rebuilding after the crash
Discussion in 'Off Topic Hot Rods & Customs' started by racer-x, Sep 19, 2015.
  1. strokedstang331
    strokedstang331
    from Beloit WI
    Cars looking good. Another trick to pounding out dents without making more dents is tape the head of the hammer or use a dead blow that is rubber coated. I learned the tape trick from a painless dent guy we have come to our shop. I use 4 or 5 layers of masking tape works pretty good or duct tape works good to but I never have any when I need it lol
    els, belair, hipster and 2 others like this.
  2. mad mikey
    mad mikey
    I think the four bar and torsion bar set up is a excellent choice for the front, proven over many years to work great! Merry Christmas racer x, and happy new year.
    els, loudbang and volvobrynk like this.
  3. Thanks mike and merry christmas to you to. We found a guy that makes torsion bars. We will mock up everything then put it on the scales. Then the torsion bar and rear springs will be ordered. Being a nonfendered street strip car the front end gets busy. I will have head lights and directional. Im thinking adding coil overs to the mix would make it look ugly. Merry christmas to everyone reading this post.
    els, loudbang, mad mikey and 2 others like this.
  4. Havr you considered something like these? Most look way to late model for me, but these from Speedway don't look too bad.
    els likes this.
  5. I have seen those lights with the directional in them. I may use the original 31head lights. They are very cool. I had 50s era mack truck lights on it when it crashed.
    els likes this.
  6. bsgp8ntball
    bsgp8ntball
    from Houston
    Miss a week or two of this thread and it's like you've been away for months. The amount of work getting accomplished is amazing!
    els likes this.
  7. Thanks it is going at a good pace. Its crazy trying to keep track of every thing. Im selling a bunch of parts. Ordering a bunch of parts. Working on the car. And trying to plan ahead so this project wont stall due to some unforseen problem. Its almost a full time job. But im ok with that. I work best under pressure. The hamb is only seeing a small percent of what it takes to build a car like this. This weekend im planning on going to cedar falls iowa to work on the engine. Another one of my good friends will be introduced. He also comes with a pedegree a mile long. Not only did he invent the b-1 heads that koffel sells it was his heads on the dodge boys engines that won three pro stock ***les. Thanks for everyones interest.
    els, hipster and loudbang like this.
  8. tricky steve
    tricky steve
    from fenton,mo.
    o.k. ****er, now I feel like I should crush my car,and start over !! LOL
    AWESOME !! How on earth do you find any time to post stuff ?? you must be super man !!
    els, racer-x, rawcjw19 and 2 others like this.
  9. mad mikey
    mad mikey
    You make us all look like we are running around backwards!
    els and loudbang like this.
  10. thats just how i do things. i dont do a lot of things but when i start something i go all out. steve hows the plans coming for participating in drag week. i told you i was going to stay on you. i gave you a triple dog dare. there is no getting out of that. mike how about you? its going to be closer to you than in the past.
  11. mad mikey
    mad mikey
    Got a long list, but trying to get on it. Have to figure out the little trailer thing as well.:eek::D
    els likes this.
  12. the rules on the trailer are 4x8 max. there is a hight limit but I forgot what it is. I use a aluminium 4x8 trailer that I have modified to suit my needs. there is a cradle I built onto the front to hold the slicks. I have a tool box and vice mounted in the back. I added a rail going all the way around to keep things from falling out. all of the things I bring go into labled plastic totes. this keeps them organized and dry. I bring battery operated tools. a 1/2 inch elect impact is always handy for tire changes. a plug in 12 volt air compressor is nice to have. I bring a 12x12 instant pop up canopy; alum jack; car stands; paper towel; a gallon of water; spare oil and drain pan; a case of brake clean; a electrical kit with tester; full set of gaskets. think of the things that could save your *** out in the middle of nowhere at 2am. on a dark deserted road. just don't over do it.
  13. mad mikey
    mad mikey
    Thanks for the Info. The hight limit I am not to worried about, as long as the thing is lower then the coupe I should be fine. Right? Saw some guys using those little U-HAUL trailers last time.
    els likes this.
  14. tricky steve
    tricky steve
    from fenton,mo.
    well... yeah after the triple dog dare, I have to go, and Cheryl is all excited about going too !
    first year, I'll bring the model A truck, nobody will even see my coupe after you roll yours out !!
    yeah, thinking about driving my coupe into the river !! LOL
    keep up the awesome work !! you're THE MAN !!!
    els, loudbang and racer-x like this.
  15. squirrel
    cool!
    els and hipster like this.
  16. manicmachanic
    manicmachanic
    from Berwyn, IL
    That ****S!
    els likes this.
  17. I tried the U-Haul. the problem with it is everything I needed was always in the front of the trailer. I spent more time unloading then reloading just to get what I wanted. the uhaul always needs to be connected to the car whenever you go in it or it flips up in the air. my trailer is setup so everything can be seen and reached from either side. just take the stuff you would normally bring with you on a track day. throw in some basic spare parts you may need. there is some strategy to surviving drag week. one thing is to make your p*** as early as possible. that way you can get on the road quickly. this plays into your favor because parts stores will be open and you are travelling in the daylight. changing rocker shafts by cell phone light is no fun in the dark. ask me how I know. speaking of light bring some flash lights also. to hook up my trailer I use a normal receiver. it will take the hitch or the mount for my parachute. just by pulling a pin I can go back and forth.
    wingnutz, loudbang and mad mikey like this.
  18. manicmachanic
    manicmachanic
    from Berwyn, IL
    Need more pix of C***andra!
    els likes this.
  19. I think I posted her web site some where near her photos. someone else was asking for them also.
    els likes this.
  20. mcmopar
    mcmopar
    from Strum, wi
    Where and when is this race you speak of?
    els likes this.
  21. squirrel
  22. belair
    belair
    Great work.
    els likes this.
  23. john walker
    john walker
    I have a very nice 31 chrysler grille shell if you need one.
    els likes this.
  24. rusty1
    rusty1
    C***andra....
    els, loudbang, Stogy and 2 others like this.
  25. I have to say it was cool to see the drive train in the ch***is today. Due to a nasty snow storm there has been a delay getting the body to the shop. I grabbed the head off the engine for this weekends trip to iowa. If everything goes as planned i will be coming home with a drum of nitro. 20151230_124225.jpg 20151230_124237.jpg 20151230_124329.jpg 20151230_124408.jpg 20151230_124422.jpg
    els, mad mikey, loudbang and 4 others like this.
  26. I thought today i would locate and dust off a few things i havent used in a while. For some reason i cant find the hydrometer. It will turn up eventually. Talking about drums of nitro can really get a guy fired up. 20151230_141911.jpg
    els, mad mikey, loudbang and 3 others like this.
  27. Stogy
    Stogy
    racer-x the theme is evolving quick here the Beauty and the Beauty...you are quite the craftsman. Thank You and Happy New Year
    els and mad mikey like this.
  28. thank you for following all this craziness. happy new year to all.
    els likes this.
  29. My drag week trailer. Nothing fancy. A well organized setup is all you need. I put the tires outside the trailer freeing up space inside. There are guys on drag week with more money in the trailer than some guys cars. Remenber keep it simple you dont race the trailer. Squirel won his cl*** and didnt even pull a trailer. 20150802_193627.jpg
    els, kidcampbell71, mad mikey and 2 others like this.
  30. Kiwi Tinbender
    Kiwi Tinbender
    Yeah, but our man Squirrel is a Legend.....:D:D
    els, Wowcars, Dog_Patch and 5 others like this.
