**Tech: Build your own 32 frame rails**
Discussion in 'The Hokey Ass Message Board' started by flthd31, Oct 5, 2008.
  1. superjunkman
    superjunkman
    from Austin, TX
    BTTT This thread is awsome!
  2. big duece
    big duece
    from kansas
    Outstanding! I have heard it being done, but never seen the process. I wouldnt have the patience, I would have bough the rails and used your outstanding talent on the body that you were doubting the condition of. Again, hats of to ya.
  3. dragster dude
    dragster dude
    dumpster diving the ultimate hybrid build
  4. Does anyone know if a router speed controller like the one pictured would be adequate to reduce the speed of a cheap, non-variable speed grinder to effectively achieve what you do with that killer Milwaukee?
    Thanks,
    Steve
  5. bcharlton
    bcharlton
    from Buffalo NY
    You are at a different leval. I'm not worthy.
    BC
  6. rottenleonard
    rottenleonard
    I know I'm pulling this one out of the depths, I have started writing a cnc programs to cut me a set on my plasma bed. did you have to make the outer plate a little longer than the inner plate to account for the curve? I have most of the drawing done but haven't gotten around to measuring the difference in lengths.
  7. flthd31
    flthd31
    Wow, this hasn't popped for a while. I'm ashamed to say that the coupe still isn't on the road...but getting close.
    To answere your question, no, the outer and inner plates were identical. Toward the end of the thread, I show tapering the horns on the inside edge. At that time I evened then up so the front edge would be straight across.The rear came out OK. Hope this makes sense.
    I've added a couple of pics to show where this project is at. Lots of guys see that frame and scratch their heads when I tell them it's home made. That one project more than paid for my Hypertherm plasma and it fits that A body like a glove.
  8. ken1939
    ken1939
    Very nice, very very nice.
  9. rottenleonard
    rottenleonard
    Ah the car is looking great, I know how other projects tend to push their way to the front of the line.
    It looks like you used the upswept front frame horns rather than the flattened style is that right or am I just seeing things? I like the way it looks, I'm using a 29 a roadster body with a duece grill and want to have it look right.
    Here is the westcott pdf so you can see what I'm asking
    http://www.wescottsauto.com/WebCatalog/Tech/FrameDiagram1929Hiboy.pdf
  10. dad-bud
    dad-bud
    Don't fret about not having it finished, it's still an awesome display of thinking outside the box and coming up with a solution to get what your want for a price you can afford.
    Inspirational.
  11. flthd31
    flthd31
    Yes, it's up-swept the same as a stock 32 frame. Back on post #237, I uploaded the pattern I used for my wood template. It was blown up from the Wescott print and needs some refining after printing because the lines blew up also...about 3/8 inch thick.
    dad-bud, thanks for the kind words.
  12. BenLeBlanc
    BenLeBlanc
    Hate to dig up an old thread like this out of the depths, but this guy deserves it. Too cool.
    Now what do you do to combat the shortening of the sides and top/ bottom due to the bends put into the metal? You seem to cut it as if it were in profile, which would result in the resulting frame being shorter than the real frame; no? That is just the last concept I am trying to grasp here...
  13. X38
    X38
    Ooo, that's a good point. How crucial it really is depends on the car being built. If for an A model body, it probably doesn't matter at all. For a totally correct spec 32, it probably does.
  14. flthd31
    flthd31
    Wow, resurrected from oblivion...which is where all tech threads have gone, unfortunately.
    X38 is right on. For a Model A...who cares if it's perfect. For a '32, you would want it correct with a developed view of the side.
    I planned all along to use a model a body on my frame with a slight channel so I wasn't too worried about it being exactly perfect in every dimension.
    As for it not being exactly the right length...well, your right, it's a tad shorter, but there again, I was putting a model a body on it so it wasn't an issue for me. I actually bobbed the front of the rails 2 1/2 inches and kept the stock model A wheel base of 103 1/2 instead of the 106 for 32's.
