Technical '61 Ford Wagon Weird VIN Codes
Discussion in 'The Hokey Ass Message Board' started by Single Fin, Dec 1, 2015.
  1. Single Fin
    Single Fin
    Hey gentlemen, I'm looking at a '61 Ford Wagon (Galaxie) in a wrecking yard in Washington. The VIN plate has odd codes I can't find. The Trans code is R and the Axle code is 0. Any ideas???
  2. Johnnee D.
    Johnnee D.
    Canadian car?
  3. Those don't correspond to any standard Ford identifiers; maybe this was a special order/fleet car. Some government agencies bought some strange cars, I'd look at the plant/DSO info to see if this was a special. Does the rest of the data plate agree with what you see?
  4. 54monarch
    54monarch
    from Calgary
    It would say Ford Motor company of Canada on the top of the Vin tag.
  5. Single Fin
    Single Fin
    That was my first thought too so I checked. It's a US wagon...
    Everything else matches fine. I had someone else come out and look too. Same answer without being prompted.
  6. low budget
    low budget
    from Central Ky
    Heres a favorite of mine, 61 wag, not actually mine but I sure do like it.
  7. Single Fin
    Single Fin
  8. Single Fin
    Single Fin
  9. I'm ***uming the OEM motor/trans is gone.. is the rear axle still in it? Make sure it's a 9" and check the ratio, Ford did have a few other ratios generally not available in cars, and did offer a 'heavy duty' rear axle as an option (very rare; I've seen one...) with a Dana centersection.
  10. Single Fin
    Single Fin
  11. Single Fin
    Single Fin
    I'll go back Thursday and look. I'm close to finishing my '60 Sunliner and want to do a wagon. If it does have special options I'd find it more interesting to restore...
    I need to see what that R code is for the transmission means... LOL
  12. Jalopy Joker
    Jalopy Joker
  13. bobss396
    bobss396
    Type out the whole code and I'll look at it. Is the vin plate (driver's door jamb) original?
  14. Single Fin
    Single Fin
  15. Single Fin
    Single Fin
    Yes @bobss396 its the original plate. I'm tied up at work and will go get all the data Thursday and send it to you. I appreciate the help.
  16. spooler41
    spooler41
    FIN, the vin#'s you are looking for were not used until 1968. Prior to '68 vin# were
    nothing more than company S/N and identifiers. 1968 the government mandated that
    manufactures use ,the now universal "Vehicle Identification Number".
    .............................. Jack
