Projects WilDhair 50 Shoebox build
Discussion in 'The Hokey Ass Message Board' started by 4rod, Mar 29, 2013.
  1. 4rod
    4rod
    Okay today worked on the b pillars. Wow lots of work. Slanting, getting the door to fit Here goes.
    Took out 2 7/8's out of the pillars
    ImageUploadedByH.A.M.B.1406253332.426094.jpg ImageUploadedByH.A.M.B.1406253353.442678.jpg
    daddio211 likes this.
  2. daddio211
    daddio211
    4rod likes this.
  3. 4rod
    4rod
    Hey yeah, the mild chop looks real subtle.
  4. Stefan T
    Stefan T
    from Sweden
    looks good
    nice build
    4rod likes this.
  5. 4rod
    4rod
    Not a whole lot done today still took 4 hrs. Clean up the b pillar and welded in the rear window corner.
    So, so much still to do. Haven't even started on the inside yet.
  6. 4rod
    4rod
    So today plan is to finish up the back window, rear 1/4 and b pillar on drivers side.
  7. 4rod
    4rod
    Couple more from today
    Flows pretty good. Need to hammer and shrink some more.
  8. captaintaytay
    captaintaytay
    Nice work Devan, it's just how I would done mine.
    This is going to be another sweet ride.
  9. 4rod
    4rod
    Thanks cap
    Got I bit more done. Second 1/4 window went much quicker
    Tackling driver b pillar and finish up rear window tomorrow. Got a real cul gadget from harbor freight. It's a cushioned attachment for my angle grinder. I've only seen them for air units. Since I don't have a compressor this is pretty cul
  10. 4rod
    4rod
    Got the b pillar in then the welder started acting up. Maybe doesn't like 90 degree weather!?
    More to come
  11. 4rod
    4rod
    Got all the rear tac down. Put it on the road for some pics
    Before
    After
    Now to finish the doors, trim ect...
    captaintaytay and daddio211 like this.
  12. daddio211
    daddio211
    Excellent proportions!
    4rod likes this.
  13. EBW
    EBW
    Great job !!
    4rod likes this.
  14. 4rod
    4rod
    In Denver for ten days. So will get back at it when I get back. Lots to do. Anyone have good results an ideas for shrinking welds?
  15. 6Racer
    6Racer
    Great job just subscribed
  16. 2BROKE
    2BROKE
    Looks good man!
    4rod likes this.
  17. 4rod
    4rod
    Thanks 6racer. Yeah it's got a long way to go...as you know. Hope to see you in a couple of days. It will be great to get our shoeboxes on the road this summer. Not much in bend along the cars were building.
  18. 4rod
    4rod
    Just got the 50 fired up. After diyin since September thought I'd do some carb adjustments.
    Guess I can't post videos so you'll have to trust me. On the agenda is to start te finish work on the chop.
  19. 4rod
    4rod
    Got some sweet tear drop dash knobs from Wirths.
  20. 4rod
    4rod
    Started on filling the rear seams.
  21. captaintaytay
    captaintaytay
    Devan, It's been awhile, how's the car coming along?
  22. 4rod
    4rod
    Hey cap
    My father has been hospitalized for the last month. Things has slowed down on the 50. Hopefully I can get some stuff accomplished soon.
  23. captaintaytay
    captaintaytay
    I'm sorry to hear about your Father, hope all works out well for him.
  24. reggied
    reggied
    Mine has a '74 Comet rear with new Yukon 3:55 gears and after market sway bar. Running a 302 roller motor with a 5 speed. I have Bronco rims, allows me to run caps and still fit under the fender skirts.
  25. 4rod
    4rod
    My fifty has a stock rearend. I do have an 8.8 in a 46 bis coupe.
  26. 4rod
    4rod
    Attacking the body panels and finishing up chop seams. It looks good in its new home.
  27. 4rod
    4rod
    Alright, yeap it's been awhile however I'm back at it...sorry for the delay, finished a build(62f100uni) and got it sold now putting a lot of energy into the shoebox before summer slips away...also I've noticed alot of builds that started years ago have gone the way of the dodo bird. Some of us have been on the H.A.M.B. For years. If we can all sustain our builds and this sight can continue to have the flavor of good workmanship and hardline, old school vision maybe we can revive some of the lost/ dead builds I.e. "Flop,", Rusty's 47, even farmers 41 Plymouth from Sweden. Well there's my soapbox.
    Started to complete and finish welding the seems and hammer an shrink **** welds around window and left C pillar.
    Lots of worn thin metal reviled when welding seems. Had to fill and chase some nasty areas around the gutter
    I was able to save the left gutter however when I get to the right side it's pretty pitted and well...we'll see
    Next I trimmed the cap that sits on the top of the rear quarter. Lots of canaer in that seam and had to work around the lead that ford uses to fill, whatever? Still don't know why ford did that
    Eventually got it welded and built up enough to round and smooth it out
    More to come, now need to finish welding from the inside.
    TS057 and captaintaytay like this.
