Projects The Levee Leveler (A Single Seat Racer Circa 1934)
Discussion in 'Traditional Hot Rods' started by cactus1, Dec 17, 2015.
  1. Several years ago as I was collecting parts and building my '34 Chevy I stumbled upon some pictures of early "fairgrounds racers" and "sprint cars" and fell in love! I started picking up parts here and there for what would be my next build after the truck. I'm not entirely sure what it is about the little simple machines that grabbed me but I knew I had to have one.
    Along the way I bought a 'T' frame, model 'A' front and rear axles, and an 'A' engine and trans.
    Then plans changed when I found a '27 T roadster body locally and decided I'd use what I had gathered for that as it would be a more practical vehicle (relatively speaking of course!)
    Well, I started prepping to build the roadster about 3 years ago and then all hell broke loose...we decided to move...
    Outback, dana barlow, brEad and 8 others like this.
  2. hotcoupe
    hotcoupe
    tune in next week for another exciting installment . . . ! :rolleyes: come on what happened then?
    Outback, clem and volvobrynk like this.
  3. Ha! Sorry more to come later. I was trying to take advantage of some free wifi and downtime!
    Outback likes this.
  4. Tim
    Tim
    from KCMO
    Man that third shot is awesome!
    clem and cactus1 like this.
  5. This thread should be called the" cliff hanger"
    cactus1 likes this.
  6. Its the next day.....
    I'm taking advantage of free WiFi, any chance of an update?
    While on the Speedster subject, my old vintage car buddy, told me they used to use copper pipe for the pipe that run down the body, he says it gives a much cooler exhaust sound.
    turboroadster and cactus1 like this.
  7. Sorry y'all. We're in disneyworld for my wife's 40th so I'm trying to sneak on when I can! This will be a slow build so be forewarned!
    So we moved. We bought a little 5 acre place in the country so now I actually have a place to run the car when/if it's done so that's good!
    I had to convert the old dairy barn to a shop. It's not done yet (I have minimal electrical right now) but it is enough to get started so I started dragging stuff over from the other barn and mocking things up.
    Sorry for the Instagram photos. They are the most accessible on my phone.
    I have a bent '36 axle from the pile. Most of this will be built with parts that I have on hand. I hope to not have to buy too many things.
    I pulled it apart as I will be using a spring over arrangement with '32 spindles up front.
    Outback, brEad, catdad49 and 7 others like this.
  8. blackanblue
    blackanblue
    57tailgater likes this.
  9. The plan calls for a T frame with a '34 rear axle that I bought for another project but I ended up finding a Columbia for it instead.
    Also, like a said an A motor and transmission, '32 spindles, 17" wires all around and probably a model A steering box modified for center steer.
    I straightened out a couple wire wheels and was delighted to find "dirt track" tires for 17" wheels at Coker.
    I bought some Excelsiors for the rear as the 17" options are slim. If anyone has an old set of Ascots I would be interested!
    Outback, brEad, catdad49 and 4 others like this.
  10. 55willys
    55willys
    Check out fastrnu build thread "26-27 modified all Ford by Ford". I used a 35 rear and 46-48 front bones on the rear.also check out the front spring perch. It might help you with some ideas.
    brEad, catdad49, Pat and 7 others like this.
  12. Will do. That's your thread? Have a link???
  13. 55willys
    55willys
    volvobrynk likes this.
  14. Cool. Checking it out now. Thanks!
  15. 55willys
    55willys
  16. TexasSpeed
    TexasSpeed
    from Texas
    Clamp-hoarder..
    In all seriousness, I like the plan here! Are you planning on keeping this a two-seater or making it a single-seater?
    brEad, catdad49, skatermann and 2 others like this.
  17. Tim
    Tim
    from KCMO
    You can NEVER have to many clamps ;)
    Halfdozen, 48fordnut, brEad and 10 others like this.
  18. NashRodMan
    NashRodMan
    The shop looks great. Got any more pictures of it?
  19. Thanks man! Your truck looks great too!
    Guilty! No, it will be a single seater with a simple hand built body (hopefully!)
    It's so true!
    Thanks! I will try to sprinkle some in here and there.
  20. Okie Pete
    Okie Pete
    Very nice organized shop.
    Enjoying your build and the direction it is going.
  21. rtsidejohnny
    rtsidejohnny
    Hey cactus! Johnny here, from the Hill Climb. Will we see this in Colorado this year?? Very cool project, I'll be watching this one!
    Cheers
  22. BrerHair
    BrerHair
    Cool Mike! Love those machines also, I'm in.
  23. TexasSpeed
    TexasSpeed
    from Texas
    So, the plan is a hand-built body and not the '27 T roadster you found?
  24. Thanks Pete!
    Hey Johnny! Maybe???? Fingers crossed, ha!
    Thanks for checking in man!
    So, as I said I'm using '32 spindles as I had some I was going to use on another project. I also had a set of '32 perch pins and some '36(?) bones that had been split. Obviously those won't work with the short pins so I had to modify them. image.jpeg
    I reground a bit to make the countersink.
    brEad, catdad49, gwhite and 10 others like this.
  25. Correct! The roadster will now be on an A ch***is (unless I find some '32 rails...)
    slv63 likes this.
  26. Jalopy Joker
    Jalopy Joker
    one of a kind - keep at it
    cactus1 likes this.
  27. Ford Mike
    Ford Mike
    Yay Mike! I like this!
    cactus1 likes this.
  28. Happy you posted this here, bigger pictures, more detail.
    I'm really liking what this is going to be.
    cactus1 likes this.
  29. After looking at many pictures of vintage racers it seems that anything goes as far as front spring mounting. I've seen bulldog type perches, narrowed/ flattened cross members, spring behind, etc.
    I decided to add a front crossmember and bulldog perch after looking at a friend's original Kurtis midget. image.jpeg
    I also tried to bolt everything up using the original frame holes as I had heard that these old T frames were tough to drill. (I haven't really had any problems though?)
    I should also add that after a little research I learned that these cars did not have much caster built into them to make turning the wheels right to left faster and easier. After all, they went around in circles, not straight so I only have a couple of degrees built in. Hopefully it will be ok for what I'm doing? We will see...
    brEad, catdad49, ClarkH and 7 others like this.
  30. gnichols
    gnichols
    from Tampa, FL
    Interesting... sub'd. Gary
    cactus1 likes this.
