Technical Fuel tank sight glass ideas.
Discussion in 'The Hokey Ass Message Board' started by 31Vicky with a hemi, Nov 24, 2015.
  1. Looking for something cool,
    Visually old appearing
    With a valve, that can handle today's gas.
    Cool but too big
    Garden hose knob ****s
  2. Texas Webb
    Texas Webb
    Neat idea,better than the old stick.
  3. harpo1313
    harpo1313
    from wareham,ma
    ya ,the knob ****s ,but a sm vintage chrome bathroom faucet with the white porceline center market fuel is a thought.
  4. rusty rocket
    rusty rocket
    Do you have a farm, implement salvage yard around. Seems to me that ive seen site gl***es on stuff like that.
  5. squirrel
  6. squirrel
    Really?
    Should be interesting to see how this all fits on the car
  7. We used sight tubes on homebuilt / experimental aircraft years ago, they probably still do. Of course that was where the fuel tank was right behind the instrument panel.
  8. 55willys
    55willys
  9. inthweedz
    inthweedz
    Check out the "boy racer" catch can/surge tank sight gl*** setup, don't have a tap, but very compact.. I think the sight tube is about 5/16'' outside diameter.. 366738546.jpg
  10. 55Brodie
    55Brodie
  11. clem
    clem
  12. gnichols
    gnichols
    from Tampa, FL
  13. I got this... It's a direct acting gauge from a military Cessna Birddog. Set into a tank from a Fordson E27N
    deadbeat, clem, tb33anda3rd and 3 others like this.
  14. DDDenny
    Holy ****oli, that's the coolest thing I've seen come down the pike in ages.
    Vicky, when I saw your thread; these old gl*** bowls came to mind immediately cuz you wanted something with age and character.
    I just couldn't figger out how to incorporate one into a sight gauge.
    Who says creativity is dead.
  15. DDDenny
    Clem, did you put this together? Bravo if you did.
    I don't do the "like" ****on thing.......but I can change.
    This is right up there with those cool repro. Halibrand gas caps that one of our fellow Hambers' is making.
    That would be a candidate for tech week. (Next year).
  16. KoolKat-57
    KoolKat-57
    from Dublin, OH
    The sight gl*** may look cool, but the thought of a tube of gl*** filled with gasoline some where on a car could spell disaster and FIRE!
    Just my opinion, but I tend to see the gl*** as half empty sometimes.
    KK
  17. clem
    clem
    Not mine!
    I was in a hurry yesterday so just posted the pic.
    I think that it was posted here on the HAMB. Whole car was great. Will try to find out.[/QUOTE]
  18. rottenpop
    rottenpop
  19. clem
    clem
    ^^^^^^Thanks
  20. GTS225
    GTS225
    I would love to see a detailed build of Nutrocker's fuel gauge, if that's at all possible.
    Roger
  21. tb33anda3rd
    tb33anda3rd
  22. 55willys
    55willys
    If it broke you wouldn't be a gl*** half empty kind of a guy because it would be all the way empty. In all seriousness gl*** sediment bowls have been around a long time and work quite well. The only time I saw one break was when it was dropped on a concrete floor. The sight gl*** tube is most likely made out of pyrex and that is quite tough stuff.
  23. BamaMav
    BamaMav
    from Berry, AL
    Holley even had some carbs with gl*** bowls.....
  24. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Gl*** sediment bowl are quite thick, and the bowl shape is inherently strong.
    A gl*** sight tube as used on steam boilers as pictured on the original post are not nearly as strong as a sediment bowl, and are quite easily broken if struck by something, I know because I broke the one on the steam boiler in our 1st homes ba*****t.
    I am glad the valves still worked and I was able to stem the tide of boiling hot water!
    I have seen the cheap tubular gl*** fuel filters break and start an engine compartment fire. The end result was a totaled OT Mustang!
    Gl*** and gas are just not a good combination.
    KK
  25. dos zetas
    dos zetas
    As was suggested above, airplanes still use those. I know Aircraft Spruce sold them a few years ago, and other suppliers do also.
  26. GTS225
    GTS225
    ********************************************************************************8
    Thanks TB33. Saw those, went through the entire thread. Incredible build, and a damn handsome rod. I was hoping for a little peek of what 's underneath the bowl. I can't imagine a vertical, straight-line float and linkage, with the short throw of the arrow pointer.
    Roger
  27. 55Brodie
    55Brodie
    Even if the sediment bowl was to break, I doubt you would see leaking gas. No worse than a vented cap anyway.
    clem likes this.
