Projects The Gimme T (1927 T coupe build thread)
Discussion in 'Traditional Hot Rods' started by Jcurtisward, Oct 10, 2015.
  1. Jcurtisward
    Jcurtisward
    from Tucson, AZ
    I started building this 1927 T coupe earlier this year and decided that I should start a build thread for it. I've done quite a bit this year, so there's a little catching up to do.
    I bought this coupe something like 5 years ago. When I had it then I build the chassis, fixed the bad rust, and started making a floor. I was also building my '40 at the time and needed money to finish that project, so the T had to go. I was able to sell it to a friend, which was enough to fund the final stretch of getting my '40 on the street. Fast forward a couple years and thousands of miles on the '40. I was able to buy the T back and my friend hadn't done much to it, so the project pretty much picked up right where it left off.
    My dad came up with the name Gimme T because a lot of the parts are just coming from piles and boxes of parts that he has accrued over the years. Other parts came from friends, I actually got the frame for disassembling a model a pickup for a friend.
    Here are some pictures of the first part of the build before I sold it.
    So, here it is. The Gimme T build thread.
  2. toml24
    toml24
    That looks great. Please keep it a TALL-T.
    Jcurtisward likes this.
  3. Jcurtisward
    Jcurtisward
    from Tucson, AZ
    When I bought it back, it came with an olds that I tried to stuff in the T. Things just weren't lining up , so I went back to the sbc muncie combo. Once the engine was mounted back up the body went to the blaster, the firewall got replaced with thicker material, and I got ready for the chop.
    1.jpg 2.jpg 20150208_184002.jpg 20150215_153608.jpg IMG_20150216_173836.jpg IMG_20150218_172850.jpg IMG_20150224_195710.jpg IMG_20150225_185116.jpg
  4. Jcurtisward
    Jcurtisward
    from Tucson, AZ
    Sorry, Already got chopped! You're a few months too late.
  5. Jcurtisward
    Jcurtisward
    from Tucson, AZ
    So onto the chop! I had trouble with the tops of the doors, so I studied the bad news t build and saw that they had to widen the whole top of the doors. I don't know how other guys do it, but I couldn't see any other way to make the doors fit right.
    IMG_20150301_140747.jpg IMG_20150301_150229.jpg IMG_20150301_150532.jpg IMG_20150301_162949.jpg IMG_20150301_164418.jpg IMG_20150301_183246.jpg IMG_20150303_125135.jpg IMG_20150308_174951.jpg IMG_20150322_123840.jpg IMG_20150322_123940.jpg IMG_20150322_153549.jpg IMG_20150322_153601.jpg IMG_20150322_175821.jpg
    We took some pictures with my dad standing next to it. He got into a fight with a cutting wheel that day, so these pictures were taken when we got back from urgent care.
    After the chop I moved onto fixing the rust and replacing the body support where I cut it out for the rear axle.
    20150410_143700.jpg 20150413_192857.jpg IMG_20150405_141434.jpg IMG_20150405_141459.jpg IMG_20150405_160406.jpg IMG_20150406_172151.jpg IMG_20150406_195121.jpg IMG_20150407_170911.jpg IMG_20150407_191525.jpg IMG_20150407_192857.jpg IMG_20150412_201531.jpg IMG_20150413_190812.jpg IMG_20150413_190910.jpg IMG_20150418_163122.jpg
    After I got that back panel in I couldn't help but try out tail light ideas. I think this is what I'll be going with.
    kidcampbell71 and volvobrynk like this.
  6. Jcurtisward
    Jcurtisward
    from Tucson, AZ
    After the chop, I got the floor structure built. Got the windshield header chopped down and welded in. Then I got the whole body in primer so it wouldn't rust.
    IMG_20150509_181801.jpg IMG_20150510_185553.jpg IMG_20150510_185648.jpg IMG_20150523_171313.jpg IMG_20150524_121104.jpg IMG_20150525_161154.jpg IMG_20150720_192359.jpg
    After that it sat for a bit while I worked on other stuff. I'd piddle on it here and there and I fixed/chopped my grille shell. ( another Gimme part which my dad has had hanging on the wall for who knows how long) The radiator is one of the speedway chopped ones. Got that off craigslist for $100. It came out of an american graffiti replica.
  7. Jcurtisward
    Jcurtisward
    from Tucson, AZ
    Now we're pretty much up to date. What I've been working on lately is the frame horn treatment. Apparently model A horns are more desirable from the research I've done on here. We had a pair of aftermarket 32 frame horns, and I actually prefer that look. So I started heavily chopping them up. I had to change the shape to make them fit the width of a model a crossmember. I also finished the grill shell at this point.
    IMG_20150815_142130.jpg IMG_20150815_150319.jpg IMG_20150815_150514.jpg IMG_20150822_142815.jpg IMG_20150822_142822.jpg
    Yes, the radiator is in front of the crossmember. It was either that, or have it sticking 5 inches above the cowl, so I chose to have it in front of the crossmember.
