My Planishing Hammer Plans
Discussion in 'The Hokey Ass Message Board' started by rodknocker, Feb 26, 2006.
  1. rodknocker
    rodknocker
    a had few requests for plans for the hammer i built for about $60.so here goes
    material cut list:
    1.5"x1.5"x.25"thick square tubing---2pcs@36"
    1pc @3.5"
    1pc @7"
    5"x.25"thick plate----2pcs@9"
    1pc @11"
    1 harbor freight air hammer,you need to make sure its at least 3800-4600bpm,i have the $14.99 model,it works fine
    2 exhaust clamps to hold the hammer to the 11" plate
    3/4" nut and carriage bolts to make into the dolly of the hammer,it ground and filed mine and have a couple different contours.
    1/2" turnbuckle i got mine from graingers for about $16
    1/2" bolt and nylock nut for the hinge part
    1 bungee cord to hold the turnbuckle from spinning when you're it.
    hopefully the pictures show you how it all goes together
  2. jaybee
    jaybee
    I like it, brilliantly simple design and plenty adjustable.
  3. speedway
    speedway
    from wichita ks
    not sure i understand what the turnbuckle is for? does the upper and lower arms pivot on the bolt in the center of the upright? if so how much adjustment does it give you? Thanks for the post and the idea.
  4. 51 MERC-CT
    51 MERC-CT
    Looks like it should work. DON'T FORGET THE EAR PLUGS:)
  5. rodknocker
    rodknocker
    the turnbuckle gives you room to work with different thickness metals plus it allows you to open it up to get to say an interior portion of the fender
  6. RodLand
    RodLand
    I would like to see more on the hammer and anvil detail.
    Looks great!
  7. 64ragtop
    64ragtop
    Rich people have it done!!! Thus the Boyds, et al! but some folks make a nice livin off the rich folks, and that helps the world go 'round.
  8. rodknocker
    rodknocker
    hope this helps, i couldn't get all of the pics up
  9. rodknocker
    rodknocker
    1 more
  10. rodknocker
    rodknocker
    again
  11. RodLand
    RodLand
    OK what I see is the hammer head is sto bought, the anvil is the one you made from carrage bolt. I see said the blind man, to his deaf wife, over the disconnected telephone.:D
    Once again, great job
  12. treb11
    treb11
    If you put a locking nut on the threaded eye portion of the turnbuckle, you can probably lose the bungee cords
    swervyjoe likes this.
  13. jdoolin
    jdoolin
    from dayton,oh
    did you make your tooling,[hammer&dies]. thanks jdoolin
    p.s. it looks nice.
  14. rodknocker
    rodknocker
    nothing fancy, just ground down the carraige bolts to different dome sizes and one i heated with a torch and pounded flat
