Projects 1948 plymouth chop
Discussion in 'The Hokey Ass Message Board' started by uglybaby, Nov 16, 2015.
  1. uglybaby
    uglybaby
    from tri-cities
    so been a while since i posted
    recently went to work for a hot rod shop (snake river street rods)
    and they let me loose on a 48 plymouth
    here are a few pics
    getting things measured
    bracing it up
    welding the fenders on
    full frontal
    putting a beak on her
    sprocket getting the job started
    this is the point when you say "well we got this far lets cut it off"
    oh but first back window gone
    to late now top is off
    jesus managed to get the whole crew in this shot except me
    top going back on
    tackin it up
    hmm b pillar angle?
    thinkin i like it
    gettin the back window fitted
    b pillar fixing
    i am liking it
    getting the rear drivers window shaped
    lmao
    now this is stance!
    well that was day one on the 48 chop
    more to come tommorow
    thanks for the look
    randy
  2. 73RR
    73RR
    What else is planned for the car?
    Stogy, kidcampbell71 and uglybaby like this.
  3. uglybaby
    uglybaby
    from tri-cities
    we are chopping it now
    4 1/2 front and 4ish in the rear lmao
    it was whatever the car dictated
    next for mods we are molding the headlight rings and frenching the buckets
    also we are thinking a 53 chevy car grill might look good
    the car is sitting on an art morrison ch***is
    it has a parallel 4 link in the rear
    tubular upper and lower front a arms
    power rack and pinion
    air ride front and rear
    it is mini tubbed in the back for some decent size tires
    custom built front structure and core support to hold fenders so we could weld them to the body
    it also has a modestly built 340 and auto trans
    just building a fun driver
  4. uglybaby
    uglybaby
    from tri-cities
    here are a few more pics
    getting the rear window corner shaped
    starting on the drivers door pillars
    checkin proper elbow clearance
    busted out some panel supports for the interior of the trunk
    engine shot
    ch***is shots
    aired up
    thanks for lookin
    randy
  5. uglybaby
    uglybaby
    from tri-cities
    please don't flame me for the ch***is or powertrain
    it was not my choice i just get paid to work on these
    someone asked so i posted
    haven't seen many chopped Plymouths so figured i would show the one i am chopping
    randy
  6. Jalopy Joker
    Jalopy Joker
    Wow - nothing like a simple low buck ride - you are doing great
    uglybaby likes this.
  7. uglybaby
    uglybaby
    from tri-cities
    thanks
    i just want to give the guy a bad*** looking car
    as far as simple and low buck goes lmao
    all i can say is guy will love this car when it is done
    he already bought a chopped 46 plymouth and it was garbage
    rusty as hell,and poorly done some spots had 1 1/2 " of bondo
    we found him this barn find and are in the process of building his dream
    he didnt want a taildragger which these cars almost beg to be turned into
    so it has been a challenge
  8. "he didnt want a taildragger which these cars almost beg to be turned into"
    i'm fighting that decision right now with my Plym. the business coupes are hard to make look right with a chop, but the club coupes can only be improved by one! you're doing an awesome job.
  9. uglybaby
    uglybaby
    from tri-cities
    well a little more today
    started on the p***enger side
    got the back window tacked to the roof
    started welding and making filler panels
    thanks for looking
    randy
  10. uglybaby
    uglybaby
    from tri-cities
    well day 4 on the 48 plymouth chop
    started making the c piller panels
    sprocket getting his tig on
    the other side[​IMG]
    looking pretty good
    getting the last few pieces made
    the filler between the trunk and back window
    [​IMG][​IMG]
    now it just welding and grinding for a while
    thanks
    randy
  11. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    dig it... keep up the good work
    Stogy and uglybaby like this.
  12. xpletiv
    xpletiv
    from chiburbs
    Nice work!
    Just a tad curious on how the corners of the trunk filler will be finished.
    Staying tuned in.
  13. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Looks great. Really nice lines! Too bad you don't have a pullmax as you could have fabbed up replacement quarter window corners like is done sometimes on 49-51 Mercs. It saves the m***ive labor of welding/grinding a dozen or so relief cuts in each corner.
