Technical 1958 Mercury alignment
Discussion in 'The Hokey Ass Message Board' started by crankcaser, Nov 22, 2015.
  1. crankcaser
    crankcaser
    from Houston
    Can anyone help me out with specifications for front end alignment on a 1958 Mercury Montclair? Thank you.
  2. ,,from MOTORS,,caster -3/4...camber +3/8 toe-in 3/16-5/16
    crankcaser likes this.
  3. crankcaser
    crankcaser
    from Houston
    Thank you s****iron
  4. Mr48chev
    Put about 1/4 degree more + camber in the left wheel than the right To compensate for the crown in the road. I found that was usually the amount that helped the car drive straight down the road back when I was doing alignments daily.
  5. bobss396
    bobss396
    This is 100% correct. I did the same thing when I did alignments every day too.
