Here is an idea for helping with the constant issue of never enough accessible storage. I make the boxes out of s**** lumber and small swiveling caster wheels. This one is has 1x12 base with 1x6 sides. The wheels are actually pretty good quality hard rubber for a buck each from China Freight. A 1.5" hole saw and jig saw makes the handle. Par***ion the box to suit your needs. No matter how heavy, the boxes will now easily move under your bench or other out of the way areas. For anyone struggling with a one car garage shop, you can now store parts, etc. right under the car !
I have found that filing cabinets from the local house junk shop are great for toolboxes or parts storage. The nice thing is that they can usually be had for cheap or free. Naturally I have several. My major problem with them is trying to alphabetize the contents.
Here is a photo of one of the boxes with lid to keep contents reasonably clean. A few mothballs inside will make it safe for electrical stuff that mice favor. Again, its s**** plywood, extra door hinge, and leftover key ring for grab handle. The grid on the top mimics the par***ions in the box so you can tell the contents at a glance. I like HVAC tape, it sticks to anything and won't degrade like fabric duct tape. The peel and stick labels will then stick to the tape and can be changed as needed.
