Mike Chilando- Alkydigger.com -Hilborn-Enderle-Blowers-Drives-Magnetos
Discussion in 'The H.A.M.B. O'Dex' started by alkydigger, Jan 1, 2016.
  1. No- it is not possible- the fuel pump must be mechanical, and sized to the engine, nozzles, and fu
    1 vote(s)
    100.0%
  2. Mechanical can be used on the street with limited success as a weekend warrior
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. alkydigger
    alkydigger
    from nashville
    www.Alkydigger.com for any help with Hilborn, Algon, Enderle, Vertex Magnetos,
    We stock almost everything Hilborn and Enderle makes, as well as a huge Blower and drive systems inventory from BDS, The Blower Shop, and Dyer
    615-457-3192
  2. alkydigger
    alkydigger
    from nashville
    When you get to about 10% under drive with a 6-71 , you should highly consider double keyway
    At 1-1 you should double key for sure
    At 10% over with a 6-71 , you are ok with a double keyway, but with a 8-71 you should consider two things : A Crankshaft support , and/or a Big Block Snout on your crank.
    At anything higher than 15% over with a 6-71 and 10% over with a 8-71 all small blocks should be equipped with a crankshaft support.
    At 20% over with a 8-71 , 10-71 14-71 all Big Blocks should consider a Crankshaft support.
    * Why ? - From the minute a blower begins to turn, it pulls the crankshaft up against the top main bearing- the more the boost or speed , the worse it gets. On a small block, you can snap the snout off the crank, on a big block, you will eventually beat the top main bearing out of the block-
    More speed,,,,, more of a problem.
    The Crankshaft support acts like a 6th main bearing out in front of #1 main bearing, causing the crankshaft to be supported as if it is in a cradle .
    We sell crank supports for Big Block and Small block Chevies, and we are about to introduce our LS Chevy support next month.
