Projects 1950 Styleline coupe kustom build thread.
Discussion in 'Traditional Customs' started by Devin, Jan 14, 2015.
  1. Devin
    Devin
    from Napa, CA
    Yeah until you burn a big *** hole in the rusty part and you spend 5 times as long filling it in lol!
  2. VonMoldy
    VonMoldy
    from UTARRGH!
    Haha or find 1" of lead covering tons of rust and a big dent.
  3. Devin
    Devin
    from Napa, CA
    ImageUploadedByH.A.M.B.1445220778.038069.jpg i reworked the brace to fit the contour or the wheel opening better. I should have taken more pics but basically made a reference line parallel to the ground and traced the contour to a cardboard template the template was cut out in sheet metal and the reference line was transferred. This made it easy to get the position accurate. Can anyone tell me if the inner wheel opening lip gets folded over the inner fender lip like a door skin, spot welded or does it get held in with seam sealer or other goop? Thanks
    50 customcoupe likes this.
  4. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    I'd love to be able to tell you, but unfortunately mine were made out of sponges, newspapers, fibergl*** screening, and that was all behind the wall of bondo. To be honest, before I read your posts, I didn't even realize there was a supposed to be a brace back there.
    Thanks for posting all of your work, I will be coming back to it when I get there with mine.
  5. Devin
    Devin
    from Napa, CA
    That's crazy. I can't really imagine someone actually trying to fix something like that but it happens all the time. The brace basically connects the front if the wheel well to the back and has a little flange on it to support the wheel opening that's about 1/2" wide. The actual wheel opening has a corresponding flange that Tia sits in plus an extension that is bent almost 45* up an into the wheel area. That's the part I'm not sure gets folded over. I am actually thinking it doesn't get folded but am trying to figure out how the factory attached the fender here.
  6. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    Thanks for the info, I'll look into it as well and see what I can find out. If you think my wheel openings are bad, my rockers are truly next level. Pretty much the entire panel is filled with expanding foam then covered on bondo on each side. However, there are places where aluminum flashing was pop riveted to the bondo and fibergl***ed over. I'm kind of like you on this one. I'm not too worried about messing it up, because anything I do to it will be an improvement.
  7. Ratatouille
    Ratatouille
    from France
    Great work, next time, build an hi-boy hot rod ;)
  8. Nailhead Jason
    Nailhead Jason
    On my 51 it rolls over and is spot welded through, I was lucky and mine are not that bad at all. I just took the inner removable wheel well covers off and removed mounts for fender skirts from them so they wouldn't cut the tire, shome how I manages to squeeze an 8 inch wheel and a 255/60 in the rear wheel wells with out having to even mess with the lip, and no rubbing either.
  9. Devin
    Devin
    from Napa, CA
    Jason,
    Thanks a lot for the info. Big help! I welded in the top part of the fender. So nice to actually work with clean, shiny metal! ImageUploadedByH.A.M.B.1445304198.418864.jpg ImageUploadedByH.A.M.B.1445304216.743020.jpg
    kiwijeff, 117harv and 50 customcoupe like this.
  10. Nailhead Jason
    Nailhead Jason
    Nice work man! If you every need pics or measurements. Hit me up. I can get it to you no prob. Im driving mine pretty much daily at this point
  11. Nailhead Jason
    Nailhead Jason
    If you ever swap rears an 80 s monte carlo rear pulls the wheels in about an inch on each side. Works great for bigger tires or if its bagged for a little more clearance.
  12. Nailhead Jason
    Nailhead Jason
    ^^^^riding the ferry on the way to TROG!!!!^^^^
  13. Devin
    Devin
    from Napa, CA
    Sweet! Good to know about the rear. I have a '56 Chevy rear stashed away but it needs to be gone through so I only have $50 invested at this point. Have fun at TROG! It's definitely on my to do list.
  14. Nailhead Jason
    Nailhead Jason
    Measure your rears. A 56 rear will bolt right in but I believe its an inch wider overall. Mine had some abortion looking set up in it with blocks to slam it and shot springs and i think an astro axle. I put a ch***is engineering spring kit in it. Best thing I have done to it yet!
