Projects Jade's '30 Sedan build
Discussion in 'Traditional Hot Rods' started by Jade, Aug 21, 2014.
  1. NashRodMan
    NashRodMan
    WOW! You know how to use the machines, cut metal and weld!! That's awesome! Nice work.
    volvobrynk and Jade like this.
  2. Jade
    Jade
    Thanks!
  3. Jade
    Jade
    With the top shock mounts made, i was ready to order a set of lowers from Speedway, but I was too cheap, so I made these from some 2x2 tubing today. Gotta stop at the hardware store, and get some 1/2" Grade 8 hardware, and get my shocks mounted.
    volvobrynk likes this.
  4. Jade
    Jade
    Got the upper, and lower shock mounts installed. I think it turned out really well. I've got 5" of ride height adjustment on the lower mount, and 0-45 deg of laydown adjustment on the upper mount. Should be able to really dial in the ride.
    I also got the panhard bar welded in place. Aside from finishing up a few weld beads, the rear suspension is pretty much complete at this point. YAY! 11351412_10204322021952650_1164825434_o.jpg
  5. Jade
    Jade
    Alright! It's a rolling ch***is again! The new rear axle has a 5x5 bolt pattern, which meant my spoke wheels wouldnt fit anymore..... bummer. I ordered some WV smoothies from Summit, and they showed up today. Got the Firestones mounted, and bolted on just for mock up purposes. Still need to paint em black. Measurement inbetween the tires shows that I'll have just about an inch, and a half on each side between the body, and the tires. Perfect! I wish I could say I planned it that way, but it just worked out with the axle I bought. If I used wheel adapters, and kept the spokes, I'd have about 5 inches on each side body to tire.
    So now my dilemma is, do I keep the spokes up front, or buy another pair of smoothies to match the rears? I suppose I'll get em painted, and then put the body back on, before I make my decision.
    Still have to get the front frame rails boxed. Gonna try to get that done this week. 11535399_10204374231857865_1814984248_o.jpg
  6. Jade
    Jade
    11639798_10204374220097571_1717930766_o.jpg I finally scored a T5... $200 with the shifter, and driveshaft out of a Camaro. Since the seats will be pushed back, the rearward shifter position should work great. It's awful grungy, but I think it'll clean up just fine. Got the adapter on it's way from Speedway... This is the piece i needed so I can get my engine mocked up, and my mounts designed, and made, not to mention, I'll get to see just how much work I'll need to do to the firewall. Man I'm excited!
  7. Jade
    Jade
    I feel like i'm slacking here. Still havn't gotten my front frame rails boxed :(. BUT, I did get that grungy T5 cleaned up a bit, got the adapter bolted up, and set the combo down into the frame rails... Just sitting on jack stands at the moment. I need to decide EXACTLY where the motor mounts need to be before I go much futher. The location front to back I'm not too worried about. Looks pretty cut, and dried, but the height... that's another story. If I leave it too low, I'll risk dragging the pavement, and If I raise it too high, I'll be taking up valuable footwell pedal space.
    Any advice is welcome!
  8. Jade
    Jade
  9. Kensey
    Kensey
    from Pittsburgh
    So killer man, love the flathead!!! You really do nice work. Little sad the flames are gone. Can't wait to see the body back on the frame.
    Jade and volvobrynk like this.
  10. Jade
    Jade
    Thanks for the kind works Kensey. Yeah, obviously, the chop necessitates a complete paint job, so I rattle canned that door black, just to help me visualize what a blank canvas would look like, and where I want to take it.
    I'm with you... I CANNOT wait to get the body back on the frame, just to see how it's gonna sit. It of course will all have to come back apart, so I can paint everything, but I'm really hoping to have the body mocked up sometime next week. You know I'll take pictures!
  11. Jade
    Jade
    11656055_10204423016677455_475822343_o.jpg Motor back out. Boxing plates in! 3/16 .... it was free from the drop bin at work!
    It's getting serious now... Now I have to make some very important decisions about where my motor mounts go. I suppose I'll just tack em in place, and see how everything fits.
    If you have advice about placement, NOW is the time to speak up. I'm all ears.
    Got my implements of destruction ready to hack the firewall. I'll be setting the body back down this weekend!
  12. Mechman_22
    Mechman_22
    from Nc
    looking good man keep knocking stuff out and you'll be driving in no time and not having to sit in
    the cab with a beer making engine sounds pretending to drive like I do lol
    Jade likes this.
