Technical Bishop-Tardel Roadster Blue
Discussion in 'Traditional Hot Rods' started by gearhead695456, Dec 15, 2015.
  1. gearhead695456
    gearhead695456
    Ok I'm going to take another wack at this blue color , in previous posts I've seen the color on the BT roadster called 1936 Washington Blue, but I swear it's a "bluer" color than WB. Does anyone have a modern paint code for the paint used on this actual car? I know this is needle in a hay stack stuff. Is Mr Bishop still on the HAMB? Thanks anyways guys.
    Hackerbilt likes this.
  2. DDDenny
    Don't know about Bishop, but Keith Tardel and Ryan hang out here a lot.
  3. The Brown Sound
    The Brown Sound
    from Maryland
    Could have been shot over black as opposed to a white base.
  4. Here is what PPG calls Washington Blue. 1932,35 36.
  5. gearhead695456
    gearhead695456
    Thanks F100, do you have the paint code for that?
  6. FlatJan
    FlatJan
    bluey ..yeah!
  7. Jalopy Joker
    Jalopy Joker
  8. 2935ford
    2935ford
    Bishop/Tardel book does not mention the color they used so must be custom PPG.
  9. rusty rocket
    rusty rocket
    I love it!!!!!!! I was going to do W IMG_0029.JPG ashington blue but decided on Indian Motorcycle Navajo blue
  10. Gearhead, I have the paint code in my shop will send it to later this evening. That is BC/CC.
  11. The one thing I found out when researching this colour a few years ago from some restoration sites is apparently Ford sprayed it over a red oxide primer which changes the colour quite a bit.
  12. Hackerbilt
    Hackerbilt
    Mr Bishop's Hamb handle is "av8".
    "Mr" adds a nice touch of respect doesn't it?
  13. You can always PM him. He responded to a thread not too long ago, maybe a month?. He's still here.
  14. gearhead695456
    gearhead695456
    Thanks guys for your responses, great info here. I think my best bet is to take a custom color mix that's close and add / subtract from there.
  15. Check out my 3 window build page as it is PPG WB that is shot over red primer. We did add more black and removed a little of the white from the formula so it is some what a custom mix. Looks BLACK under low light and WASHINGTON BLUE in the sun light.
