Hot Rods Grille ID
Discussion in 'The Hokey Ass Message Board' started by 33highboy, Nov 23, 2015.
  1. 33highboy
    33highboy
    from Florida
    Can anyone help me ID this grille is it a ford pickup or a British model, thanks
    kidcampbell71 likes this.
  2. Speed Gems
    Speed Gems
    36' ford pickup cut down.
  3. timwhit
    timwhit
    Yep. Wasn't that Goodguys hot rod of the year? (or some thing like that) Tim
  4. alchemy
    alchemy
    Not 36 pickup, but looks like 37 pickup.
    Hnstray likes this.
  5. X38
    X38
    It's a modified 37 pickup.
    Hnstray and Dizzie like this.
  6. Daddy_O
    Daddy_O
    ^^^ X2 ^^^
    Hnstray likes this.
  7. Katuna
    Katuna
    from Clovis,Ca.
    Pick up the latest Rodders Journal. It has a cover story on that coupe. Might even say how they modified it (I haven't read it yet so I couldn't tell ya).
  8. That's a 1937 to mid 1940's E83W Anglia Thames Panel Grill. How do I know, I've got a NOS Grill. I found it from a Englishman. I'm needing A Complete S/S Grill Trim.I'd like to know the Iden***y of those *****in Wheels? The Last year of Rod & Custom, there was a article on a 33/34 Ford 3-W Coupe using the
    1937 E83W Anglia Thames Panel Grill. They also showed a How To: making a Custom Louvered Aluminum Hood. Coupe was a Hiboy, So, on 2nd looking at the Picture, this might not be that 1933/34 Coupe in the Article, not a 1937 Anglia Grill. As, in the Above Picture. Thanks BigDTexasKid
    29EHV8 likes this.
  9. rusty rocket
    rusty rocket
    Im sure its a narrowed 37 pick up.
  10. X38
    X38
    I recall the R&C article and that was indeed a Thames grille.
    The grille in question here however, is not. Nor is it a stock 37 pickup one, it has been modified and as a result does look a bit like a Thames.
    These are Thames. Similar, but obviously different and a lot thinner.
  11. studeynut
    studeynut
    Agree!
  12. Ned Ludd
    Ned Ludd
    Note the two starting-handle holes in the Thames grille. To keep the wheelbase short the E83W had its engine offset to the p***enger side, i.e. the left on right-hand-drive vans. Early ones had only one hole, suitably offset to the left. When Ford began making left-hand-drive vans for export the frame layout was mirrored on those, and it made more sense thereafter to make grilles with two holes than two types of grille.
  13. chickenridgerods
    chickenridgerods
    from DSM, IA
  14. 33highboy
    33highboy
    from Florida
  15. X38
    X38
