Projects KIWI 1939 COUPE DU JOUR - Runnin from Johnny Law!
Discussion in 'The Hokey Ass Message Board' started by woodbox, Dec 23, 2013.
  1. Very cool and the tram rail system you took the time to make and use certainly paid for it self. Absolutely brilliant idea Wade. I'm enjoying following along on this build as you post updates.
    woodbox and 26 T Ford RPU like this.
  2. woodbox
    woodbox
    1450331768476.jpg 1450331804242.jpg 1450331828645.jpg A little off topic, but an explanation of my lack of progress at the on topic car. We got back from a friend, a 3D printed pattern for a twin down draft intake manifold that my son designed for the Pinto engine in his project car. We will tidy the pattern then send it to the foundry to be ceramic coated, fired (which melts away the printed pattern) then cast in aluminum.
    I have a similar manifold in steel that is on a 1600 kent engine in my mk1 ******. I fabbed it from exhaust bends etc 20 years ago. If his is a success we will do one in aluminum for mine
  3. 26 T Ford RPU
    26 T Ford RPU
    Damn that's cool, it just amazes me what can be done now days. That's a good looking manifold.
    Oh and just to get in early, I hope you and family have a great Christmas and a safe and very happy New Year. :cool::D Jeremy......JW
    whiplash1923T, volvobrynk and woodbox like this.
  4. Sounds like the young man takes after his Dad in the " thinking outside the box " when it comes to building Hot Rod stuff. Is the manifold going to have water running through it two to help when cold ?
    All the best for the new year also from me Wade.
    26 T Ford RPU likes this.
  5. Having another look at the thing, I wonder if what I think is for water is more to balance the fuel as I noticed that the hole goes right through into the inlet.
  6. woodbox
    woodbox
    The hole in question is a dual purpose thing. One is to act as a balance tube between the plenums, also it will be a vacuum take of point for the brakes and PCV. We will weld in a piece of tube after casting is completed. It is a lot easier to do this, than to try and include it in the pattern.
    There is no water jackets, just a boss between the two banks for a water take off point for the heater etc. I have no water jacket on my one and where we are it doesn't get cold enough to worry about carb preheat. 10 deg C in the winter and 30 deg C in the summer.
  7. The 39 guy
    The 39 guy
    Very cool! I hope you show us more of the project as it progresses.
    woodbox likes this.
  8. Yeah, the so called winterless north aye, where it rains cats and dogs a lot. Oh and if in Kaitaia, rope yourself down as it is always blowing a gale. Nah, just having you on Wade as I spend several years as a sales rep up in Northland and absolutely love Whangarei as a place to live. Thanks for the explanation on the manifold as after I studied it some more I sort of worked out that was the case. When I lived in Invercargill I had to run water from the engine through my Weber inlet manifold to get the car to perform but then I had a cardboard panel blocking 75% of the radiator also so the engine would get up to running temp throughout most of the year. The difference from one end of NZ to the other.
    kiwijeff, 26 T Ford RPU and woodbox like this.
  9. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Great project.
    Your intake manifold is somewhat similar to the dual carb intake I fabbed for my champ car. Mine uses Healy SU carbs though with a balance tube.
    I love your country by the way. I'd move there if ever I left USA.
  10. 26 T Ford RPU
    26 T Ford RPU
    Wade, just thinking about you hooking up the PCV and Brake Booster to the balance tube, I feel the Brake booster vacuum will be impaired by the lowering of the vacuum by the PCV System. Just thinking. JW
  11. woodbox
    woodbox
    Jw. I don't use the brakes!
  12. 26 T Ford RPU
    26 T Ford RPU
    Good point.........carry on. JW
    whiplash1923T and woodbox like this.
  13. I hear that there isn't much of a vacuum takeoff with twin carbs.
    Any truth in that.
    I'm doing a 2.0 Pinto motor myself at the moment.
    woodbox likes this.
  14. loudbang
    Now that is a true HOTRODDER can't find a manifold MAKE YOUR OWN that is what Hot rodding used to be.
    volvobrynk likes this.
