1952-59 Ford Speedometer jumping
Discussion in 'Off Topic Hot Rods & Customs' started by BeerMoney, Nov 15, 2015.
  1. BeerMoney
    BeerMoney
    Hello
    my speedometer in my 55 ford customline started makeing a racket and jumping around yesterday.
    could some one tell me what might be wrong i have the 302 with a c4 ****** i have the right gear and cable because it was working .
  2. 55Brodie
    55Brodie
    I would start with looking to see if the cable is kinked or has a bind anywhere. Then I would disconnect it at the speedometer and pull the cable out and clean, re-lube it and re-install.
  3. HOTRODPRIMER
    HOTRODPRIMER
    Exactly. HRP
  4. JeffB2
    JeffB2
    from Phoenix,AZ
    If there is no kink you might detach it at the Speedometer head and spray some WD-40 down the cable housing I have had that work several times in the past.
  5. bobss396
    bobss396
    Graphite is still the best thing to use on the actual speedo cable itself. WD may be good at the speedometer head, used sparingly.
  6. JeffB2
    JeffB2
    from Phoenix,AZ
    The graphite can cake up causing the problem.the WD loosens it up again.
  7. bobss396
    bobss396
    Well.. if it matters, I like gravy on my French fries.
  8. JeffB2
    JeffB2
    from Phoenix,AZ
  9. BeerMoney
    BeerMoney
    i think i fixed it i took the cable out and sprayed wd40 all over it and put some axle greese on the end that goes in the speedometer. works like a charm
    Copper Top likes this.
  10. Paul2748
    Paul2748
    I've used lithium grease in my speedo cable. WD-40 is not a lubricant and won't last long. Graphite is also good.
  11. bobss396
    bobss396
    Lock Ease is not bad either. I use it just at the ends.
  12. parklane
    parklane
    Ya, what Paul said
  13. Texas57
    Texas57
    Dupont teflon "non-stick dry-film lubricant"
    This is what I use to lubricate all cables..speedo, shifter, etc. Anytime a cable is housed in a casing. Undo both ends if still in the car, and drip feed it till it runs out the lower end. It's a microscopic teflon powder suspended in alcohol (after you shake it up). The alcohol evaporates quickly leaving the teflon coating behind. It should last much longer than traditional lubricants.
    downside...trying to find it!! Lowe's carried it until about a year ago..6-8bucks a 4 oz. bottle. I'm finding it listed by motorcycle shops on ebay 22-26 for same thing.
    http://www.ebay.com/itm/DuPont-Tefl...736765?hash=item234e40fafd:g:EEUAAOSwI-BWFy0Q
    It is available in an aerosol, not sure how that would work for drip feeding a cable.
  14. bobss396
    bobss396
    Nice to find an alternative that uses the new technology. With an aerosol, try fitting a wand to the nozzle.
  15. 55Brodie
    55Brodie
  16. 56longroof
    56longroof
    Is this what you were looking for?
  17. 55Brodie
    55Brodie
    Couldn't see for looking. Thanks Longroof.
  18. 56longroof
    56longroof
    LOL. I have that problem alot.
  19. flattie38
    flattie38
    from Taylor, Mi
    There is a little hole right on top of the cable housing which oils the base where the needle moves up and down. I don't know if anyone mentioned that but mine used to bounce and made a grinding noise when it was a bit chilly but, it would quiet down once the temp rose. You have to look hard to see it I put in WD-40 or 3-in-1 oil. you can't see it from the bottom you have to remove the whole speedometer housing.
