Projects 1934 Ford PU Build
Discussion in 'Traditional Hot Rods' started by Jeff34, Jul 27, 2015.
  1. Jeff34
    Jeff34
  2. alchemy
    alchemy
    You'll need longer perches with that kit as well.
  3. Jeff34
    Jeff34
    Happy Thanksgiving all! Working on the truck this weekend, and have a couple of questions:
    - Tried to remove rear hubs, but they are stuck good. Hammered the **** out of the puller, but they still won't pop loose. Suggestions? Heat? Bigger hammer?
    - Is there an easy way to get the bed off the frame? Looks like rear fenders first, then bed?
    - Are the leaf springs in a "neutral" state when unloaded (truck jacked up by frame) or will they jump to a neutral position when I take out the shackle bolts? Worried it might be difficult to get them back on.
    First, I need to drive down about 30 miles to the next city to get a Christmas tree. See how it feels on the freeway.
    Cheers!
  4. jerseyboy
    jerseyboy
    Jeff34 likes this.
  5. Jeff34
    Jeff34
    Great info. Thanks!
  6. Hitchhiker
    Hitchhiker
    Couple things.
    1. Great truck and I love the direction you are taking it.
    2. the autopulse is a 2 psi max, so would probably be fine with no regulator. They are very noisy. If you want to sell it, I am looking for a spare for my rig. so keep me in mind.
    3. A good way to loosen the hubs off the axle when the puller doesn't work is to loosen the axle nut a little bit and drive around the block. I've had to do this on a model A before. I have the K.R. Wilson puller as well and it wouldn't budge it.
    Jeff34 and kidcampbell71 like this.
  7. Jeff34
    Jeff34
    @jerseyboy
    Great information, thank you. I really like that method. Looks nice and "controlled"
    @Hitchhiker
    Glad you like the direction. I'm movin' slow, but I'm movin. I'm following a few others here and trying to "repair" rather than "restore". I've been holding off on the "drive around the block" method. I had heard from a couple of others that it could really F-up the keys or key slots...
  8. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Amazing truck! Man its cool to see it getting shined up- thats my favorite part. :)
  9. Jeff34
    Jeff34
    Thanks, Tuck. It's fun, and even a bit challenging. If I push it too far on the pinstripes they run right off. Re-striping wouldn't be as cool as saving them to me.
  10. Hitchhiker
    Hitchhiker
    I think it will be fine. I would not be worried if it was mine. I would,be more scared of screwing up the axle threads when you the puller. It's worked for me with no damage on multiple occasion. Don't got hot rodding it. Go slow. It the turning that does it. Pops them right off. You'll hear it. I barely made it out of the driveway.
    Jeff34 likes this.
  11. Jeff34
    Jeff34
    Ran with the hood today. Needed some lumber for a project and it was raining. My air cleaner is still not ***embled, so I just put on the hood. With no wiper or lights, I just used a towel to dry the windshield whenever I stopped. The narrow bias plys make the drive fun!
    ImageUploadedByH.A.M.B.1449447808.822194.jpg ImageUploadedByH.A.M.B.1449447830.234384.jpg ImageUploadedByH.A.M.B.1449447854.627839.jpg
  12. Jeff34
    Jeff34
  13. Jeff34
    Jeff34
  14. Using a truck as a truck, perfect!
    Bet it drew some looks at the lumber yard.
  15. jerseyboy
    jerseyboy
    Jeff,
    Sounds fun! Try some Rainx on the windshield, helps repel the rain. Truck looks good:cool:
  16. dumprat
    dumprat
    from b.c.
    Did ya get any farther with any of your engine mods? Heads cam etc?
  17. Jeff34
    Jeff34
    I'm still working on pulling together the parts I want. The heads turned out to need too much work, so I'm back in the hunt for heads as well. My signature shows the big bits I need. I also need to figure out exhaust (I have a couple of ideas) and shocks (keep going back and forth between tube and lever)
    BUT, I've got a remodel going on a small room of the house that's going to take most of my time through the holidays, so I think the truck will have to wait to get any real work done. I'll still be looking for parts to do the work, just holding off on the work itself.
  18. dumprat
    dumprat
    from b.c.
    There was a nice early Thickstun popped up in the cl***ified the other day....just saying.
  19. Jeff34
    Jeff34
    I saw that one. I asked him some questions about it. Not sure my generator would fit in the stock location without bumping into the front Strom.
  20. Jeff34
    Jeff34
  21. Bader2
    Bader2
    Bw over drives are 30 percent,so 2.78 x.30 or whatever original ratio you have.
  22. alchemy
    alchemy
    That's an earlier '32 unit with the unsupported pinion. It will work, but it won't be as strong as your '34 unit.
    The length of the torquetube will be too short on the '32 unit. You will need to lengthen the TT. The wishbones are also unique to the early '32 and will need to be obtained if they don't come with that ebay rearend.
    But, the width of the unit and the rear spring are the same as your '34.
  23. Jeff34
    Jeff34
    Thanks bader and alchemy! May need to reconsider
  24. More inspiration. I kept mine stock-appearing, with a much hopped up later flathead under the hood.
  25. Bader2
    Bader2
    I've got three of those odrives in a torque tube,paid 700$ each,that's a lot of money for what's there.
  26. Jeff34
    Jeff34
    My plan as well. Can we get a peek at the hopped up bits?
  27. I will try and post a pic today. We got a little snow last night, but it ought to be gone by later in the day.
    But as a teaser, the block is a 59A, dual Strombergs on a Sharp manifold, Fenton headers, 4" Merc crank, adjustable lifters, Howard cam, and a crab-style distributor. Very little chrome, and shaved stock heads with some port and polishing work instead of the shiny new aluminum heads often seen on hop up builds.
    We wanted the motor to appear more "industrial" than have much bling on it, thinking "It is better to be discovered than announced." Too many motors (and cars) these days look like cliches, as if the owner went through the Speedway catalog and picked one of every possible dress up piece they could find. No thanks
    I'll post a pic. Promise.
    kidcampbell71 likes this.
  28. NashRodMan
    NashRodMan
    Jeff,
    I haven't seen this thread since you first posted it. I have to say the truck looks awesome!! And the video of you driving it down the road...cool! What's the top speed for it? Can you go 65?
    Paul
    Jeff34 likes this.
  29. Also waiting for pics...
    I am on the same path, except using a pre 48 Edelbrock regular dual intake with the 97`s, a L100 cam and an original 32 generator mounted fan. No plans to shine up the outside of the pickup and going out of my way to use original parts.
  30. Jeff34
    Jeff34
    Nice! I'm still trying to find pre-50 parts for my engine. I'm staying with 6V pos ground. Generator in stock location. Interesting idea on using iron heads...might have to consider. Looking forward to the pics for inspiration.
    Thanks, Paul! Per my iPhone speed app, I have reached speeds up to 50mph. I don't have a tach yet, but once I do, I'll be able to see how fast I'm running and can see if I can push a bit more. I'm considering a Mitchell OD unit for easier freeway driving.
    I don't think I've seen your pickup, have you posted it?
