Projects SOUTHEAST GASSERS "BRAND X" BUILD
Discussion in 'Traditional Hot Rods' started by HEMIBERT, Oct 12, 2015.
  1. I still favor "Hemi Under Gl***" of course it was not a "G***er" just one bad to the bone Barracuda.
    Built right a Barracuda could be one fast stripper. A 413 max wedge would be as sweet as it gets under that hood.
  2. Quain Stott
    Quain Stott
    I have a corvair box on my willys and have put them on several other cars with no problem. you will have to reverse it or buy it already reversed. What causes problem with the box is builders not adding a steering stabilizer. With out the stabilizer you could get death wobble and that will kill any box over time.
  3. MOPAR used that same basic box through the muscle car era. They resemble the moon box that was used back then too. you don't have to reverse them to run them with a drag link and they make an excellent hot rod box. They make two different length pitman arms for them the long one works well on an old hot rod.
    AHotRod likes this.
  4. So do you sell the stabilizer as a kit if so how much and how do you get one.
  5. HEMIBERT
    HEMIBERT
    Like the porkn****** said, just about all Mopars had the same manual box. All aluminum and will take all you can give it. No need to reverse it, just turn it on its side. Cross steer wouldn't work on mine either. I'll run a stabilizer on mine too. It's a common stabilizer available at just about all parts stores. Fits a VW. P/N is SSD 58 from Autozone.
    My box is the one that came on the car. Modified/made my own pitman arm. You at least need to use the end that has the splines. Rod ends on the drag link. I believe the steering arm is for a 48 Ford, from Speedway.
  6. Quain Stott
    Quain Stott
    SSd 58 from auto zone or any place that sales suspension products. I cut the bent end off and plug welded a 3/8 female rod end in place.
    AHotRod and Chucky like this.
  7. Hey Guys, Thank You, for the information will check into the stabiizer at the local Zone.
  8. catdad49
    catdad49
    Morning Guys, love this site because of all the info available & that everyone is willing to share it, sometimes complete with part #s! Sure beats going to the parts store(best to have # with you)! All I need now is a site that deals with knee replacement rehab, this **** is HARD. Tuned in, Carp
    colbyw and loudbang like this.
  9. HEMIBERT
    HEMIBERT
    YES. Well.........
  10. HEMIBERT
    HEMIBERT
    Been working on Cuda for 2 months now. I'll post a then and now pic tomorrow. Started on my birthday, Oct 10. Today is our boys birthday, Dec 12. He's following the build and since we won't see him til after Christmas--Happy Birthday Robbie!
  11. HEMIBERT
    HEMIBERT
    OK. After 2 months work , this is what we have. BEFORE1.JPG BEFORE2.JPG AFTER3.JPG AFTER6.JPG AFTER9.JPG
  12. Quain Stott
    Quain Stott
    I'm so impressed, everything is like it should be even the wheelie bars.
  13. AmishMike
    AmishMike
    Great build, love the concept of southern g***ers and your car. Hope the ******& clutches hold up. Leave the faded color and dents for the first year - an oldy g***er for sure.
    lawman likes this.
  14. D.N.D.
    D.N.D.
    Nope paint her up nice and shinny like race car should be , with some turned leaf lettering for the icing on the cake
    You would never take a new first cl*** g***er to the strip in primer back in my day ' no way ' as it was not done till it had some color on it, then it was time to race it and be very proud of you have built
    Leave the non- finished paint stuff to the rat rod bunch
    DND
  15. HEMIBERT
    HEMIBERT
    I haven't put as much thought as I should into a paint job yet. That makes or breaks the project. They also are very expensive. The color, scheme and name have to complement the body style. Any suggestions? Anybody?
  16. D.N.D.
    D.N.D.
    You could do what I did on my 37' as I did all the prep work block sanding the primer, then pay a guy or shop to lay on the color & clear coat and then you do the color sanding and rubbing it out
    You can save a lot that way by doing most of the work yourself, and let a pro spray it then use some of that saved money for a nice quality lettering job
    All the steps for todays paints are easy to get then do your home work, and make a game plan of what to do so you don't have any hiccups along the way
    Get a scratch pad and start making up some different designs to see what lights your fire
    BTW with that ridge that goes front to back along the top of the fenders & door that is a great spot to meet two colors , and go nice with the body shape & design
    DND
  17. rt1976
    rt1976
    from indy
    What material did you use for bottom flat plate on the wheelie bars?
  18. HEMIBERT
    HEMIBERT
    I used 2" x 3/16" 6061 T6 aluminum
    rt1976 likes this.
  19. HEMIBERT
    HEMIBERT
    Yeah....I have a friend who does excellent work. He always says "You paint it, bring it to me and I'll fix it." He has "fixed" all my "good" cars, but it extremely busy.
  20. Dog_Patch
    Dog_Patch
    Man this thing is looking cool!
  21. II FUNNY
    II FUNNY
    Mine will see track time before its painted...kind of like sea trials for battle ships.
    lawman likes this.
  22. D.N.D.
    D.N.D.
    My 37' was just like you see it the first time out, so I could put all my attention to racing it since B/Gas was a tough cl*** to win with a lot of heavy hitters at each strip
    Plus that way of having the car all done, I could take it to the big shows each year out here in L.A.
  23. HEMIBERT
    HEMIBERT
    This is most likely what I'll do. Depends on when and where I can get some hits on it.
  24. What is your favorite color? Lighter colors, at least on the roof will keep you from roasting inside, sitting in the staging lanes etc. Red, or any color using red tints tend to be physically heavier because of the iron content in red toner to create the red color. My experience for this, goes back to the mid 80's, so they may not even use iron in red tones anymore. I'll throw a list of names at you, after I've had my thinking cap on awhile, first one that came to me was "Cuda Skoota" . If you put the engine size on the fender, could go with "383 Wedgamacallit" Deciding on the color, could influence the name too, looking at the color now, reminds me of a favorite drink, "Orange Bang" or "Orange Whip". Are you partners with anyone on the car, lots of cool old g***ers just had the last name of the guys involved "Stone Woods & Cook".
  25. glrbird
    glrbird
    White top, blue above the belt line, red sides. Use base coats, letter it, then clear everything.
    Names: Tennessee Terror
    Cl***ical Gas
    Terminator
    Cave Man
    What ever you do it will look good I'm sure.
    Dog_Patch likes this.
  26. HEMIBERT
    HEMIBERT
    Maybe it's me not keeping up with the times, but back in the day, 2 loops were required. One front and one in the back half of the driveshaft. Maybe someone here knows the answer. I'd like to know for sure. It's been a long time since I p***ed a door car through any kind of tech.
  27. HEMIBERT
    HEMIBERT
  28. Higgy's Henry
    Higgy's Henry
    These cars launch between 8-10000 rpm's, imagine breaking the drive shaft up behind the four speed. Right beside your seat!! I don't think by rule you need two, but it's a heck of a good idea!
    colbyw, OahuEli and Dog_Patch like this.
  29. ROADSTER1927
    ROADSTER1927
    I had a 61 Chevy car in high school and me and a buddy blew the front drive shaft joint doing a burn out of co****. It came forward and busted the shifter off the 4 speed and ****ed my hand that was on the shift knob down through the shift boot. I was not hurt but very surprised to say the least! Gary
    Atwater Mike likes this.
