  1. tommyd
    tommyd
    from South Indy
  2. tommyd
    tommyd
    from South Indy
  3. tommyd
    tommyd
    from South Indy
  4. tommyd
    tommyd
    from South Indy
  5. tommyd
    tommyd
    from South Indy
  6. Kentuckian
    Kentuckian
    There were two different Ford truck hood scoops. The first was used on 53-56 bigger Ford trucks known as the "Big Job" truck. That scoop went on a hood that had a raised ridge down the middle.
    The one that became popular on racecars (including the super duty Pontiacs) were first used on the larger 1957 Ford trucks which was redesigned with a flat hood. The larger F-series trucks were called Super Duty and had an emblem identifying them by that name. These scoops were used on the Super Duty Ford trucks from 1957 through the late 60's and were functional using a dash mounted cable to open and close a flapper mounted in a raised box on the air cleaner.
  7. Yep, what he said. '53-6 were mounted in the center of the hood facing forward. '57 and up were mounted on the right side of the hood facing backwards.
    hipster, Bowtie Coupe and loudbang like this.
  8. noboD
    noboD
    Is this the same body that became the convertible Dart that is in the Garlits museum?
  9. DDDenny
    53-56 correct
    Bowtie Coupe likes this.
  10. 296ardun
    296ardun
    Pretty sure that this is Woody Gilmore's house car, the "Charger" at Lions
    Don't have an ID on this one...
    The "Thresher Special," from Kansas...this was originally the Cook & Bedwell car that set a world's record in 57, only to have it broken by Garlits...now running a flathead
    Mr Flathead, John Bradley, at the first Smoker's meet, '59
    No ID on either
    OCIR...looks like a top gas car against an injected fueler...hermanpullersgarage suggested Enriquez & Adams near side, against Bill Schultz gas car...I don't remember E&A being that long, but it certainly could be...blew up the picture and the side body panel says "Schultz" so that is Bill Schultz...thanks for the ID...see below also
    No ID, looks like a Ford, anyone else?? This was when AHRA sanctioned Lion's...hermanpullersgarage suggested maybe Gary Cochran without the roadster body...could certainly be, not many racers ran wedge Fords...appreciate the IDs on both
  11. bowie
    bowie
    Kentuckian : I appreciate your good info. I've never seen one of the earlier type before.
  12. tommyd
    tommyd
    from South Indy
  13. tommyd
    tommyd
    from South Indy
  14. tommyd
    tommyd
    from South Indy
  15. tommyd
    tommyd
    from South Indy
  16. tommyd
    tommyd
    from South Indy
  17. 296ardun
    296ardun
    Forsberg & Hubbard....I was there that day they ran San Gabriel...very quick off the line...Algon Injectors, they ran for top eliminator that day, if I remember right, they went several rounds against the blown fuel Chryslers...
    tommyd, Bowtie Coupe and hendelec like this.
  18. tommyd
    tommyd
    from South Indy
    Identified as Ed Prout by nickthebandit.
    hendelec and loudbang like this.
  19. jivin jer
    jivin jer
  20. jivin jer
    jivin jer
  21. jivin jer
    jivin jer
  22. jivin jer
    jivin jer
  23. NHRANUT
    NHRANUT
    from Western PA
    That photo is from 1971. The stance is a a dead giveaway that it is a later photo.
  24. loudbang
    This one could be Ed Prouty out of Bristol Connecticut. Sure looks like it.
    from post 47605 by 296ardun
  25. stillrunners
    stillrunners
    from dallas
    post 47538 - early early Bob Langley Scorpion - with what youse guys call weed burners ?....maybe at Caddo Mills....(not sure if that pic was tagged before)
  26. Gabe Fernando
    Gabe Fernando
  27. fiveoh108
    fiveoh108
    Great picture
  28. rooman
    rooman
    Nope, this is one of two mid engine Darts, both of which crashed very early in their careers, prompting the creation of the dragster framed roadster.
    Roo
  29. 296ardun
    296ardun
    Thanks, I added the info to the original post.
  30. wbrw32
    wbrw32
    Stillrunner...This is NOT a Bobby Langley car...
    296ardun likes this.