    Another problem I ran into was that I wanted a straight spreader bar (verses a V), BUT I wanted it all the way forward like a V-bar. Apparently no one makes that?! So I turned some ends, bought a polished tube from the scrap area of my local metal supplier and welded them together. This was my first time welding stainless with tig, and it came out good enough. It only cost me about $10.00 too, so you can't beat that.
  8. Jcurtisward
    Jcurtisward
    from Tucson, AZ
    Last one for the night, just wanted to get a caught up.
    Once I got the frame horns all welded up and the stainless bar made I finished off the frame horns with drilled boxing plates. Then I drilled the outside of them. Then to clean them up a bit I put a cap on the ends. The bar gets put in under the frame rather than in the front now.
    Then today I mocked up the radiator mounts just to get an idea of what it all looks like together.
    20151010_174918.jpg 20151010_174935.jpg 20151010_175023.jpg 20151010_175053.jpg
    That's it for now, I'll hopefully have more updates soon.
  9. AndersF
    AndersF
    Looks great this far.
    Will follow this build for sure.
  10. volvobrynk
    volvobrynk
    from Denmark
    I'm so subscribed!
    What size wheels and tires are you running?
    Like the chop, can you sit in it with out sticking true the roof?
    I like yours better!
    What's the plan paint wise?
  11. Very cool, love the stance..
  12. Jcurtisward
    Jcurtisward
    from Tucson, AZ
    The wheels are 15". I'm not positive what size the tires are, but I need to get taller ones like the tires on the orange rims.
    I can actually sit in it and not be sticking up, and I'll be making a seat that's probably about 2" high and sits directly on the floor.
    I still have no idea for paint. It's either going to be 60s showcar metalflake, or maybe I'll go more traditional hot rod with a black frame and maybe Washington blue body. But I really don't know!
    kiwijeff and volvobrynk like this.
  13. Jcurtisward
    Jcurtisward
    from Tucson, AZ
    I've been busy helping my dad with another car, overtime, and house maintanence, but I was actually able to get something done on my own car today. I got the rear section of the floor made, and added a small tunnel on the cross brace because I raised the engine another 1/2 inch. If the weather isn't too bad tomorrow I'm going to try and get at least some of the front section done.
  14. allenolga
    allenolga
    I like it! looks a little like mine.
  15. AHotRod
    AHotRod
    Tall T Rules ! .... and even those with a haircut.
  16. Jcurtisward
    Jcurtisward
    from Tucson, AZ
    Here is some more progress I made this weekend. I got the front floor all made, but then realized that I had the linkage on the muncie upside down. Oops. So now I'm going to get the shifter boot all attached and then add a piece from the kicker to the boot box. It looks like my gas pedal wont have to go on top of the tunnel though, so that's a win.
  17. Jcurtisward
    Jcurtisward
    from Tucson, AZ
    Nice! Do you have any more pictures?
  18. allenolga
    allenolga
    kidcampbell71 and Tim like this.
  19. hrm2k
    hrm2k
    The seats on the floor actually end up being pretty comfortable. Here are the seats in my coupe
    Keep in mind that my coupe is channeled over the frame about 4 inches or so. The engine sits about 6 inches higher than most installs. The channel and the raising of the engine means a much higher trans tunnel than what you are doing
    kidcampbell71, volvobrynk and AHotRod like this.
  20. VA HAMB
    VA HAMB
    Great Build! Looks Awesome!
  21. Jcurtisward
    Jcurtisward
    from Tucson, AZ
    Nearly 2 years later I feel like I should revive this thread, haha. I'm just about done painting a Deuce for a friend and I feel like the T will finally get done soon. It's been a slow build, but between jobs I've gotten a few things done.
    Highlights would be,
    -Visor (no idea what it is off of, had to widen it)
    -Headers
    -Seat
    -Floor finished
    -Dash installed with gauge panel
    - Cowl vent filled
    -Starting to rough in the body work on panels
    -Trunk lid and panel above trunk lid (Almost finished)
    -A lot of miscellaneous other little things
    Hopefully I can get some real progress going on this thing soon.
    AndersF, kidcampbell71 and Terrible80 like this.
  22. Jcurtisward
    Jcurtisward
    from Tucson, AZ
    Here are the deck lid build pictures too. This is the first time attempting to build something like this from flat sheet, and I'm very happy with how it came out.
  23. MMM1693
    MMM1693
    Great job! It's funny how quick time passes on a build sometimes. We both kinda did the deck lids in the same fashion. Great workmanship and enjoy your build. Good luck!
  24. Stock Racer
    Stock Racer
    Great build. Don't know how I missed this. Subscribed as I am building one similar and can use all the help I can get.
  25. Nightheat Fab
    Nightheat Fab
    Nice job! mine looks close to yours[​IMG][​IMG][​IMG][​IMG]
  26. VA HAMB
    VA HAMB
    Did you ever finish this?
    kidcampbell71 likes this.
  27. MMM1693
    MMM1693
    I hope you finished it, you have such a great start!