  14. uglybaby
    uglybaby
    from tri-cities
    thanks for the replies everyone
    man i wish we had all the bad*** tools
    we are a fairly new shop with very basic tools
    as we get going the tools will come
    as for the corners of the trunk filler piece
    the pics make it look wierd , it has a really nice natural looking flow
    i may extend them a little just to cut the angle down a bit
    chryslerfan55, Peanut 1959 and Stogy like this.
  15. Baldies
    Baldies
    Very nice.
  16. 38Chevy454
    38Chevy454
    Nice amount of chop and the work looks nice so far. Agree that all those relief cuts is a lot of welding and grinding!
    So why did you weld the fenders on? Just trying to make it more smooth?
    chryslerfan55 and uglybaby like this.
  17. uglybaby
    uglybaby
    from tri-cities
    thanks again all
    here is a little better pic of the corner
    and i agree about the extra work
    but i used what had
    i can only talk the boss man into so many tools
    i think the end result will work just take longer
    the reason for welding the fenders was final fit
    it would have taken longer to gap them and then take the chance of chipping the edges
    so we just built an inner structure and welded them
    plus it should look real cool when done
  18. 73RR
    73RR
    Don't worry about the ch***is and drive train. If anyone *****es its likely because they are jealous...who would not want a 340 in such a ride?
    Oh yeah...serious tin work. Where are you in the tri-cities?
  19. zjerry
    zjerry
    Nice looking chop..
  20. uglybaby
    uglybaby
    from tri-cities
    thank for the comments all
    shop is located in finley washington
    just outside of kennewick
  21. 55willys
    55willys
    I like the flow of the chop. I build those high dollar street rods as well. You just have to appreciate the work and disregard the running gear. Instead of welding up all those pie cuts in a fairly flat piece I would just curve the radiused area and fill it with a new piece in the flat area to save time and grinding.
  22. uglybaby
    uglybaby
    from tri-cities
    yeah
    i cut out alot of the pie cut **** and replaced it with full pieces
    here is a shot of the start
    going to replace the tops of the door corners
    had to run those through the wheel and shape them a bit also
    every part of this darn car is curved LOL
  23. 55willys
    55willys
    Looks good, better than welding and grinding all those cuts.
  24. uglybaby
    uglybaby
    from tri-cities
    thanks and oh yeah lots easier
    plus i can get the door gaps dialed in
  25. uglybaby
    uglybaby
    from tri-cities
    customer showing up on monday
    hope he likes it LOL
    here is a pic of the first 46 he purchased
    it was poorly done with a ton of filler(notice the bend in the rear window frame)
    rear gl*** didnt fit
    when we blasted it it almost fell apart it was so rusty
    i think we have improved a bit
  26. uglybaby
    uglybaby
    from tri-cities
    so a little update
    chop is going along as planned
    not much to show there welding and grinding
    so on to the front of the car
    the front of a 48 plymouth is somewhat flat and not as curvy as the rest of the car
    soooooo lets fix that
    stock dechromed
    sort of a square hole in a round peg LOL
    so the customer is a mopar guy and wants the car to remain mopar
    and he wants to retain the look of the 48 plymouth but gave us a bit of artistic license
    so found some pics of a 40 desoto and thought hmmmmmmm
    hit up a buddy and sure enough he had a set of front grill shells
    oh my let the fun begin
    a little test fit
    not to bad
    little metal work should be fine
    other side mocked up
    tommorow should be interesting
    cuttin out half a fender and reshaing the entire fron of the car
    LOL
    and then praying the new grills we ordered fit the holes
    thanks for looking
    randy
  27. Looks great so far, I like the angle of the B pillars. Follows the C pillar angle, and is more severe than most I've seen before.
    Grill looks like it was made for that car, I'm keen to follow along.
    Stogy likes this.
  28. uglybaby
    uglybaby
    from tri-cities
    thanks
    i layed the b pillar forward a ton because i wanted to keep the integrity of the rear side window
    i see many of these cars when chopped the front side window looks a mile long and the rear side window look tiny
    always thought that could be improved
    as for the grill
    yeah it is a perfect look for the car
    i just have to make it fit now
    lol
    Randy
    chryslerfan55, Stogy and kiwijeff like this.
  29. Jose perez
    Jose perez
    Very motivating.... Can't wait for the finish product.
  30. Jose perez
    Jose perez
    How's the chop going? Any recent picture of the process.
