Projects '27 RPU frame painted and rolled outside fro first time
Discussion in 'Traditional Hot Rods' started by Bondo Slinger, Sep 1, 2014.
  1. dumprat
    dumprat
    from b.c.
    Keeps the spring from twisting. Not rocket science
  2. Pete
    Pete
    Phew... Good thing because in not a rocket scientist..
  3. mike bowling
    mike bowling
    Definitely a "different" approach , but clean and well executed. If people didn't think outside the lines, we'd still be looking at a horse's ***.
    Give it Hell! ---- Dr. Mike , NASA Control
    Thank you!
    It finally stopped raining for a couple minutes so I rolled it out again for some update pics.
    There's been a few changes. The frame horns are gone and you'll notice the rolling stock has been swapped out for 7.50 and 6.00 Firestones on International wheels. The primer is temporary. It will eventually be gloss black.
    Lil'Alb, Okie Pete, Stogy and 7 others like this.
  5. verde742
    verde742
  6. dumprat
    dumprat
    from b.c.
    I love the wavy tube axle and the super low stance
    volvobrynk and Bondo Slinger like this.
  7. bct
    bct
    Love it Ish. Well done and cl***y reaction to the resident aholes here.
    Bondo Slinger likes this.
  8. Thank you. It can be hard to bite your lip sometimes but there's usually no point in getting into an Internet ******* match.
    jebbesen, volvobrynk and bondojunkie like this.
  9. Spud
    Spud
    from Ohio
    Well said.
  10. Mk1ofMnM
    Mk1ofMnM
    Where did the gold wheels go?
  11. ol'stinky
    ol'stinky
    from New Jersey
    Looks really good!
  12. Just sold em off to a fella who's gonna put em on a shoebox. They'll suit a shoe box perfect but I was looking for more of a rubber rake.
  13. Don's Hot Rods
    Don's Hot Rods
    from florida
    I like it. You are getting close to the finish line, keep after it.
    Don
  14. TexasSpeed
    TexasSpeed
    from Texas
    I dig it.. Keep going!
  15. Well I've been awfully busy lately and too mentally exhausted too get anything meaningful done at the end of the day but things are settling a little and I'm ready for one last good push to get this thing running. Here we go!!!
    Sent from my SM-G900W8 using H.A.M.B. mobile app
    Lil'Alb, rab71, Stogy and 5 others like this.
  16. loudbang
    Get it running and you will have plenty of pep and vinegar
  17. I really like the way you have done the windscreen. I need to sort out mine soon - any close up pictures?
    volvobrynk likes this.
  18. Gary Addcox
    Gary Addcox
    Clem, I think you are absolutely correct about the tube axle/4-bar argument. There is SO much difference between a racecar utilizing a tube axle with hairpins on a smooth track vs. a streetdriven rod with like suspension having to handle dips, bumps, uneven and undulating pavement, and otherwise ****ty roads in America. I'll ride with you anytime, mate.
  19. steinauge
    steinauge
    from 1960
    I like it! Really nice work and different too.
  20. Turnaround
    Turnaround
    As long as you just did one, let me ask what all automatic transmissions did you find that can be hooked to the little Dodge hemi like you used, and I have?
  21. Thanks Loudbang, I think you're right!
    Thanks! Any shots in particular you'd like to see? I just made a template with cardboard and took it to the local gl*** shop to have made. It's laminated safety gl*** with a green tint.
    You're right to bring that up however I considered this carefully when building this part of the car. Search the HAMB and you'll see this subject has been beaten to death in the past. For every person that says it can't be done there will be someone saying that they've driven their rod with hairpins/tube axle for 35 years with no issues. I think split bones would be more of an issue than hairpins but then again there are folks who have run V8 60 axles with split bones for decades as well. I'll just run it and keep an eye on it.
    Thank you!
    I didn't do a pile of research. I just bolted up a 904 with a 1/2" spacer. The flex plate came from B&M. Hope that helps!
    volvobrynk and loudbang like this.
  22. Blade58
    Blade58
    from apopka ,Fl
    What is the Body? looks cool and comfortable
  23. trollst
    trollst
    You know, I read this whole post, you're a pretty well informed guy, your workmanship is first rate, I really like your build and will spend time crawling all over it should I see it in person admiring your work. Honest.
    Why have you chosen to ignore scrub? Probably never happen, but should a blowout or flat happen at speed, it will be catastrophic, for you, p***enger, which I bet will be your child, and or another motorist or pedestrian. Not trying to **** you here, honest, cause I really like your car, just wondering, also wondering how you'll get past the mechanical with it being low. Please don't be offended or take this as offensive, just a question, I'd be interested on your take on this issue.
    I just finished my 27, going through the reggie process now, it's pretty easy, by the end of next week I'll be done and have mine on the road, I'll post the method to obtain vin numbers and forms used.
  24. Thanks for the kind words! I'm fine on the scrub line. With the larger diameter wheels and another leaf added we're good. I'll post a pic when it on the ground again.
    And yes please keep us posted on the regi process! Did they give you any grief over the open wheels?
  25. hasty
    hasty
    Looks like a careful and inventive build. It would be great to hear how it rides.
  26. trollst
    trollst
    I've had to build fenders, my guy knows they'll come off, need a front bumper, rear is optional.
    You only need three forms filled out, I'll post them later today, gotta dig them out, a weigh scale slip, and a mechanical. As you may know, the open wheel law is coming, it'll be here sometime this summer. DSC05869.JPG
  27. Blue One
    Blue One
    from Alberta
    Glad to hear that you are able to keep above the scrub line.
    The car should be a lot of fun once you get it on the road.
    Lower than I like but still will be a blast to drive.
    Good to see you putting the exhaust system through the frame. Clearance is better and looks better too.
    As for the fenders thing, I am building cycle fenders for my RPU.
    They will be good looking and I will have the option to run them or not.
    Most of the time it will be not but I can if I like.
    Going to be moving out to the island and want to have the option for fenders even if the open wheel law is p***ed.
    Seems to me that it has been taking an unusual amount of time for that law to be made official.
  28. Great work Ryan. Hope to see it on the road soon.