  15. KustomKreeps
    KustomKreeps
    you have some mad skills.
    saved the thread for reference for my upcoming 52 Buick build.
    plywood idea is great.
    Alex
  16. woodbox
    woodbox
    Thanks kk the plywood certainly made life easier.
  17. woodbox
    woodbox
    I must apologize for my recent disappearance. Progress has ground to a complete halt on the coupe and is not likely to pick up any time soon. My priorities have shifted.
    My father has been building a boat for the last 26 years and it has been a part of our family since 1979 when the project began. I grew up sailing aboard an identical vessel and loved every day of it.
    Dad p***ed away in February this year after a period of illness. This makes the fact that the boat was close to 98% complete that much harder to deal with. Dad was 74 and knew he was unlikely to be able to sail on the boat when finished anyway due to being very sensitive to the sun.
    I along with my sister and our respective young families are working together to be ready to launch next summer (December).
    Long story short......hot rods will wait while I go sailing with my kids!
    The picture is of the boat I used to sail on as a teenager, it is identical to the one we are finishing now.
  18. dirt t
    dirt t
    There's no problem. You have your priority's straight.
    Enjoy the time with your kids and create great memories.
    loudbang and Kroombit like this.
  19. 64 DODGE 440
    64 DODGE 440
    from so cal
    Sometimes priorities shift and life takes a different path. Between health events and other things our race car has been on hold for far too long, but when the time is right, things will happen. Family comes first. Beautiful boat there. Keep us posted on your adventures.
  20. The 39 guy
    The 39 guy
    Well you certainly have the skills to complete your fathers dream! You have made a good priority choice. We that are subscribed to your build will look forward to fallowing your build when you get back to it.
    whiplash1923T likes this.
  21. 26 T Ford RPU
    26 T Ford RPU
    Sorry of your Dads p***ing Wade, these happening are the hardest we have to deal with in life. To build a copy of the one above shows he was very talented and I trust this is where some of your talents that I have seen came from. Look forward to seeing this get finished and sailed. Keep us posted on its happening. JW
    rod1 and whiplash1923T like this.
  22. Jiminy
    Jiminy
    Sorry about your Dad's p***ing but it is great that you and your sister and families are going to finish fitting it out and sail it. Do you have a blog or forum someplace where you will be chronicling that work?
  23. woodbox
    woodbox
    I have a fb page called Blue Water 41 that I started to attempt to attract all of the other 13 owners of the same design, all built in my hometown and now spread all around the world. I may post updates of our progress on there.
    www.facebook.com/bluewater41/
  24. Certainly will join the face book page as I like yachts too. That is a nice Ketch and should be fun for the whole family and I'm sure your Dad would be proud that you are finishing it for the whole family to enjoy. Who designed it, not a guy by the name Underwood ?
  25. 64 DODGE 440
    64 DODGE 440
    from so cal
    I'm following your Facebook page too.
  26. woodbutcher
    woodbutcher
    :( Hi Wade.Sorry to hear of the loss of your Father.Lost my Mother and Father about a year apart in 93 and 94.Mom was 88,and Dad was 98.That is a great tribute to your Father.
    Leo
  27. woodbox
    woodbox
    Terry Wells Designed her and was part of the team that started building the hulls in the 1970's in Whangarei, He was from California originally and now lives in Hawaii
    Thanks
    Thank you.
  28. Wade, sorry to read of your Dads p***ing.
    Now we know where your creativity comes from.
    I have an Uncle in his eighties who builds boats, and he recently completed a restoration on a canoe my Dad built.
    I'll keep my eye open for updates here, when you get the time to get back on it.
    In Till then, look after yourself.
  29. woodbox
    woodbox
    1463890047685.jpg 1463890069033.jpg 1463890084171.jpg 1463890095074.jpg I dropped the coupe down off the bench today and pushed it in the corner. I need the bench for welding the ch***is on my cousins sons T bucket next weekend.
    I have wheels and tires on the front that are about 2 inches too small. But other than that the suspension is at correct ride height!!!!!!
  30. The 39 guy
    The 39 guy
    Looks wicked low WOODBOX! Nice to see it on the ground.
