Features Corvette Gassers
Discussion in 'Traditional Hot Rods' started by bigalturk1, Mar 23, 2011.
  1. elgringo71
    elgringo71
    Evolution in the quest for speed. I always enjoyed seeing how cars changed to try to go faster or be more compe***ive.
    Rat Sass and Bowtie Coupe like this.
  2. vetrod62
    vetrod62
    Good eye, but also see how the front and rear wheel axles are pushed forward compared to a stock 56/57 vette. Notice how the stock vette center line of the car rear axle is about 5" behind the rear of the hard top.
    Thunderation's center line of the rear axle is abour 2" inside the hard top. The front wheel alxes on both cars pictured, look to be pushed forward about 2". I see that on many SP/M cars. Jim
    enloe, Rat Sass, loudbang and 2 others like this.
  3. NHRANUT
    NHRANUT
    from Western PA
    I have a soft spot for that Fremont photo. :)
    Rat Sass likes this.
  4. elgringo71
    elgringo71
  5. nh-lead-man
    nh-lead-man
    ITS BEING resurrected in New Hampshire undergoing 2 year rebuild thus far. Completely rebuilt Hillborne injected 327 rebuilt 4 speed Frame modifications underway for st.front axle motor mount location. Owned by Don D
    rust, loudbang, elgringo71 and 2 others like this.
  6. loudbang
    Look at those Wrinklewalls WORKING don't see that too much now with all the sticky goo they put on tracks now to help non-hooking cars out. :confused:
    loner2, 1947knuck, Baron and 4 others like this.
  7. seadog95
    seadog95
  8. seadog95
    seadog95
    After searching I found what I believe is my car, Junior Damato owned it and he lived in Hyde Park, MA. From what I was told he raced it between 1970-73, I bought it in 75 and still own it. Does anyone have any information on it?
    Rat Sass, elgringo71 and Bowtie Coupe like this.
  9. Last edited: Jan 16, 2016
    Bowtie Coupe and loudbang like this.
  10. seadog95
    seadog95
    I talked with his son at the shop but he said he was too young and couldn't answer any questions, don't know if his dad is still alive and didn't offer any contact. I received it from someone who lived near the shop when he was younger and said he raced it on the street also
  11. Baron
    Baron
    Any pictures of the car ?
  12. seadog95
    seadog95
    The orange 62 with the white convertible is the car Junior owned, and it is the only picture that I have seen
    Baron and Rat Sass like this.
  13. Scottrodsllc
    Scottrodsllc
    from ohio
    my vette 18.jpg Heres an update on the ch***is for the ScottRods Vette G***er build. my vette z-frame rails.jpg
  14. seadog95
    seadog95
  15. Scottrodsllc
    Scottrodsllc
    from ohio
    Got the body mounted , time to start the main hoop and cage. my vette 20.jpg
  16. Jimbo17
    Jimbo17
    Scott Rods sure does some excellent work and every car project looks First Cl***.
    Jimbo
  17. Baron
    Baron
    Could not agree more. A first cl*** operation. Looking forward to seeing it completed.
    This is going to be a killer car.
  18. Rat Sass
    Rat Sass
    That is one beefy steering arm Scott! Have never used a Corvair box...how does it compare to the Vega/cross steering set-up? Almost used that set-up on my '63 Corvette.
  19. Scottrodsllc
    Scottrodsllc
    from ohio
    I don't think there will be any difference between the two box's, The corvair box is a little lighter and fits this application a little better than the vega.
  20. Scottrodsllc
    Scottrodsllc
    from ohio
    I am searching for another steering arm, I'm a little fussy about my stuff and I donot like the "beefy" look of this steering arm, Also a straight pitman arm would work better on this and I have not had any luck finding one of them either.
  21. Baron
    Baron
    Have you seen the one Speedway Motors sells ?
    The plain one they sell could be straightened out and cleaned up to do what you want I think.
    I have found this steering set up is more stable at speed than cross steering in past builds I have done.
    loudbang, Rat Sass and Scottrodsllc like this.
  22. Scottrodsllc
    Scottrodsllc
    from ohio
    This one came from speedway, Not sure what it might do to the strength of it if we tried to straighten it.
  23. Baron
    Baron
    I have heat and bent these arms as lng as they are a forged peice. The other thing I have done is cut off the splined end, turn it down round and weld it to a fabricated pitman arm so it drops in a hole and gets welded 360° all the way around on both sides. Than you drill 2 or 3 holes for the draglink to attach to change the steering ratio if need be. Just throwing out a couple of things that have worked for me in the past.
  24. Jimbo17
    Jimbo17
    Some of the products from Speedway lack quality and I am not sure I would have total confidence in them.
    Just my opinion. Jimbo
    Scottrodsllc and Baron like this.
  25. Baron
    Baron
    It seems like almost everything we buy today is made in China. Too bad.
  26. Scottrodsllc
    Scottrodsllc
    from ohio
    I understand!!
  27. Rat Sass
    Rat Sass
    First look. Just sat it down on its springs/suspension. Still no motor/trans, so it will set just a bit lower after those are added. Intend to bring the rear up a couple inches, also. Can raise the front as much as 10" from where it is now. 100_1223.JPG 100_1225.JPG 100_1221.JPG
    Baron, Scottrodsllc, loudbang and 4 others like this.
  28. traffic61
    traffic61
    from Owasso, OK
    Talk about your silver streak...
    That is beautiful
    Bowtie Coupe likes this.
