Projects 1948 plymouth chop
Discussion in 'The Hokey Ass Message Board' started by uglybaby, Nov 16, 2015.
  1. uglybaby
    uglybaby
    from tri-cities
    sorry for the wait
    back to work on the 48
    ok so i goofed
    turns out the grills are not desoto
    ooops
    1940 pontiac grills
    so after buying an original set that wasn't thrashed
    went back to work
    rear roll pan and license box
    nd back to the grills
    roughed in
    new grills in
    time to get serious about fitting
    time to french the headlights
    thats it for today
    randy
  2. uglybaby
    uglybaby
    from tri-cities
    few more progress pics
  3. Jose perez
    Jose perez
    Thanks for the update and pictures. Very clean
  4. uglybaby
    uglybaby
    from tri-cities
    thanks
    it is coming together
    christmas and tax season always slow us down a little
    more updates soon
  5. 41 C28
    41 C28
    You are an artist.
  6. scrap metal 48
    scrap metal 48
    Looks really good.. Gonna be Cool...
  7. Hnstray
    Hnstray
    from Quincy, IL
    Love the chop. Nice work! I thought those were '40 Pontiac grilles when you first introduced them, but hadn't seen a '40 Desoto in a very long time, so....who knew?
    Maybe it's just the camera angle....or my old eyes, but the space between the upper, outer, grill corners and the headlights looks different one side to the other.......?? Is the driver side headlight closer? May have occurred during fairing in the buckets?
    Overall, great workmanship and will make a very cool Custom. Thanks for sharing all the details!
    Ray
  8. uglybaby
    uglybaby
    from tri-cities
    thanks everyone
    and good eyes there is a bit of a difference between the 2 sides
    the drivers headlight bucket is pushed in closer just a tad
    it is where it fit the best
    when i do the p*** side i will pull it all together
    make it symmetrical
    the camera angle is messing with the look just a bit also
  9. mgtstumpy
    mgtstumpy
    Coming together nicely. Looks like a good solid 'barn find' body to begin with. Makes it so much easier with less work fixing everything else up as well.
  10. 73RR
    73RR
    ...you tin guys are amazing....
  11. uglybaby
    uglybaby
    from tri-cities
    ok some more updates for ya'll
    getting the grill openings finished
    also the frenched headlights
    p*** side[​IMG]
    the front is starting to look good
    talked to the customer about rounding the hood corners
    he said "go for it "
    old square corner
    gone!
    new piece tacked in
    template
    filler pieces tacked in
    welded and ground down
    inside welded and ground
    thats all for this week
    i will have updates on the regular
    thanks
    randy
    chryslerfan55, Stogy and williebill like this.
  12. uglybaby
    uglybaby
    from tri-cities
    couple new pics
    started mocking up the front roll pan
    little more shaping but its close
    fixed a couple things on the front roll pan
    started looking at the wheel wells
    didnt like the radius of the front edge
    so i fixed it
    tape mock up
    cut and reshaped
    just tacked in place ,only moved it 3/4 of an inch but man what a difference
    more to come
    randy
  13. uglybaby
    uglybaby
    from tri-cities
    a little more work on the drivers side
    front is taking shape nicely
  14. 31Dodger
    31Dodger
    Looking smooooth!
  15. uglybaby
    uglybaby
    from tri-cities
    thanks
    hoping to finish the metal work on the front this week
  16. Peanut 1959
    Peanut 1959
    I'm really glad to see a completely new approach to the from of one of these. I'm not sure I'd have never thought of the Pontiac grille.
  17. Baldies
    Baldies
    What's happening?
  18. choptop40
    choptop40
  19. James D
    James D
    Very nice! Really got some flowing shape into the front end.
  20. uglybaby
    uglybaby
    from tri-cities
    ok back for an update
    jeremy getting the inner fender panels cut and installed
    [​IMG][​IMG]
    [​IMG]firewall welded up
    front marker lights frenched
    tailights frenched
    thanks for the look
    randy
  21. uglybaby
    uglybaby
    from tri-cities
    should have more pics today
  22. choptop40
    choptop40
    Wunderbar...magnificent
  23. Hollywood-East
    Hollywood-East
    Excellent! Just picked up a Special DeLuxe " find" myself.. Great build!
  24. Sorry, I just got here or I would have commented sooner. I had a '40 DeSoto 4-door sedan as my daily driver in the 1970's. It was a great cruiser! I'm surprised how similar the '40 DeSoto and Pontiac grilles are. I believe the horizontal bars are thicker in the Pontiac, but the grilles are the same shape. Anyway, it's a great look for the Plymouth. It took some imagination to visualize those grilles in there, and a lot of work to make it happen. The rolled pan is a nice touch as well. The front end looks 100% better than stock. Good work!
    chryslerfan55 and Peanut 1959 like this.
  25. uglybaby
    uglybaby
    from tri-cities
  26. j hansen
    j hansen
    Looks really good.
    Stogy likes this.
  27. choptop40
    choptop40
    Agree , looks great...
    Stogy likes this.
  28. Stogy
    Stogy
    @uglybaby good to see you still on your project and as the others have said you have things well in control...Looks just Dandy...
    The Photo****et curse has plagued your Thread but due to the fact you are still active on here you could go back and and Edit your posts with pic problems.
    By putting your pics back in your posts it helps those that could use your tech...;)
    I can't emphasize enough to stay away from storing pics on sites like this...
    Thanks for the update and Happy New Year...
    Peanut 1959 and chryslerfan55 like this.
  29. uglybaby
    uglybaby
    from tri-cities
    thanks everyone
    planning on fixing the broken links
