Technical Weber carb set up Pricing advice?
Discussion in 'Traditional Hot Rods' started by david buczynski, Nov 15, 2015.
  1. david buczynski
    david buczynski
    I came across this listing EBay for this Weber carb set up for SBC I really like and thinks it cool looking. But I have bid up to a $1000 and still have not hit his reserve. What do you think its worth? It comes with over $100 worth of jets and throttle bracket.
  2. If you haven't hit the reserve at $1K, I think it's overpriced. I've seen 4 IDF weber carb setups sell used in the $1500 range (or all-new at $2400) and that's arguably a better setup. The two-carb is a bit rare, so I expect you're mostly paying for that....
    falcongeorge and david buczynski like this.
  3. J. A. Miller
    J. A. Miller
    from Central NY
    Are there other people still bidding? If so, there's your answer.
  4. david buczynski
    david buczynski
    I'm the only bidder so far! 4 days left, but that is the most I'm willing to pay. thanks.
  5. Mr cheater
    Mr cheater
    Well than I guess you aren't getting it than
    Truck64 and LOU WELLS like this.
  6. Most bidding is in the last hour..you may still get a second chance...
  7. ididntdoit1960
    ididntdoit1960
    from Western MA
    Its in the cl***ifieds on here......prob give you a good idea on the reserve price....
    david buczynski likes this.
  8. Jalopy Joker
    Jalopy Joker
    Ha! good reply - if all else fails check the cl***ifieds here, better yet is to check them first
  9. falcongeorge
    falcongeorge
    from BC
    why in hell are you bidding it up with 4 days left? I guess if you haven't hit the reserve, its a moot point, but...
    And I agree with Steve.
    Kona Cruisers likes this.
  10. big duece
    big duece
    from kansas
  11. mad mikey
    mad mikey
    You have to wait till the finale minutes!!!!! and bid more if you want it, I would not go over 1100.
  12. falcongeorge
    falcongeorge
    from BC
    Theres times I've paid over the odds for rare stuff I really wanted, 6 months from now, it wont really matter what you paid for it. But Its gotta be something I really want, and have been hunting for.
    gwhite and david buczynski like this.
  13. Atwater Mike
    Atwater Mike
    My recollection of the old Moon setup (4 of these) make this setup look a little anorexic.
    Rarity of the intake and visual condition of the Webers make the reserve believable.
    Like George says, "4 days left?" Bidding already?
  14. david buczynski
    david buczynski
    I was trying to feel out the reserve on it , looks like someone else has out bid me ill keep an eye on it I like it because its different not some thing you see often.
  15. 383deuce
    383deuce
    I thought it was cool also for the same reason....But way to much$$$$
  16. Here is something to think about. Ford A.C. Cobras with a 302 ci. motor ran 4, 48's. Moon made a 327 manifold for the 4, 48's. If your motor is anything at all are 2, 48,s going to be enough? Looks aren't diddley if it won't perform.
    The Wizzard
  17. Jalopy Joker
    Jalopy Joker
    have you called the seller in ad here, charlesincharge09 ?
  18. david buczynski
    david buczynski
    No Its listed for 17oo here I saw it some ware else for 1500. I will wait and see where it goes on EBay first
  19. 97
    97
    It will only be good for a small cubes sbc , even if it has the largest venturies available fitted, a pair of 40s will only flow about 425cfm. They fit these to 1600cc engines in Europe. That's why only 11 manifolds were made, CB performance was prmarily a vendor of VW performance parts.... Webers need to be 48mm and four of them to make a V8 run reasonably well.
    Good for a 283 to about 5800rpm.
  20. gimpyshotrods
    gimpyshotrods
    For perspective, I had a pair of 45mm Dellortos (Weber-'ish) on an engine back in high school.
    It was an 1835cc VW.
