Projects My Deuce Coupe Project
Discussion in 'The Hokey Ass Message Board' started by Jimmy Tee, Aug 15, 2009.
  1. rcnut223
    rcnut223
    from wisconsin
    Absolutely beautiful!
  2. Jimmy Tee
    Jimmy Tee
    Time to decide on Dash Knob/Key locations.
    I have three knobs (Heater, Lights & Wipers) as well as the Ignition Key and Push ****on Starter.
    With my Gauge Cluster the way it is I can't balance the five items on either side of the Cluster. So I've decided to put the Ignition Key over to the Right and leave the Push ****on Starter next to the Knobs.
    The alternate I considered was to put the Key where the ****on is now and put the ****on out of sight under the dash. I gotta decide soon so I can drill out the holes and get the Dash panel off to paint.
  3. Jimmy Tee
    Jimmy Tee
    Tail Lights (1941 Pontiac) have now been trimmed and fitted.
    Here are some before and after pics of how much had to be taken off to get them to sit flat against the rear panel.
  4. Jimmy Tee
    Jimmy Tee
    Nearly there.
    Just waiting on the last few pieces (Trunklid, Gas Tank, Hood, Grille Shell, Garnish Moulds and Dash) to come back from the Painter and I can get maximum weight on the car to measure up and have the Drive Shaft made. In the meantime I'll get Door Gl*** made and finish off certain small items.
    langy, Drewfus and thommoina33 like this.
  5. rcnut223
    rcnut223
    from wisconsin
    Looking Great!
    Awesome flathead!
    Jimmy Tee and 509garyd like this.
  6. Looking good Jimmy
    Jimmy Tee likes this.
  7. Jimmy Tee
    Jimmy Tee
    Trunk lid is finally painted and fitted.
    The wheels have been sent to get Trued Up, as they had a few knocks, before they get Powdercoated Black.
    I made a template for my drivers side gl*** and sent it off to get some Toughened Gl*** made. Now I know why everyone builds Roadsters. The cost for this type of gl*** is criminal.
  8. Jimmy Tee
    Jimmy Tee
    Gl*** is now all fitted. The Dash is fitted and tested ok. All electricals are done. Grille Shell and Radiator are fitted, as well as the front Cycle Guards.
    I had a leak on the seam of my Fuel Tank so that had to be cleaned out, ground back and Soldered. The fuel system is now complete and tested for leaks, but I still have to work out where to fit a breather tube for the tank.
    Master Cylinder brake lines had to be re-terminated as the Banjo fittings I initially had would not seat and seal properly.
    Now to bleed the brakes again, fit the rear Cycle Guards and paint the Grille.
    The Heater has been Powdercoated hammertone and vents chromed.
    The Electroplater didn't test the metal of my heater vent handles and fried them.... To top it off he also lost my throttle linkages, so I have to make some new heater vent handles and purchase new linkages from the U.S.
  9. ace5043
    ace5043
    from Florida
    You nailed it with the steering wheel & dash..very nice.
    Jimmy Tee and rodl like this.
  10. langy
    langy
    Looks great Oz, why is the gl*** so expensive over there, a door gl*** here in the uk is about £25 ($16)
  11. Jimmy Tee
    Jimmy Tee
    Thanks. 55 Olds Dash & 41 Poncho Wheel. Something different I thought. But I love the Art Deco look.
  12. Jimmy Tee
    Jimmy Tee
    My rear screen was AU$85, but that was just laminated gl***. So I went to the same place for the drivers door gl*** and he charges me $300 for Toughened gl***. I then found out that it p***ed through three different shops (toughening, Edge polishing, and the guy I took it to), so they each got their cut. So for the p***enger side gl*** I took it to a one stop shop and got charged $130. Still expensive for what it is.
  13. Jimmy Tee
    Jimmy Tee
    I painted and fitted the signatory Deuce Grille today. It's now looking good.
    Dean Lowe, Drewfus, DeLuxe 32 and 2 others like this.
  14. 509garyd
    509garyd
    Sweet....
  15. Not far off now Jimmy.
    Looks Great
  16. Jimmy Tee
    Jimmy Tee
    I just need to make the fuel lines leading to the Carbs, Bleed the brakes and she will be ready for her first drive tomorrow.
  17. 509garyd
    509garyd
    I bet you cannot wait, good luck sleeping tonight knowing you will be test driving it tomorrow....
  18. That's a great looking car, well done. I like the couple of little pops of br*** in the door hinges and engine block, just enough to add that bit of interest but not too in-your-face.
  19. brady1929
    brady1929
    Damn it is beautiful!
  20. RodNoc
    RodNoc
    from Kelso, WA
    Absolutely stunning. Thank you for continuing to share your accomplishments with us.
  21. Austinrod
    Austinrod
    from Austin
    Everything is done right on this
    rat bastad and Jimmy Tee like this.
  22. Jimmy Tee
    Jimmy Tee
    No startup today. I had a hiccup with the Fuel lines. I lost one of the fittings to the Fuel Block and most shops carrying such stuff are still closed here for the holidays. I'll go on the hunt for one tomorrow.
    On a brighter side, the Brakes were bled.
    Dean Lowe, Austinrod and ct1932ford like this.
  23. thommoina33
    thommoina33
    Alliance Member
    from australia
    What fitting? I got fittings if you get stuck.
  24. ct1932ford
    ct1932ford
    Hard to make cycle fenders look good! But you sure did.:cool:
  25. ct1932ford
    ct1932ford
    What are you using for seat tracks?
  26. Jimmy Tee
    Jimmy Tee
    I painted them Matt so they blend in as much as possible with the Tire. I didn't want them Gloss & Shiney to stand out.
    I had the tracks I purchased with the Glide seat I was going to use, so used those.
  27. Damn so close.
  28. Looking awesome, keep pushing forward, almost there.
  29. And she sounds SWEEETTT ;)
  30. ct1932ford
    ct1932ford
    Love the taillights :cool: And everything else as well.
