Projects My '33 PU, a truck, a build, a story *Done For 2016*
Discussion in 'Traditional Hot Rods' started by Flowmeister, Nov 16, 2015.
  1. It's the 19 Dec now, any updates?
    Great work and dedication.
  2. Thank you! @racer-john
    Yes, December 19th already. This year flew.
    Nothing really substantial for updates, I have been working on the doors, hood and grille.
    Trying to finalize everything on them so they are on and bolted for good.
    The grille with this truck was rough, a few tears along the outer lower edge, it was missing the inner chin shield, and one lower bar.
    The grille I bought when I was gathering parts for the meat truck, was salvageable, but had bottom rust issues. I had removed the inner shield and sandblasted it quite a while ago.
    So now, I am fixing rust on it and it will get welded in this one.
    This one also had brackets brazed onto the lower sides for some reason, and the bottoms were mangled pretty bad,so I decided the best repair was to cut out sections from the other, as well as the bar and weld them in.
    A friend of mine also has a '33 truck grill that needs the top fixed, so although I hate to sacrifice an old
    truck part, it is going to make two other grilles really nice.
    Here are a few pictures of that. 928466_604125546332975_1026174255_n.jpg 1941177_651400961592922_1571330874_n.jpg Grille side.jpg IMG_20151213_163657.jpg IMG_20151213_163705.jpg IMG_20151213_163713.jpg
    T-roaster, jerseyboy, K13 and 6 others like this.
  3. 64_Vette
    64_Vette
    from alabama
    Do you have any photos or detail description on how you "hammered the little reveal that goes around the hinge" ? How did you handle the corners of the reveal ? Would love to do the same to my 36 Chevy doors. I am a newbie to metal shaping, so I can't image what you did to accomplish this reveal. Any help/advise would be appreciated. Thanks !
  4. Hey, @64_Vette I looked through my pictures and realize I didn't take any of that process,
    so, I just went out and hammered one out and took a few pics to show how I did it.
    Started with tracing the hinge profile onto the metal
    Roughly cut out the center excess, leaving about 1/4" inward
    I just used square headed hammer and a 2" slice of railroad track, but any
    clean edge of a vice would work.
    I hammered the line slowly about 1/4" outside of my sharpie line,
    You end up flipping the piece over and back doing a lot of tapping
    to get the desired shape and depth.
    Once you are happy with that, use snips or a little grinder to evenly clearance the inside
    to your hinge. This one isn't great, but gives you an idea how I did it.
    Also, on my door, I hammered that into a larger than needed piece, then trimmed
    it to the size of the patch I needed.
    Hope this helps IMG_20151221_150340.jpg IMG_20151221_151321.jpg IMG_20151221_152628.jpg
  5. 64_Vette
    64_Vette
    from alabama
    Perfect ! Thanks for the photos and the quick response. I have learned soooo much from guys on the H.A.M.B.
    Flowmeister likes this.
  6. 2deuces64
    2deuces64
    This is an EXCELLENT!!!!!! thread.
  7. Ford52PU
    Ford52PU
    from PA
    All I can say is you do amazing work. It was a pleasure to go thru all 6 pages so far. I'm subbed to this and will keep watching.
    Best wishes on the health issues so sorry to read this, it seems to happen to so many anymore but you seem to have the right at***ude and I think thats the key. Merry Christmas to you and yours, and good luck in 2016!!
  8. Thank you very much! @2deuces64 & @Ford52PU
    Likely won't be any updates till after the holidays.
    Merry Christmas to you and yours as well!
    @64_Vette You're welcome, Glad you are learning from the HAMB.
    This place is great for that!
  9. b-bop
    b-bop
    Fantastic build thread Kelly, no wonder I have not seen you around all summer. Can't wait to see it rippin' up the pavement.
  10. Thank you Barry! @b-bop
    Hopefully we can log some miles together!
    You are a veteran of epic road trips.
    b-bop likes this.
