1952-59 Ford 302 exhaust in a 1956 wagon
Discussion in 'Off Topic Hot Rods & Customs' started by 56FORD390, Dec 21, 2015.
  1. 56FORD390
    56FORD390
    What diameter exhaust pipes and mufflers are suitable for this application. I fear that the stock ones are too small.
  2. mitchs66
    mitchs66
    Is your engine stock, or has it been worked up a little? Do you plan on running stock exhaust manifolds or headers? The exhaust shop I like to use always said 2 inch dual exhaust was enough for a small block, but he put on a lot of 2 1/4 and some 2 1/2. Also different size of pipes can change the sound, depends on what you like.
  3. JeffB2
    JeffB2
    from Phoenix,AZ
    Because of the bends to exit through the ovals in the frame 2" would be easier to work with anything larger would be more of a challenge not to rub.
  4. 56FORD390
    56FORD390
    I have headman headers going in. The engine is around 350 horse so it is beefed up a bit. Looks like 2" is the way to go. That's what I needed to know. Thank you so very much.
  5. JeffB2
    JeffB2
    from Phoenix,AZ
  6. EchoOfGecko
    EchoOfGecko
    I'm running a 2" dual system with 23" Smithy's on my slightly warmed over 302 and couldn't be happier... as others have said any larger and it would be a trick trying to run it through the angled ch***is braces in the front.
  7. BeerMoney
    BeerMoney
    would it hurt anything if i run stright pipes out the rear i have a h-pipe
  8. Slicks
    Slicks
    from denison tx
    I ran 2 1\4 on my 55 Victoria no trouble at all i had plenty of room i have a good muffler shop here
  9. fordsbyjay
    fordsbyjay
    from Lafayette
    At least 2 1/4" and 2 1/2 if you plan any future power mods.
