Hello my speedometer in my 55 ford customline started makeing a racket and jumping around yesterday. could some one tell me what might be wrong i have the 302 with a c4 ****** i have the right gear and cable because it was working .
I would start with looking to see if the cable is kinked or has a bind anywhere. Then I would disconnect it at the speedometer and pull the cable out and clean, re-lube it and re-install.
If there is no kink you might detach it at the Speedometer head and spray some WD-40 down the cable housing I have had that work several times in the past.
Graphite is still the best thing to use on the actual speedo cable itself. WD may be good at the speedometer head, used sparingly.
i think i fixed it i took the cable out and sprayed wd40 all over it and put some axle greese on the end that goes in the speedometer. works like a charm
I've used lithium grease in my speedo cable. WD-40 is not a lubricant and won't last long. Graphite is also good.
Dupont teflon "non-stick dry-film lubricant" This is what I use to lubricate all cables..speedo, shifter, etc. Anytime a cable is housed in a casing. Undo both ends if still in the car, and drip feed it till it runs out the lower end. It's a microscopic teflon powder suspended in alcohol (after you shake it up). The alcohol evaporates quickly leaving the teflon coating behind. It should last much longer than traditional lubricants. downside...trying to find it!! Lowe's carried it until about a year ago..6-8bucks a 4 oz. bottle. I'm finding it listed by motorcycle shops on ebay 22-26 for same thing. http://www.ebay.com/itm/DuPont-Tefl...736765?hash=item234e40fafd:g:EEUAAOSwI-BWFy0Q It is available in an aerosol, not sure how that would work for drip feeding a cable.
Nice to find an alternative that uses the new technology. With an aerosol, try fitting a wand to the nozzle.
http://www.amazon.com/Motion-Pro-08-0182-Cable-Lubber/dp/B0012TYX9W I use this on my choke and air vent cables...works like a top and could probably be pressed into service for speed o cable use. BTW, it would be nice if the OP reported back with his results.
There is a little hole right on top of the cable housing which oils the base where the needle moves up and down. I don't know if anyone mentioned that but mine used to bounce and made a grinding noise when it was a bit chilly but, it would quiet down once the temp rose. You have to look hard to see it I put in WD-40 or 3-in-1 oil. you can't see it from the bottom you have to remove the whole speedometer housing.