  11. timwhit
    timwhit
    I admire your tenacity!! love the thread/truck. Look forward to more. How are you doing? Here's a pic of one I sold to build my cabrio. Tim 100_0004.JPG 100_0107.JPG
  12. Thanks! @timwhit
    I'm doing ok. I really like the looks of your truck,
    must have been hard to let it go.
    I'm ****oning up a whole list of small details right now, so nothing
    worth posting at the moment. But please stay tuned.
  13. stalle61
    stalle61
    from sweden
    I like your build thread
    I need new door hinges to my 34 pickup,
    the ones i have are just too worn.
    Do you know if there are any other i can use?
    Thanks
    Peter
  14. 383deuce
    383deuce
    Kelly, Looks like you are keeping after it and it is looking great. I know just what you are saying about all the small stuff taking a lot of time with not much to show. I spent 3 hours yesterday just making a stainless steel ring to put over the shift boot. But I could not fine one the right size I had no other way to go.
    brad2v likes this.
  15. Thanks! @stalle61 I don't know of others that will work.
    If you have all your hinges, you can drill them and make bigger pins,
    or drill and bush the stationary part that bolts to the pillar, then size it for new stock pins.
    @383deuce Ain't that the truth. Lot's of little things to check off the list.
    But they all gotta get done.
    The last few weeks have been real frustrating for me, I have been fighting a cold
    that never really goes away, due to my compromised immune system.
    So not a lot has gotten done.
    However, I did take my radiator in and get a leak fixed, took my generator in and had new brushes, springs, and bearings done, then they set it up with my regulator. I also changed my fan mount/
    pulley and gained another inch of clearance to the rad.
    I finished working my grille and threw some paint on it.
    It's not great, but it's gooder
    Same goes for my hood tops and side panels. I also riveted the new hood hinge to the tops,
    installed my cowl lacing and bolted that all together for the last time.
    Still finalizing things on the doors/ hinges, and latches, but have started to straighten out all the box
    structure. All of the cross pieces were bent/ bowed pretty bad, and some rust issues to repair as well.
    Hoping to have some good update pictures soon, but for now here is another front shot.
  16. waxhead
    waxhead
    from West Oz
    A little bit of progress is better than no progress.
    Jet96, volvobrynk and Flowmeister like this.
  17. redwelter
    redwelter
    Wow you've done a ton of work since I last checked in. Great work so far and how cool to actually drive it for the first time!
    Red
  18. Thanks @redwelter Yes, driving it for the first time was so cool!
    All the time we spend building Hotrods, imagining what it will be like to open that garage door
    and drive it out. The work pays off.
    I should have a fairly big update in about a week.
  19. flip
    flip
    Just finished your complete thread. Great work but story is amazing. Would have been very easy for you to become discouraged with your health issues. Hope things are going well for you on that front. You are truly an inspiration. God Bless
    Flip
  20. Chris
    Chris
    Go man, go! I've been driving mine, the weathers been so nice
    Hotrodmyk and Flowmeister like this.
  21. Go Kelly!
  22. shopdawg
    shopdawg
    from alberta
    Your epic trip is sure sneaking up fast, wishing you the best of luck. It goes without saying, but if there is anything you need just call.
  23. 56pickup
    56pickup
    from Wisconsin
    I dont post much but i really enjoyed reading through your thread! I am also building a 34 pickup and have been collecting parts
    Jeff34 and Flowmeister like this.
  24. dentisaurus
    dentisaurus
    from Boston
    Great thread, really informative. I'm sure your trip to the round up will be epic!
  25. dumprat
    dumprat
    from b.c.
    Where did you get the cloth wire from? I need some pretty soon.
    dearjose likes this.
  26. @dumprat I bought it from George Moir, his selection wasn't great.
    Sacramento Vintage Ford has a great kit, but our dollar is ****ing, as you know.
  27. dumprat
    dumprat
    from b.c.
    Ok thanks. I will call George. I dont need that much just for the bits or the harness through the engine compartment.
  28. JimmyD3234
    JimmyD3234
    from PA
    looking - GOOD - I like IT :cool::cool:
  29. 383deuce
    383deuce
    Kelly,
    It is looking great.....Keep it going.
  30. What's the word, bird?!
