Features Truly Traditional, Period perfect 1932-34 Chassis Picture thread.
Discussion in 'Traditional Hot Rods' started by Harms Way, Apr 24, 2012.
  1. HotRodMicky
    HotRodMicky
    Damm Kent , that ch***is is nice!!
    I ilke the pierson coupe ins***ed rear crossmember!
    Michael
  2. Wardog
    Wardog
    Dad's 32, The brake line running down the torque tube is a neat idea.
  3. Larsdk
    Larsdk
    Ive seen this shop before:D
    Say hey to Wolf
    Lars
  4. J.B.
    J.B.
    from Sweden
    Hi!
    Have you been to my garage before? :)
    Can't remember... :confused: Getting old here...
    I'll say hi to Wolf!
    Best
    J.B.
  5. lil32b
    lil32b
    from Belgium
    Hi
    Is there anyone who has "modern rear shocks" with the original rear crossmember on the ch***is ?
    I've seen the way Mart did it on his '33 survivor, but i want to see some variations...
    Thanks,
    Filip
  6. juniorsrodshop
    juniorsrodshop
    from nh
    I have 48 tube shock mounts on my Columbia rear end in my 32... I run a 40 rear crossmember that is flattened but it would mount in the same place as stock. I'll look for a picture post number 78 on page 4 under my build thread bellow
  7. alchemy
    alchemy
    Mounting tube shocks with a '32 rear crossmember is a VERY TIGHT operation. I used the shortest shocks I could find, but I wanted them to have shrouds. There is about a quarter inch from axle to shock and then shock to crossmember. I made a bolt-on mount to the crossmember and a bolt-on mount to the wishbone-to-axle bolts.
  8. lil32b
    lil32b
    from Belgium
    @ Alchemy, do you have any photos of the set up and the shocks are of what type of car ?
  9. lil32b
    lil32b
    from Belgium
    I considred this kind of set up, but i think it will not work properly or even not...
  10. Gary Addcox
    Gary Addcox
    Neal in LA, you cleaned up an otherwise laughable and obviously dangerous build. If that **** is what "tradition" was, screw it. Your car looks healthy now, and should be a fun, safe ride. What you now have is real "tradition".
  11. irondoctor
    irondoctor
    from Newton, KS
    Agreed!
  12. mad mechanic
    mad mechanic
    some truly inspiring ch***is, subscribed
  13. Six Ball
    Six Ball
    from Nevada
    Some really nice stuff and a great thread in a limited kind of way. It seems that in the beginning it was about traditional rods through the 60s and rapidly turned rods with closed drive lines. Once you remove the torque tube something has to replace it. There were a lot of rods from the mid 50s through the mid 60s that had open drive lines. Basically when you remove the torque tube the Ford set up changes from a well designed suspension to a poorly designed triangulated 4 bar if you run the bones back near the center or a more poorly designed parallel 4 bar if you split them. Either way you have to add something that the traditional police will give you a ticket for. Good stuff anyway and some great workmanship.
  14. Bringing the ch***is **** back up top.
  15. firerod
    firerod
    from Colorado
    37 millrat, ch***is looks great.
  16. louisb
    louisb
    Bump for new ch***is ****.
    --louis
  17. Jeff Norwell
    Jeff Norwell
    MODERATOR
  18. louisb
    louisb
    Now that's the stuff.
    --louis
  19. FritzTownFord
    FritzTownFord
    Jeff Norwell likes this.
  20. thommoina33
    thommoina33
    Alliance Member
    from australia
    ImageUploadedByH.A.M.B.1413330166.076929.jpg ImageUploadedByH.A.M.B.1413330195.420996.jpg ImageUploadedByH.A.M.B.1413330232.406836.jpg
  21. A Rodder
    A Rodder
    ^^^is that the Industrial Ch***is rear leg kit? @thommoina33
  22. thommoina33
    thommoina33
    Alliance Member
    from australia
    No, made locally by Ben at Rancho deluxe.
  23. A Rodder
    A Rodder
  24. NealinCA
    NealinCA
    Here's some pics of the ch***is I am putting together for my old Fordor patina car...
    [​IMG] [​IMG] [​IMG] [​IMG]
    kidcampbell71, Walle, haring and 2 others like this.
  25. StrickV8
    StrickV8
    Here is an older pic of my original '32 Ford ch***is. Has had a '30-31 chopped Model A Tudor on the frame, a '31 Model A roadster body, and now a Brookville '32 Roadster body. 223271-1285894340-e53e3b66c3a08b14e2d9b3b2fad33465.jpg
    kidcampbell71 likes this.
  26. Any new frames to show?
  27. texkbc
    texkbc
    11817284_1094869783859852_2686184542225496460_n.jpg 11027940_1094869763859854_1550373066760722008_n.jpg Here's my rookie attempt...
  28. FPorth
    FPorth
    Hi Kiwi
    Is this your ch***is? I'm thinking of doing something similar...flathead with all A front and rear end.
  29. FPorth
    FPorth
    Hi Kiwi
