Projects 1934 Ford Sedan Gender Reassignment Surgery
Discussion in 'Traditional Hot Rods' started by flatnasty, Jan 14, 2014.
  1. Runnin shine
    Runnin shine
    Flat, do mind sharing how long your rear shocks are? Extended and maybe roughly with the ch***is on the ground?
  2. Flat nasty your ride is flat nasty and getting shiny....looks awesome man love it!
  3. pumpman
    pumpman
    After you polished the tube did you clear it with something?
  4. flatnasty
    flatnasty
    from Vancouver
    Thanks fellas!
    Runninshine I'll messure those shocks and post the info for you tomorrow.
    Here's what I did this weekend.
    Mocked the quick change in. wanted to be sure that nothing will bite me in the *** later. then I polished and mounted the bung on the turque tube to hold the radius arms.
    pretty happy with how it's looking so far.
    I'm looking for an old chrome mode T rear spring if anyone has any leads it would be greatly apreciated.
    Pufff, ls1yj, kidcampbell71 and 2 others like this.
  5. Man, that rear end is cool !
    PA Gas likes this.
  6. rat nasty
    rat nasty
    Damn nice man keep the updates coming lots of great ideas and as alway awesome work!
  7. rcnut223
    rcnut223
    from wisconsin
    Looks cool
    How much air do you have in those rear tires?
  8. ss34coupe
    ss34coupe
    The chrome looks great!
  9. flatnasty
    flatnasty
    from Vancouver
    Running shine was asking the mesurements of the shocks I put on the rear. 16'' total length and 13.5 at ride hight.
    Rcnut 223
    I haven't checked the tire pressure lately but I would have set them at 35psi
    thanks for all the compliments fellas!
    Runnin shine likes this.
  10. flatnasty
    flatnasty
    from Vancouver
    Got some more work done on the hot rod this weekend through all the holiday rush. Also a little Heads up I have decided to Start posting the progress of the hot rod and all the other cars that I'm building on InstaGram so if you want to check it out I will be starting this week @FLATNASTYCUSTOMS. Of course I won't be stopping my build thread here on the Hamb
    Anyway i started work on a tack drive ***embly. First thing I had to do was cut the big nut off the end of the 90 degree drive unit. There is absolutely no room for it so it had to go. then I sanded the face smooth.
    After that I made up a holder for it. it's not done yet just kinda ruffled together. I will finalize it this week and post how it turned out. 2015-12-27 23.00.22.jpg 2015-12-27 22.50.19.jpg 2015-12-27 22.49.50.jpg
    Pufff and bct like this.
  11. flatnasty
    flatnasty
    from Vancouver
    Got some more work done on the tack drive.
    Modified the bolt for the front crank pully. Started by machining those narly claws off for the hand crank. then I drilled the Centre out. Made a weld in bung with a keyed hole for the drive pin. I even made the bung out of a old ford king pin to keep it period correct. lol pretty basic ****. 2016-01-03 22.07.13.jpg
    Here it is all mounted up.
    Thanks Brad
    FLATNASTYCUSTOMS on instagram
    Pufff, '52 F-3, wedjim and 3 others like this.
  12. flatnasty
    flatnasty
    from Vancouver
    I decided it was time to revisit the roll pan. I was never really happy with it. So I cut the ****er off and louvered the **** out of it. lol 2016-01-10 23.53.10.jpg Thanks Brad
    2deuces64, Pufff, texkbc and 5 others like this.
  13. '52 F-3
    '52 F-3
    from Central PA
    very nice.....
  14. rcnut223
    rcnut223
    from wisconsin
  15. Bottomedout39
    Bottomedout39
    from Reno NV
  16. 1951hudson
    1951hudson
    Really nice addition!
  17. 3blapcam
    3blapcam
    Looks sweet! I love the roll pan... but won't the louvers catch a lot of debris facing that way?
  18. brady1929
    brady1929
    Love the louvers
  19. Smokeshow
    Smokeshow
    Keep up the great work! I think you single handedly raised the value of all 4 doors after you made this one look so easy :)
  20. flatnasty
    flatnasty
    from Vancouver
    Built a simple battery box for the hot rod this weekend. 2016-01-18 18.59.47.jpg
    My plan is to mount an optima sideways in side the rail. 2016-01-18 19.00.13.jpg
    After that I remounted the body so I can get my seat and gas tank mounted. 2016-01-18 18.45.26.jpg
    I'm looking for an old chrome T rear spring if you fellas have anything.
    Thanks Brad
    Pufff, Drewfus, wedjim and 4 others like this.
  21. pumpman
    pumpman
    Damn, that hot rod looks like it's looking for fight.
    Hansa1100 and bigheadbaxter like this.
  22. Really love this build and your chop height especially. I like how the angle of the A pillars matches the slant of the back edge of the hood opening. I'd be curious to see how it'd look with the grille shell leaned back to match. Would this be too 'cartoony' or 'Foosey' looking?
    jerseyboy likes this.
  23. Hey Brad, That car is looking ready for some salt or a dry lake!!!
    Nothing cartoonish or Foosey about it!!!
    Keep up the AWESOME FAB WORK!
    Joe
  24. Fordgasser1
    Fordgasser1
    from Jersey
  25. yes, this is awesome work & I didn't mean to imply that it is cartoonish or foosey looking - this is way more bad-*** looking than what chippy could come up with :D
    530sandman likes this.
  26. 383deuce
    383deuce
    IT IS LOOKING BAD *** TO ME.........GOT A GREAT **** ON IT NOW ALSO.
  27. Robert Crosse
    Robert Crosse
    from WNY
    Damn I LOVE this build!!! :cool: DSC08217.jpg
    Bob
  28. flatnasty
    flatnasty
    from Vancouver
    Been slacking off on posting on the old terd so here we go. In my defence most of the stuff I have been working on hasn't been real post worthy.
    Got going on my seat. it's an original 4 Dr seat. It has this big lump area in the small of your back so I decided to ditch it and fill it. then I punched it full of louvers.
    I got the tail lights under control as well. I decided to go with the predictable but staple 37 ford units. Made a small bracket and bolted them to the roll pan
    Finally I mounted the gas tank. I decided on a tanks tank and made a some brakets to mount it in the trunk.
    I am putting together a big push to tie up all the loose ends on this thing and get onto the body work.
    Anyone have an old chrome T rear spring? it's the only thing I'm missing.
    Thanks Brad
    Pufff likes this.
  29. JimmyD3234
    JimmyD3234
    from PA
    SIR , you have P*** the TEST -- 100+++++++++++++++++++++the CAR is SO - BAD - *** - nice work - good LUCK :D:D :cool::cool:
