History Help me find some old photos of this Cedar Rapids Iowa 1940 Ford Coupe
Discussion in 'Traditional Hot Rods' started by Roadsir, Sep 22, 2015.
  1. Roadsir
    Roadsir
    I got nuthin compared to Mark!
  2. TerrytheK
    TerrytheK
    :D
  3. Roadsir
    Roadsir
    Katman1 and Moriarity like this.
  4. Roadsir
    Roadsir
    Yesterday was opening day for hunting Hemi parts. I bagged my limit, and found these cool Chrysler Marine valve covers with breathers, some exhaust manifolds, and a pair of Hurst Hemi to 40 Ford motor mounts.
    I was one over the limit on Stromberg's and got five, so I have a spare.
    Should be enough parts to carry me through Spring!
    1927graham, Fedman, Katman1 and 6 others like this.
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    you got it made!!!!
  6. Roadsir
    Roadsir
    Had to set the parts on the motor today to get a feel for how it might look.
    This motor is rebuilt with no miles but I think I'll pull the heads to check it out for sure.
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    looks like 1000 hp from here!!!
    lothiandon1940 and Tim like this.
  8. Roadsir
    Roadsir
    Lbs maybe!, I don't know about hp!
    lothiandon1940 and Runnin shine like this.
  9. YJ4000
    YJ4000
    Very cool, looks like it will be a fun motor.
    Ryan.
    Roadsir likes this.
  10. Tim
    Tim
    from KCMO
  11. mickeyc
    mickeyc
  12. mickeyc
    mickeyc
    Hey I have a set of those Chrysler Marine valve covers. I have the engine as well it came with
    a2x4 cast iron manifold, a heavy beast of an intake! I have been told the block letter covers are
    not as common as the script marine covers.
  13. Roadsir
    Roadsir
    I don't know much of the history or specs on the marine motors. I'll have to do a little more research. I thought the covers looked cool. I haven't seen script style.
  14. Roadsir
    Roadsir
    After buying a project pickup several years ago and selling it and a bunch of parts I ended up with this 392 that had been gone through. I decided to tear it down today to check it out.
    The heads are nicely machined. Valves are larger 2.125, and 1.875. They have umbrella seals, new springs, and it came with new rocker shaft ***emblies.
    It has a re grind solid lifter cam and I have the card. I forgot to take a picture to post the specs.
    The exhaust ports have had a little m***aging.
    I knew the block was stock bore and pistons with a light hone. I was bummed when I pulled the heads and found some water, and it was my fault. When I hauled this home I got caught in a hailstorm and just missed a tornado. The motor was on my trailer and bagged but had a few holes. When I got home I fogged the motor, and down the plug holes ( plugs weren't in the heads) but a little water must have been trapped in two cylinders.
    Here's the good side.
    Here's the bad side. I'll see what the machine shop thinks if it will clean up with a hone. I actually wouldn't mind new pistons...
    The second and last holes had a real light rust. It wasn't stuck.
    Top view. It's a 58 block.
    This is off topic for the 40, but I have never liked the headlight placement on my Roadster, and I like the look of a bar crossing the grille. Friday night I made this from a aftermarket dropped 32 bar and model "A" ends for the uprights. I need to relocate the signals. Much improved ( I think).
    kiwijeff, 1927graham, Katman1 and 3 others like this.
  15. Roadsir
    Roadsir
    Just a little progress update. The 392 block is at the machine shop. Most of the staining was and pitting is most likely older damage, and the decision to hone versus re-machine was probably marginal. Yesterday we checked the a few of the bores and the and they measure .005-.010 out of round. I decided to go ahead and and break it down and bore the block and get a set of pistons. This will give us a chance to check the crank, and the rest of the internals to be sure everything is up to parr.
    I'm doing a little clean-up on the small block in the car, and slipping in a Walker Radiator. I'l post up some pics when it cleaned up.
    In the mean time I came across this Cedar Rapids car in another post. Bill Wernimont's 32 five window coupe featured in Rodding & Re-Styling March of 58. The Midwest and Iowa in particular were putting some nice cars together.
    http://www.jalopyjournal.com/forum/threads/1950s-period-correct-hot-rods.430894/page-36
    kiwijeff, kidcampbell71 and Moriarity like this.
  16. Always thought the Marine Covers were the coolest!! Good find.
  17. alchemy
    alchemy
    I think that black 32 might be the one that shows up at the CR swap meet every year. I saw it again this year. Different wheels and some other details, but the car looks otherwise the same. I don't know who the current owner is.
  18. Roadsir
    Roadsir
    It's a pretty cool old car.
  19. Roadsir
    Roadsir
    Here's a small update. I got the walker radiator installed, motor cleaned up a little, pulled the chrome alternator, and painted the brackets and pulleys. To everybody's dismay I pulled the Edelbrock elite valve covers[emoji22].
    I picked up a pair of these covers from the HAMB cl***ifieds. I like'em, something a little different to hold me over until the 392 is ready to go in the car.
  20. Roadsir
    Roadsir
    Saturday I picked up dad and ran down to Cedar Rapids. I wanted to meet John Park who has excellent memories about the 40, but also talk about vintage dirt track cars, and hopefully get some leads to help my Dad restore his '69 and '70 dirt track modified that he built. This car with Jim Edgington driving, and Ron Barton building the motors, dominated the So Minnesota and Northern Ia dirt tracks, and was also the 69 And 70 Minnesota State Fair Champ on asphalt.
    Here's a couple pics...... I'll have to start a build thread on this next ( probably on dogfight ). Dads basically starting with his original ch***is, so if you have any parts leads shoot me a message.
    1st year long wheelbase.
    Here's a shot with a "A" body fitted to meet some local track rules. That's me sitting on the tire, and why to this day I like the smell of grinding wheels, arc welders, and holding the trouble light for my Dad. I learned a lot looking through the back of his welding helmet.
    We need to work on recreating this picture. [emoji3]
    Here's a shot from 1970. The wheelbase was shortened 10" and the Vicky body added.
    John is very knowledgable and has an eye for detail. This is a '84 Trostle offset ch***is sprinter that he restored, and it's drop dead gorgeous.
    John thought this would be a good piece for the 40's hemi. It's a Davisco Cirello "Frankenstein" Magneto for a 392. I need to do a fit check and call Cirello to see what it will cost to go through. It's a cool piece.
  21. Corn Fed
    Corn Fed
    Restoring your Dad's modified will be a fun trip down memory lane. What version is he going to do?
  22. Roadsir
    Roadsir
    We also met up in Center Point with Eric Aurand ( Hot Rod Artist), his wife Monica, and another couple that Eric has been helping get their 1940 deluxe coupe on the road after a long hiatus. He's put a few build updates in the MSRA linechaser, look for a metallic brown coupe with a black ****on tufted interior and fresh flatty to be on the road this year.
    When in Iowa, you have to have a Pork tenderloin!
  23. Roadsir
    Roadsir
    That's his current ***ignment! It will be short wheelbase.......but which version??
    The 69 car had a ******* bunny painted on the tail that people remember well....... And is why I got in trouble in 2nd grade when we had an art ***ignment to draw the Easter Bunny and I depicted it as the ******* bunny, standing at the bar drinking "Old Milwackey". Not sure where I got that from as they were sponsored by Schlitz!
    Sounds like a lot of people have fond memories of the Stars and Stripes car because of the paint, and the era.
    1927graham likes this.
  24. 40FordDeluxe
    40FordDeluxe
    Great car and history to go with it. I just read your entire thread and I bet I know a man who ran into this car in Cedar Rapids a few times back then. Bill, told me several stories about growing up in Cedar Rapids and all the hot rods and motorcycles they used to build and race back then. He always talked about a 40 Ford coupe with a Hemi that always beat their Olds powered 36 coupe. I wish Bill didn't have dementia so bad. I'd gladly get you his info so you could talk with him. Terribly, it's all gone now. I sure am looking forward to the time you put the 392 in it!
  25. Roadsir
    Roadsir
    Thanks for posting. I would be interested if you could come up with any more information. I've been slacking off a little bit this winter. I'm going to start putting the new shifter, and fuel tank in. We have the 392 lower end torn down, measured up, and I'm ready to order the pistons, bearings, and I think I'll change the cam grind, so hopefully there will be a few more post in the future. I've got the new shifter, and fuel tank to install.
  26. Roadsir
    Roadsir
    Well. I'm still having fun with the "small block" in the car. The shifter is sorted, as well as the clutch linkage. Now I need to re-do the fuel system, and in general tidy a number of things.
    Here's a short video:
    kiwijeff, T Hudson, Tim and 3 others like this.
  27. Roadsir
    Roadsir
    Here is another short video. You can't really see it but it I was getting some pretty bad wheel hop and had to let up a few times..
  28. glrbird
    glrbird
    I love your cars, you can hear the wheel hop in the tire squeal.
    Roadsir likes this.
  29. Roadsir
    Roadsir
    Ran the 'ol 40 at the HAMB Drags this year. I started a video thread but thought I post a copy here as well.
    This p*** was a 13:21.....
    Tim likes this.
  30. HelmuthBrothers
    HelmuthBrothers
    from New Jersey
    Amazing story so far! In love with the early stages of the car with the hemi. What a clean build for back in the day! Will be following along!