  13. Looks good. Like the idea on mounting the upper end of those coil overs.
    You going to swap out those tail lights?
  14. Jade
    Jade
    Thanks man!
    What, you don't like my taillights?? LOL No offense to whoever put those on there, but they are the one Hideous part about the car. Absolutely horrible looking. Of course it's easy to say so AFTER they've been mounted. Before hand though I might have thought it was a cool idea too. Just didn't work out.
    So yeah, I'll be filling the holes, and going with something different. Not sure what yet.
  15. Kensey
    Kensey
    from Pittsburgh
    I honestly think that whoever had the creative mind to go with those taillights single-handedly revolutionized traditional hot rodding as we know it today! Not to mention the added 75 horsepower per light! That's a lot of extra zip for the little banger that was in it. I for one would like to thank said BAD *** for paving the way for the rest of us to do burnouts in the name of hot rods, koolness and FREEDOM! Thank you Sir!
  16. Jade
    Jade
    Kensey, I think I'm starting to agree with you! That guy IS a Bad***! From the looks of the holes he made for the lights, he cut them with his teeth! Just chomped right through the sheet metal. It was either that, or he cut em with a rusty s****! LOL. Good Stuff!! Thanks for the laugh first thing in the morning.... The taillights are still getting 86'd though LOL!
  17. Jade
    Jade
    Nothing is bolted down. The body, and engine, are just sitting in place while I take measurements, and decide what needs cut, and where, and how much.
    After an afternoon of deliberation, I've decided that the car needs channeled. A plan is in place. We'll see how it turns out in the next few days. 11255291_10204445501559563_1851128019_o.jpg 11660070_10204445501759568_1743659554_o.jpg
    waxhead likes this.
  18. rlsanford
    rlsanford
    WTF....... get to work..... unless you want to trade for an s10...... purple with tunnel ram and the top cut off.......
  19. Jade
    Jade
    DEAL!!!!
  20. aerocolor
    aerocolor
    from dayton
    Do we need to have a garage night to get you rolling again?
    We know you can do it!
    Watching and waiting...:)
  21. gecko54
    gecko54
    from Sumner, WA
    Quick question, that rear ladder bar set up looks stiff as for articulation. Front mounts don't look like they can pivot. Did it cycle OK? Looks cool, like that your making all your own stuff but it needs to ride good or you will hate driving it.
    Just asking.
  22. Mechman_22
    Mechman_22
    from Nc
  23. chop job
    chop job
    from Wisconsin
    What happened such such a nice build. lets see more please!!!
    CornfieldPerformance likes this.
  24. ewf
    ewf
    from fl
    Nice project. Is that a 4" or 5" drop axle?
  25. Jade
    Jade
    6" drop.
    Got sidetracked for a few months, but I'm back on it. Spent a few hours today just finishing up some welding that needed done. I also realize that since I'm channeling the body, my homeade ladder bars will need to be re designed. As it is, they would end up hitting me in the *** everytime I went over a bump.... gotta make em a little skinnier up towards the front.
  26. Mechman_22
    Mechman_22
    from Nc
    glad to see your back cant wait for some pics!!!
  27. Jade
    Jade
    Excuses, Excuses... Here in Ohio, the past couple weeks have been opressively hot. I just don't go out in the garage when it's 90. Last few days though, have been really nice. Didn't take too many pictures, but I did get some detail work done on the Chop... I did the pie cuts on the pillars so they all match up nice now. Also did some more welding on the frame boxing plates... man... talk about going through some wire! Also finally tore the headliner out... and 2 good sized mouse nests! And removed the firewall... man, what a pain in the ***. Lots of spot welds, and rivets! Think I'm gonna keep the original tank. It's in good shape, and I like living dangerously.
    Next up, I need to mount the engine, and fab, or buy a new firewall with a recess for the engine/******. Here's a couple pics from today...
    Mouse Houses!
    Firewall gone!
  28. Jade
    Jade
    And here it is channeled! Still a lot of work to do, but this is how it's going to sit. The body is just even with the bottom of the rails. 6" off the pavement at the moment. Once the engine goes back in... it drops a little more.
    Aaron D. likes this.
  29. Shadow Creek
    Shadow Creek
    My personal opinion - car sits great!
  30. Just Gary
    Just Gary
    You do great fab work!
    The car looks good so far, but you'll need to both lower & section the grille shell to keep it below the cowl & beltline. Otherwise the car will look really awkward.