  15. layedout49
    layedout49
    Keep it going bud , looking good !
  16. Devin
    Devin
    from Napa, CA
    Thanks! I'm heading back out to the ship for a couple weeks. I hope to have some EMS sheet metal waiting for me when I get back.
  17. Nailhead Jason
    Nailhead Jason
    Let me know if you need little bits and pieces for interior or weird little brackets. Im dragging home a complete 50 parts car tommorow. Rusted to hell but tons of good small parts.
  18. Devin
    Devin
    from Napa, CA
    Hey Jason, thank you! Not even sure where to start regarding the interior. I'll see what's missing and touch base when I get back. Thanks!
  19. Devin
    Devin
    from Napa, CA
    Just got back from a long business trip and noticed an ad for a 49 Chevy frame on Craigslist for free. Went and picked it up from a cool guy. The frame is cherry, the guy wire wheeled it and rattle can primed it to boot! The only issue is the p***enger side body mounts were cut off for some reason. This ch***is will be a great way to be a step ahead once I remove the body for dipping or blasting. The current ch***is is very pitted and I'm sure there an element of rot to contend with. ImageUploadedByH.A.M.B.1449028308.977306.jpg
  20. Bruce A Lyke
    Bruce A Lyke
    Nice pickup on the free frame.
  21. Devin
    Devin
    from Napa, CA
    Finally got back on it today. It's been a while! I started mocking up the frame, rear end and some retired NASCAR truck arms I scooped up to get a sense of space etc. ImageUploadedByH.A.M.B.1451280036.222911.jpg ImageUploadedByH.A.M.B.1451280055.717779.jpg ImageUploadedByH.A.M.B.1451279967.004935.jpg ImageUploadedByH.A.M.B.1451279992.751162.jpg
    I'm going to notch the frame for clearance. I'm not looking to lay frame or anything so I'll probably cut the notch downs some.
  22. Devin
    Devin
    from Napa, CA
    I was in SoCal for Christmas and picked up some doors that are in nice shape overall. One of the doors was cracked at the check strap mount. Welded that up today also. ImageUploadedByH.A.M.B.1451280231.754533.jpg ImageUploadedByH.A.M.B.1451280244.744399.jpg
  23. Bruce A Lyke
    Bruce A Lyke
    Good to see the progress
  24. Devin
    Devin
    from Napa, CA
    ImageUploadedByH.A.M.B.1451358267.094300.jpg started section on another deck lid, the other one I was working on was so rusty and pitted. I kept burning holes in the paper thin metal and trying to fix it was getting aggravating. This one is coming out much nicer. Instead of cutting out a section first like I did on the last one, I made reliefs in the inner frame to separate the bracing and then cut around the perimeter of the skin. I pushed the skin into the surrounding metal and relieved the stressed areas until it looked right. Once i felt it was dialed in I secured the skins together with Clovis and trimmed the excess. I got it tacked up tonight but it was too dark to photograph. More pics this weekend!
  25. Devin
    Devin
    from Napa, CA
  26. Ratatouille
    Ratatouille
    from France
    It's a long way to the top if you wanna rock'n'roll!, great job, happy new year Devin:)
    Peanut 1959 likes this.
  27. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    You're a brave man. I've toyed with the thought of this a few times, then I stand back and realize I have a million other things I have to do before that I time comes. I like how you used the pie cuts. Well done.
  28. motoandy
    motoandy
    from MB, SC
    Looks great. Stay at it
  29. Devin
    Devin
    from Napa, CA
    Thanks fellas and happy new year!
  30. Devin
    Devin
    from Napa, CA
    ImageUploadedByH.A.M.B.1451788554.936920.jpg hit a few mor minutes into it today. The end result is OK, it's lim pier than Oprah's *** and will need some filler but I'm pretty happy with the overall shape and profile.
    Ratatouille likes this.
