Features *Lets see those detailed traditional engines!!
Discussion in 'Traditional Hot Rods' started by Bondoboy, Mar 23, 2008.
  1. Runnin shine
    Runnin shine
    You know of course poverty stricken me has to make some of these myself now. I go the distance and also put in the George approved safety wire holes too.
    falcongeorge likes this.
  2. RainierHooker
    RainierHooker
    from Tacoma, WA
    Pretty normal AN-Type clamps. Use them all the time at work (I'm an aircraft mechanic), and can be bought at any decent hardware supply place near, or on an airport. I've got several boxes of old ones that I use on my cars, all different manufacturers, but all from WWII-era packaging...
  3. enloe
    enloe
    from east , tn.
  4. blackanblue
    blackanblue
  5. Lbass
    Lbass
    from Joplin, MO
    It took me a second to catch what exactly that was... and I don't think I've ever seen a blower on a 6cyl, But it is damn cool. What is it powering?
  6. selectedgrub
    selectedgrub
  7. X38
    X38
  8. 26 T Ford RPU
    26 T Ford RPU
    Is that Bill's Crown Jewels Coupe? Cool !! JW
  9. tofords
    tofords
    VERY nice Neal
  10. barrnone50
    barrnone50
    from texas
    You have done a outstanding job on this flat Head. Sweet!! Are those risers on your manifold your handy work?I guess that is what you call them. It for sure gives it the look.Great Job. George
    falcongeorge and drifters cc like this.
  11. 270ci
    270ci
    54 Chebby.
  12. LAROKE
    LAROKE
    Here's another, also on a 235 Chevy Stovebolt (55 1st Series Chevy truck). I'm only in the mock up stage at this point.
    Dyno Dave, biggeorge, 270ci and 2 others like this.
  13. drifters cc
    drifters cc
    Thanks George, I have tried to capture a bygone era. It's the little things that can make or break a "period correct"
    or "traditional engine". I did fab up those risers under the carbs. The Hexagon manifold has the carbs ( float bowls) turned backwards so not to interfere with the stock generator mounting position. Well if I were to throw a couple Holley's or Stromberg's on there they would clear. But I got cute and wanted run these odd ball Marvel-Schebler
    carbs and they are bigger and hit the generator. So I made the risers to solve that problem. Not planned on them but I too think they give the motor the look. IMG_0603.JPG
    LOU WELLS likes this.
  14. barrnone50
    barrnone50
    from texas
    I saw on Ejay the Hexagon manifold I think its yours for sale. If you haven't sold by the end of your auction let me know I might be interested. I just spent a chuck on 2 door A so funds are tight.. You nailed it on bygone era!! George
  15. Kerry
    Kerry
    I'm late to this show. Here's the hemi in my Dragmaster.
  16. Fedcospeed
    Fedcospeed
    My Merc
    biggeorge likes this.
  17. 28dreyer
    28dreyer
    from Minnesota
    WOW11031.jpg My Studebaker Champion.
    Water pump is driven off nose of the crankshaft.
    Dyno Dave, biggeorge, Jet96 and 6 others like this.
  18. falcongeorge
    falcongeorge
    from BC
  19. rcavaliers
    rcavaliers
    from downey
    Dyno Dave, jebbesen, Jet96 and 8 others like this.
  20. Here is the 42 Merc flathead engine that I just completed and put in my cabriolet. I originally going to run a set of early Eddie Meyer heads, but the chambers were too small for the valves and I didn't want to hack them up . . . so I put on a set of Navarro heads that I got from Barney years ago.
    2015-11-07 18.30.47 copy.jpg 2015-11-07 18.30.55 copy.jpg 2015-11-07 18.31.35 copy.jpg 2015-11-11 19.21.31 copy.jpg 2015-11-11 19.21.40 copy.jpg
    biggeorge, tevintage, gonmad and 8 others like this.
  21. atch
    atch
    x2
  22. Lynspop
    Lynspop
    Nicely done!!
  23. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Dyno Dave, Jet96, Shoop107 and 4 others like this.
  24. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Working on a couple more!
  25. VonGhoul
    VonGhoul
    from SW Florida
  26. VonGhoul
    VonGhoul
    from SW Florida
  27. VonGhoul
    VonGhoul
    from SW Florida
  28. Shoop107
    Shoop107
    Tuck. What's the story on these valve covers?
    wedjim likes this.
  29. Nostrebor
    Nostrebor
    x3! Care to share what it is?