    This project was never intended to be an exact copy of a 32 frame. Trying to make a perfect duplicate then pinch it at the cowl, then kick up the rear and then re-contour the rails, then shorten the wheelbase...all to fit a Model A wouldn't make a lot of sense.
    If you're luck enough to have a 32 body, you probably would be better off buying repop frame rails.
    Here's a couple of pics for you where I currently at. Test drive with no doors was a good time. Lots of guys have seen it and nobody thought it was weird looking.
  15. scotti32
    scotti32
    That coupe is turning out beautifully.
    flthd31 likes this.
  16. X38
    X38
    Coupe is turning out every bit as impressively as the tech thread it began with! Great job.:)
    flthd31 likes this.
  17. flthd31
    flthd31
    Thanks, guys. Got side tracked a few times on this build but it should be on the road in a few weeks.
    Here's a couple pics of the dash. I'm leaving the steering wheel and waterfall un-restored. The tach is an old "Radatron" that works beautifully. And, the horn ****on works! steering install_016a.JPG steering install_023a.JPG
    Rich B., just Mike, chopd top and 4 others like this.
  18. clem
    clem
    WOW ! Amazing build. Thanks for posting. That dash is fantastic, as is the whole car.
    flthd31 likes this.
  19. D-Russ
    D-Russ
    Very, VERY nice.
    I love the idea of keeping the Model A wheelbase with a 32 frame. I didn't realize you had done that until I read your most recent posts. Again, VERY nice.
    flthd31 likes this.
  20. flthd31
    flthd31
    Thanks man, I wanted to run a stock hood top from the beginning...didn't want to stretch one 'cause I like the A Coupes "short and stout " just like Henry built them. I ended up using an old 32 hood I had. That stainless center hinge really cleans things up a bit.
    30TudorSedan, Rich B. and charleyw like this.
  21. DDDenny
    Roger that!!!
    Two things:
    I'm liking Model A's much more than I use to thanks to guys like this that go the extra mile, especially the deuce hood and shell, and about that *****'n frame---
    YOU GOTTA WANT IT PRETTY BAD
    Bravo
    flthd31 likes this.
  22. tobyflh
    tobyflh
    from Peru il
    WOW!!!!
    flthd31 likes this.
  23. jerseyboy
    jerseyboy
    Triple wowie! That is one beautiful ride:cool: Love the dash and color.BTW, what is the color?
    flthd31 likes this.
  24. Bugguts
    Bugguts
    Just reread the whole thread. It's been a few years ago that I first read it, but it's very cool to see the finished car. Looks really nice. Well done.
    flthd31 likes this.
  25. flthd31
    flthd31
    It's an old Porsche color from the 60's called Schiefergrau or Slate Gray - code 6401. It's Glasurit 22 line paint.(BASF subsidiary)
    It's a nonmetallic single stage...probably too high of quality for this old rust-bucket.
    Here's what it looked like before....just a bunch of cast off parts.
    Wanderlust likes this.
  26. wow that looks awesome man!!
    flthd31 likes this.
  27. jerseyboy
    jerseyboy
    From humble beginnings....makes it even more impressive. Now one of my favorite builds!
    flthd31 likes this.
  28. F-head
    F-head
    very impressive
    excellent work, love the color
    flthd31 likes this.
  29. sport fury
    sport fury
    would like to have the print outs for the top views of the 32 ford frame rails.
  30. flthd31
    flthd31
    Sorry, I do not have one. The top profile pattern was made right on the garage floor directly on the plywood as shown below. You could easily do the same thing with any project.
    The frame rail is straight from the cowl forward. It's forward width is determined by the width of your front crossmember. From the cowl back, it will follow the body contour. Overall length is determined by the wheelbase you choose.
    Here's a re-post from earlier in this thread:
    To make the top profile, I drew a centerline on the garage floor and put the floor, cowl and front cross member in place using the dimensions on the print. I then traced the contour onto luan underlayment and cut it.
