Technical Questions about Mallory YC Pertronix Conversion
Discussion in 'The Hokey Ass Message Board' started by Saxman, Nov 16, 2014.
  1. Saxman
    Saxman
    I've got a really clean and tight 4-lobe Mallory YC Double-Life distributor with a nice flat top two-piece cap. I've always been a traditional "points" guy but I'm thinking about doing a Pertronix conversion on it.
    My question is what ignition wires should I run on this? It seems that most folks recommend running solid core copper wires with the flat top cap but it sounds like you can't run solid core copper wires with the Pertronix. What are you guys doing in this situation? Also, I see that Pertronix recommends one of their coils (45001,45011,45111). What are the differences between these coils?
  2. Dean Lowe
    Dean Lowe
    I just went through the Pertronix/plug wire deal. I converted my Mallory with a Pertronix Ignitor III. I had been running Accel copper wires. It ran great, for a short time. Then it started dropping cylinders. At that point, like all good hot rodders, I then went back and read ALL the instructions and learned that the Pertronix unit needs the resistance of carbon core wires. I switched the wires, and, bingo, it runs better than ever, starts instantly, and, since I had to set the idle down about 200 RPM's, I'm thinking the engine is burning more of the fuel charge. I am also using the recommended Pertronix coil. It is important to have the coil matched to the module's requirements. I changed to a point less ignition because the blower is so close to the firewall it has to be removed for ignition servicing. The Ignitor III has solved all the problems earlier units had. I have always been a "points guy" too, but the maintenance free excellent performance has sold me.
    UNSHINED 2, Fordors and beatnik like this.
  3. HOTRODPRIMER
    HOTRODPRIMER
    I'm running the Taylor wires on both my Deuce pickup and the Ranch wagon.
    The Pertronix conversion has worked great for me. HRP
  4. Saxman
    Saxman
    Hey Dean and Danny, thanks for the info.
    Danny- Are the Taylors carbon core or spiral wound?
  5. HOTRODPRIMER
    HOTRODPRIMER
  6. Jimmy2car
    Jimmy2car
    from No. Cal
    Are you planning on running 2 Pertronix units with that 4 lobe rotor?
    Seems like a cool idea, if you could get it setup on a distributor machine
  7. Saxman
    Saxman
    Sorry, I should have been more clear. I was wondering specifically about the ones you are running. It sounds like you are happy with them. What kind of distributor are you running? I guess my concern is that I had heard that the carbon core wires might not work well with the old Mallory flat-top, two-piece caps.
  8. Saxman
    Saxman
    It doesn't look like they have an Igniter III kit for my application, only the Igniter II. Are you running the flat-top cap on your Mallory?
  9. Saxman
    Saxman
    Pertronix makes a kit specifically for the 4-lobe rotor in the Mallory YC.
  10. HOTRODPRIMER
    HOTRODPRIMER
  11. Saxman
    Saxman
    Okay, thanks. The old Mallory flat-top cap only takes 7mm wires. I know Taylor makes good stuff but could only find 8mm and above on their site. I believe Pertronix actually makes an all black 7mm wire set. I may have to look at that. I just need to figure out whether I can run them with this style cap. I sent a PM to Jim Linder (GMC Bubba), he may know something about this. Thanks Danny.
  12. I just talked to a Pertronix tech Thursday about this same conversion. I have reproduction solid core Packard 440 wires and want to keep them. The guy said he would only try it on a Igniter I. A II would need better wires. And the plain black 7mm wires they sell would work. Also they would like to see their coil. But I could use the Mallory if it had no more than 1.5 ohms of resistance. I have never seen a III listed for the flat cap Mallory so I didn't ask about that.
  13. Dean Lowe
    Dean Lowe
    I'm running a Mallory YL. It's not a flat cap.
  14. fordrule
    fordrule
    sorry about bumping an older thread I am going to be running a mallory YC-449-HP. I also have the marine 2 piece cap. I was curious about the wires and the petronix setup that you are running.
  15. fordrule
    fordrule
    anyone with some information. I am looking at boosting the 260 that I have and want to try and use this distrubitor. I was able to get a MSD 6462 boost ignition module box and not I am looking at the petronix really hard or just s**** it and go with a newer style dizzy. any help will be much appreciated
  16. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    My Wizard says to run Pertronix wires if you can. I have them on my Falcon and my Roadster, Both running Mallory dizzys with Pertronixs conversions.
  17. fordrule
    fordrule
  18. Boden
    Boden
    What kit are you using? I love the look of the Mallory two piece cap distributors and would love electronic ignition inside. If you could give me the part # or model that would be great!
    plymouth1951 likes this.
  19. Saxman
    Saxman
    I never did buy that Pertronix but I did a quick search And it looks like the number for the YC four-lobe is 9ML-187A. I’d do a search on that number just to make sure or give Pertronix a call. I’m pretty sure that’s the one though.
    Boden likes this.
