Technical 1932 ford cabriolet windshield pics
Discussion in 'The Hokey Ass Message Board' started by thirtytwo, Jan 1, 2016.
  1. thirtytwo
    thirtytwo
    I was curious if I could get any detailed pic of the windshield and how it mounts ect...
    I have never inspected a cabriolet before ... I've got a really rough body with nothing else . I would like to make something as origional looking as possible ~thanks
    kidcampbell71 likes this.
  2. deucendude
    deucendude
    from norcal
    I believe they had a piano type hinge like the B400. Check on the ford barn.
  3. crminal
    crminal
    image.jpg I can send you whatever you'd like. The windshield is fixed, as you know. Not sure what you mean, "how it mounts".
  4. thirtytwo
    thirtytwo
    Honestly I was unsure if it swung out like a model A or it was fixed .... So it's a frame that's fixed ... How does it seal and how is frame held into the body?... Thanks again
  5. cabriolethiboy
    cabriolethiboy
    It is fixed. Screws in from the back side. Nuts are made into the windshield frame.
    timwhit likes this.
  6. thirtytwo
    thirtytwo
    Ahhh,...thanks.. How does it seal ? does it have a rubber gasket between the body and screw holes ?
    I had a frame that I could of made work too... I cut it minto a roadster windshield .... Bummer
  7. crminal
    crminal
    The frame is part of the body. The gl*** ***embly is rubber mounted in the framework. If anyone knows where to get that rubber, let me know. The rubber on mine is hard as a rock!
  8. thirtytwo
    thirtytwo
    You mean it has rubber in the side like a roadster windshield , instead of a gasket between the a pillar and the frame?
  9. timwhit
    timwhit
    Thirtytwo: I believe this is the cabrio that belongs to cabriolethiboy. See if he has pics of the windshield frame installed, inside and out. tim 004.JPG
  10. crminal
    crminal
  11. thirtytwo
    thirtytwo
    Thanks, kinda still can't tell if the gasket is sandwiched between the frame and body or it hooks to the windshield somehow , I guess drake does make a gasket for it according to the catalog image.jpg
    Could I get you to snap pics of what the back of the a pillar looks like and the door tops? What is on there for molding/ garnish?~ thank you
  12. cheap-n-dirty
    cheap-n-dirty
    from that picture it looks like how a pick up windshield is held in. they pivot with a piano hinge at the top.
  13. thirtytwo
    thirtytwo
    Yeah it does ...and for a long time I thought that's the way they were , which actually makes more sense to me ...
    , but if you look at cabriolet hiboy 's picture my a pillars do have corresponding holes
  14. RICH B
    RICH B
    Just lean it against the posts, like in the old days.
    kidcampbell71 and timwhit like this.
  15. thirtytwo
    thirtytwo
    Seems legit ... Traditional bailing wire
    The guy at the swap meet told me it would fit
  16. didn't you have a Cabriolet ? or was that a sport coupe?
  17. thirtytwo
    thirtytwo
    Ha ha yep ... And that had a homemade windshield too! .... It was just flat bar with counter sunk screws
