures. ImageUploadedByH.A.M.B.1448198027.325359.jpg ImageUploadedByH.A.M.B.1448198037.229715.jpg ImageUploadedByH.A.M.B.1448198049.018302.jpg
    wedjim, bengeltiger and kidcampbell71 like this.
  30. DDDenny
    May I have more please!
