Hot Rods Flathead oil smoke right exhaust / help
Discussion in 'The Hokey Ass Message Board' started by guy1unico, Dec 12, 2015.
  1. guy1unico
    guy1unico
    Hello
    I've been battling a oil smoke blow by on the p***enger side exhaust for a good 8 months. It is getting me down.
    here are my motor specs.
    Motor rebuilt totally in 2011 no problems until end of 2014.
    49 - 53 Ford with 3 3/8" bore and Merc crank
    327 chevy distributor
    3 carb intake running only 1 .. 48 Stromberg carb in center
    Plugs are new Champ D 16
    Va*** is steady at 20...checked from the intake
    We listed for any air leaks.... with a rubber hose screwed into a plug hole and compressed air the other hose was in the oil inlet where we listened (No air byp*** sound)
    Compression check
    front
    L R
    100 70
    100 110
    80 100
    110 120
    _____________________________
    miles since rebuilt in 2011
    3,000
    Added 1 quart Marvelous Mystery oil to 4 quarts Valv. VR 150 20 w 50
    _____________________________________________
    Heavy blue smoke occurs every time I gun the motor in neutral, accelerate from a stop sign or enter the highway. The smoke will go away after the initial acceleration.
    _________________________________________________________
    Any ideas of what I can do to totally keep my motor from smoking out of the right side exhaust?
    left side (driver's seems to be fine).
    Thank you,
    Guy
  2. Russco
    Russco
    from Central IL
    You can't tell from reading the plugs which cylinder(s) is burning the oil? The 30+% compression drop on number 1 is significant. I'd use a set of Leakdown Gauges and try to get a better idea than just trying to listen for air leaking for starters. If its showing that much of a loss on a compression check its going somewhere. It should show up on the leak down as well.
    Fedman likes this.
  3. Fedman
    Fedman
    X2!
  4. guy1unico
    guy1unico
    When I put a vac*** gauge on the intake the reading was an excellent 20+ steady.
    On the Barn they suggested I soak #1 in MMO overnight and check in morning...they think it is a valve guide situation.
  5. Russco
    Russco
    from Central IL
    Valve guide won't cause compression loss but it could cause smoke ( it would be on intake valve)
  6. guy1unico
    guy1unico
    Russco
    Is the 70 compression the #1 valve on p***enger side an intake valve?
  7. King ford
    King ford
    from 08302
    The valves, in order are exhaust.intake.int.exh.exh.int.int.exh. But that has no bearing on your situation, I would leak it down and I believe you have a ring or cylnder wall issue, if it leaks down a substantial amount shoot some 30 weight motor oil in that cylnder, crank it over a couple of revolutions and see if the leakage goes down...
    Andamo likes this.
  8. guy1unico
    guy1unico
    Could I possibly draw the line at only replacing the front 2 valve guides or should I do them all...since I have the top end apart?
  9. Andamo
    Andamo
    Do the leak test first like everyone is suggesting and go from those results. You might have a broken ring and be scouring the cylinder wall.
  10. Russco
    Russco
    from Central IL
    Changing the guides out is actually not that of a bad job you already have to have the intake and head off anyway just do all of them, there is no sense in doing just a couple. However back to the original post: The 2 most likely scenarios would be that oil (and compression) are leaking by the piston(s) on the affected cylinders which would be why compression is lower in the #1 cylinder (and #7 too) this could be caused by several things. Broken /stuck rings, galled or scored piston or cylinder wall, damaged piston, ETC.... and Scenario #2: an intake valve guide/seal is allowing oil to leak past the seal/guide and to enter the cylinder while under a vacuum condition when the intake valve is open and the cylinder is filling with fuel and air.. Either way the oil is being burned and causing the smoke. The spark plug from that cylinder should show signs of oil burning /fouling more so than other cleaner burning cylinders. As stated above a leak down test with gauges should give a pretty good idea of what's going on in each cylinder. A bad Guide/Seal will not show up on a leak-down as it has nothing to do with compression unless its somehow causing the intake valve to not seal on the seat.
    BTW I'm not very computer literate, I'm terrible at explaining stuff like this when I have to type it out. I hope this is making sense to you.
  11. guy1unico
    guy1unico
    Thank you Russco
    Note:
    I've been running the VR-150 oil 20W 50 my friend in the Early V8 Club says a newly rebuilt flathead...under (10,000 mi) should be using 30 weight non detergent oil. The synthetic oil causes no wear on the engine therefore they do not seal properly. He suggests driving with the 30 wt. for around 2000 more miles and see if everything begins working properly.
  12. tig master
    tig master
    from up north
    The oil should be 10w30. Non detergent oil what planet is your friend from???
    This is 2015 not 1915. No need for any other oil if the engine was built with the correct clearances.
    Getting back to your question do a leak down test as the others have suggested and report back
