Projects 26 T Roadster Pick Up build Thread
Discussion in 'The Hokey Ass Message Board' started by Blue One, Mar 27, 2010.
  1. 26 T Ford RPU
    26 T Ford RPU
    That looks very sharp, a glimpse of whats to come............cool!!!!! :cool::cool: JW
  2. dakotajayne
    dakotajayne
    from 3c1
    Looks great, nice detail work & interesting components!
  3. loudbang
    Wow that was exactly my very first USED and abused Tri-power set up way back in 1965. But it looked one hell of a lot worse than your beauty.
  4. rusty rocket
    rusty rocket
    I hear ya. You have a vision and your going to make it happen.
  5. Blue One
    Blue One
    from Alberta
    Front brakes have been ordered. :) The exchange on the dollar really hurts :( but what the heck :D.
    No one said that this project would be cheap :D
    brad2v, K13 and AndersF like this.
  6. daddio211
    daddio211
    Too bad Canada doesn't make hot rod parts, I'd be buying everything I could!
    Blue One likes this.
  7. Six Ball
    Six Ball
    from Nevada
    daddio211 likes this.
  8. Blue One
    Blue One
    from Alberta
    Here is their website rather than a blog link.
    http://www.candyshotrodsupply.com/
    They are a builder shop, not a parts supplier. You should check out the website to see some of their outstanding work including Jeff Norwell's 32 5 window.
    Very impressive work for a small shop.
    And, take note of the fact that the shop is in Ontario.
    That's Ontario Canada, not California. :)
  9. Blue One
    Blue One
    from Alberta
    Built some stands to put the RPU up at a better height for working, 12" high.
    Also got word that I should have my MT Products Lincoln front drum brakes in about a week. :cool:
    Larry.
    20160115_172652 (2).jpg 20160115_180124 (2).jpg 20160116_123235.jpg vented.jpg
  10. 26 T Ford RPU
    26 T Ford RPU
    Looking good Larry, top job as usual. :cool: JW
  11. keith27T
    keith27T
    Like those stands.;)
  12. Blue One
    Blue One
    from Alberta
    Got out to the garage and took the top off and stowed it away.
    I set the tri power on the mock-up engine and started to locate the gas pedal.
    I had bought one of the chromed s**** pedals that Kelly's hot rods sells here on the Hamb and now that I have it mounted, I can tell that I am going to have to do some slicing and dicing to make it work.
    What else is new ? :D
    I'll make it work and just Tig weld the modifications with stainless. That will discolor the chrome the least and if it is a problem I'll blast the pedal arm and paint it black. :)
    The s**** will still be chrome.
    I'm also making the link to the carbs mechanical with a rod, no throttle cable here :)
    Larry
    Pictures eventually :)
    Uncle Lee, Als27T, daddio211 and 3 others like this.
  13. 01mikep
    01mikep
    Nice work Larry. Your progress feedback always gives me ideas.
  14. Blue One
    Blue One
    from Alberta
    The gas pedal is a piece of junk, and will not work. I debated building my own, then decided to order up a good quality one from So Cal speed shop which will fit and work properly. :cool:
  15. 26 T Ford RPU
    26 T Ford RPU
    I had a problem with mine, I just couldn't get the cable to be where I needed it with the peddle where my foot was so I pulled it apart and reversed the bits, not 100% ideal but it worked. JW
  16. rusty rocket
    rusty rocket
    Now those drums fit the bill!!!!!!!
  17. Blue One
    Blue One
    from Alberta
    Yes, they are nice aren't they. :cool:
  18. 26 T Ford RPU
    26 T Ford RPU
    They are nice, if you decide you don't wont them.............can I have them?:D:rolleyes: JW
  19. Blue One
    Blue One
    from Alberta
    Won't happen :D :D
    loudbang and 26 T Ford RPU like this.
  20. Blue One
    Blue One
    from Alberta
    When I built my steering column I used 2.5" exhaust tubing for the bottom section and had it terminate at the floor where a u- joint p***es through the firewall to connect to the steering box.
    This left the u -joint exposed and the bottom of the column open to wind and water.
    So, to enclose the u-joint and close off the column I fabricated a stub with an end plate and a hole for the steering box spline.
    It had to have an access hole to get to the u-joint set screw.
    So I added that and made a cover for it. ( There is also a drain hole in the bottom so if any water gets in it will drain out.)
    I removed the steering column and welded the stub in place. When the steering column is bolted back in place it is now sealed and finished.
    A small detail, but needed. :) Larry 072 (2).jpg 073 (2).jpg 074 (2).jpg 075 (2).jpg 076 (2).jpg 077 (2).jpg
  21. loudbang
    Looks better with the new cover.
  22. Blue One
    Blue One
    from Alberta
    I just got 2 boxes full of brakes brought up to me by K13 from the shipping depot in Montana.
    Awesome. Thanks Ian.
    I'll open them up and will find my new MT products Lincoln drum brakes. :cool:
    Goodbye front discs :)
    daddio211, AndersF and brad2v like this.
  23. Blue One
    Blue One
    from Alberta
    These brakes are things of beauty. Wow. :cool:
    Uncle Lee, redzula, AndersF and 2 others like this.
  24. Six Ball
    Six Ball
    from Nevada
  25. Dennis Lacy
    Dennis Lacy
    My Dad and I are dealers for MT. They are very good products but there's a few things you need to be aware of because they aren't totally ready to use out of the box.
    1) The hubs and drums need to be bolted together with nuts and flat washers on all 5 studs, torqued evenly then lightly machined on a brake lathe to true the shoe surfaces to the centerline of the hubs. I find that it typically takes a .010" cut to accomplish this which will result in the drums being .020" oversize. Once you have done this and BEFORE the hubs and drums are taken back apart you need to mark them Left and Right then make indexing marks so that the drums are always mounted to the same hub and in the same position. Every pair of hubs and drums that are sold through our shop get true'd and indexed. I have never found a pair that don't require this.
    2) The brake shoes will need to be arch-ground to exactly match the diameter of the shoe surface on the drum. Even as the drums come out of the box before truing the shoes are rarely a perfect fit. Arch grinding is essential as it ensures that the full length of the shoes are contacting the drums.
    daddio211, loudbang and brad2v like this.
  26. K13
    K13
    They look great Larry!
  27. Blue One
    Blue One
    from Alberta
    They really do :) :cool:
  28. brad2v
    brad2v
    Boy, do they!
  29. Blue One
    Blue One
    from Alberta
    I posted my response to this over on my other thread. Not necessary and won't be happening.
    Got the word right from the source.
    http://www.jalopyjournal.com/forum/threads/traditional-style-front-drum-brakes.1002189/page-2
  30. Blue One
    Blue One
    from Alberta
    Spent some time and installed the gas pedal I got from So-Cal.
    Worked out pretty well. I didn't want to go with a throttle cable so I fabbed up a 3/16" diameter stainless steel throttle rod using a studded rod end for the throttle pedal end and a spring pin clevis on the center carb linkage arm.
    Then I built a stainless steel bracket off the front carb for a double throttle return spring to supplement the throttle shaft spring on the center Stromberg.
    The firewall "boot" is an old rubber bellows type thing off of an old Ford M/C.
    It works pretty well and the pedal is in a very comfortable foot position.
    Larry throttle pedal 001 (3).jpg throttle pedal 003 (2).jpg throttle pedal 005 (2).jpg throttle pedal 006 (2).jpg throttle pedal 007 (2).jpg :)
