Customs '54 Chevy 210 post build
Discussion in 'The Hokey Ass Message Board' started by cretin, Mar 30, 2015.
  1. cretin
    cretin
    @deto , Hey, No I don't have any dies for the belt line. I did have plans to make some though, once I got around to the area I need to repair on my car, most likely near the end when it gets a chop.
    But I don't mind making the dies sooner if it helps you out. What sections do you need to repair?
  2. cretin
    cretin
    I need to order material for the T project and couldn't make any progress on that, so I messed around with the '54 today. While I don't like to admit it, I made a mistake somewhere along the way, and I wasn't really happy with how the eyebrow fit with the top part of the bezel, so I addressed that first. After that, I turned my attention to the small transitions on the side. While I had easily made the transition from the eyebrow to the body line, I was having trouble visualizing the transition from the bottom section of the headlight to the eyebrow/body line transition. So, I just started working on it, and the photos are what I came up with. It turns out that it was hard to get a good photo of it. Light lines were playing tricks in the photos, but I'm pretty happy with how it looks in person.
    Here is the transition from the front.
    And here is the profile.
  3. K13
    K13
    Nice work not sure how I missed this thread!
  4. The37Kid
    The37Kid
    Always good to see progress on this build, lots of nice fine details. Bob
    Spoggie likes this.
  5. 50blackbird
    50blackbird
    Great build...subscribed
    cretin likes this.
  6. nowaxn5
    nowaxn5
    Looks great!
    Can I ask what your plans are for the trunk? My brothers '53 has the notch and suspension done and the next project to get ****oned up is the trunk floor. We are looking for a game plan.
    Thanks,
    Jerry
  7. cretin
    cretin
    Sure, I planned on making a removable bulkhead behind the seat, and behind the notch which will go behind interior. I want to make both sides removable so I can get good access to the rear suspension if need be. Also, because my valves, and tank mount on top of the notch.
    As for the rest of the trunk area, I had also planned to make a removable floor. A lot of people use the mustang tank as the trunk, but I want to make a trunk floor panel that goes above it. My plan is also to have removable sections on the sides of the trunk. One side will house the battery, and one will have a hidden storage space for things I want in there permanently, but don't want rolling around in the trunk all the time.
    I would most likely fasten all these panels except the trunk side panels with Dzus fasteners. Trunk side panels would just be a press fit.
    Hope that helps. If you have any other questions, let me know.
  8. SpazTaztic
    SpazTaztic
    Did the firewall or tunnel need to be modified to fit the 350/350 combo originally? I would like to get back on my 54' 210 project to get it going as a daily too.
  9. cretin
    cretin
    The 350/350 combo was in it when I bought it, but it appeared the only modifications made to the body for it was t******* the firewall ribs around the valve covers, and of course a hole in the floor for the shifter. The rest of the firewall, and tunnel were still stock.
    This didn't leave much room for a fan, but I found a thin Spal fan that did the trick.
    19ChevyFleetline50 likes this.
  10. SpazTaztic
    SpazTaztic
    So would the stock style new aluminum radiator fit in stock location, or would it need to be moved forward?
  11. brady1929
    brady1929
    Your work is amazing!
  12. cretin
    cretin
    I used a stock style walker for a small block and I left it in the stock position. But there is room to move it forward depending on what parts you plan to use.
    Thanks so much.
    This car has been neglected for too long. I have another project that I want to get into, so I debating getting this ready to sell. I really wanna finish it too though.
    cpd682 likes this.
  13. K13
    K13
    Did you get a '36?
  14. cretin
    cretin
    I have yet to pick it up, but yes getting a '36 3 window. I've gotta find room for it, but don't really want to part with anything. haha.
    kidcampbell71 likes this.
  15. cretin
    cretin
    I finally made a little progress on the 'ol poor '54. I'm going to have to move it soon, so I decided to to get the front sheet metal work wrapped up so I can bolt it back on. Then my goal will be to take care of a few other sheet metal issues, and get it back on the road.
    I finally wrapped up my my headlights, at least for the time being. There is still a little bit of tuneup I want to do, but in the interest of getting the car on the road, I'm going to move on and fine tune it later on.
    So the next step is the hood. Time to peak and one piece the hood, then round the corners.
    So, I fit and clecoed in the front peak. After much deliberation, I decided to go with a peak that fades out like the stock piece instead of running it the length of the hood.
  16. The37Kid
    The37Kid
    Nice to see you back on the '54, will that be hammer and dolly work or English wheel smoothing? Bob
  17. cretin
    cretin
    Today I got the peak fit and tacked in, and got the top piece made and clecoed in.
    Wrench666 and slo-dat like this.
  18. cretin
    cretin
    It feels good to make some progress on it.
    I will use a hammer and dolly to finish it. Maybe planishing hammer if I can con one of the other guys to stay late and help me hold it.
  19. cretin
    cretin
    I got a bit more time in on the hood after work today.
    One of my friends at work gave me the idea to make a little radius detail at the end of the peak on the front of the hood. I thought it was a great idea so I went for it.
    I made a patch for the front that included these radii, and the flange under the front of the hood.
    It took longer then I expected it to to get the patch right, but I think the effort was worth it. I think it gives the peak a much more finished look.
    It still needs a little fine tuning, and I'll probably get to that tomorrow. Then I can finish the rest of the peak patch, then get rid of the holes and welds seen in the above photo.
    jakespeed63 and kiwijeff like this.
  20. The37Kid
    The37Kid
    Nice, guess you have to round the corners now. :)Bob
  21. cretin
    cretin
    That's right! I have a rounded corners fetish, so that's always been the plan, now this can be a nice tie in to that,
    I'm always looking to round corners!
  22. rod1
    rod1
    Sweet stuff,******.Serious talent...
  23. cretin
    cretin
    Thanks!
  24. Finnrodder
    Finnrodder
    from Finland
    Looks great!
    How did you form the peak,with beadroller?
  25. cretin
    cretin
    Thanks!
    I used the Pullmax. We happened to already have a die made that worked for the peak so I used that.
    I describe making that piece in post #21.
    Had I not had access to a Pullmax, I most likely would have used a bead roller.
    To make the front section with the radii at the end of the bead, I used the Pullmax for the peak, the bead roller to establish the line for the radii, then tuned it up by hand. Lately the brake to make the flange.
    Unfortunately, I didn't get any photos of the process of the front piece. It took me a couple test pieces to get it figured out.
    Stogy likes this.
  26. cretin
    cretin
    Put in some more time on the hood today. Since I'm not going to be able to get the hood done before I have to move the car like I wanted to, I decided to concentrate on the front of the hood, and I'll do the top after the move.
    I cut out the welds seen in the last post and filled that an the holes from the last post. Rounded the hood corners, then welded up the peak patch. I began hammering and finishing the welds, and got up to about the center of the curve on the hood before I decided it was quitting time.
    I still need to ****m and smooth out this whole front area. I'll probably do that after removing the rest of the welds that are there and before doing the hood top.
  27. Finnrodder
    Finnrodder
    from Finland
    That peak sure looks great.I wish i have the access for Pullmax too,but i guess the beadroller is my way to go.Keep up the good work!
  28. K13
    K13
    Looks great Kyle. The detail at the end of the peak is fantastic.
  29. cretin
    cretin
    Yea, I'm pretty lucky to have access to one. It's one of my favorite tools.
    And thanks, I'll try to keep it up!
    Thanks! I really like the detail at the end of the peak too. I'm glad my friend gave me the idea. I've been looking at other hoods since I did it, and I think it makes it look like it was always intended to be that way. I can't wait to see it back on the car.
  30. cretin
    cretin
    The car said goodbye to what's now the old shop today.
    And it's now at its new resting place at my parents place.
    Now that tax season is over and the car is back here, my old man should be able to lend a hand with it, and hopefully this and the T can see the road again soon.
    I'm happy with how the front end is coming together. I think it's going to look great once I do the fender side of those rounded hood corners.
