Projects "Pea Green" the '29 Tudor build
Discussion in 'The Hokey Ass Message Board' started by '52 F-3, Sep 14, 2014.
  1. '52 F-3
    '52 F-3
    from Central PA
    th350 mount getting closer....(still trying to keep changes to original frame minimal)
    juan motime, Stogy, Tim and 4 others like this.
  2. '52 F-3
    '52 F-3
    from Central PA
    Thanks. Paisley patterns are pretty polarizing, seems you either love it or hate it....
    scotty t likes this.
  3. '52 F-3
    '52 F-3
    from Central PA
    a couple hours of metal whittling got me the beginning of a upper front shock mount.
    Stogy likes this.
  4. '52 F-3
    '52 F-3
    from Central PA
    a little bit of heat and my F-1 inspired shock mounts are starting to take shape....
    bako48, Stogy, Tim_with_a_T and 2 others like this.
  5. Just Gary
    Just Gary
    Beautiful work. Your combination of technical skills & creativity is inspiring.:)
    '52 F-3 and scotty t like this.
  6. '52 F-3
    '52 F-3
    from Central PA
    initial test fit looks kind of tall? and still over thinking the lower shock mount.... so I started working on headlight stand (using original cut offs and bending)
    juan motime, Stogy and kidcampbell71 like this.
  7. '52 F-3
    '52 F-3
    from Central PA
    i have too many hours in these f'ing shock mounts and I still ain't happy..... but they're getting closer.
    1st time with headlights mounted (I do like how these are looking). need to get off lift to have a better look at everything.......
    I bent the steering arm a little bit to match drag link angle with the track bar, I don't believe i'll have any bump steer issues. fyi.....strap is holding suspension at right height, and the shock are Monroe 5850's with the cover thing removed.
    55Deso, juan motime, Stogy and 2 others like this.
  8. '52 F-3
    '52 F-3
    from Central PA
    change 3, part 1............ a "squirrel motor" followed me home tonight. (Thanks to my neighbor Tom for all the help.)
  9. '52 F-3
    '52 F-3
    from Central PA
    any guess what these are? bolt is 9/16", and grey hairy thing is Max the cat o_O
    bako48 and kidcampbell71 like this.
  10. 340HilbornDuster
    340HilbornDuster
    Hey, It's Friday, and I love your quizzes....
    -New Squirrel Motor Mount Adapter?
    -Removable Tow hitch mounts?
    '52 F-3 likes this.
  11. '52 F-3
    '52 F-3
    from Central PA
    no, think rear suspension....
    I figure a small block chevy is "mouse" and big chevy is "rat", so a 265 is a little mouse (squirrel)...
  12. 340HilbornDuster
    340HilbornDuster
    Aha! ... Adjustable shock mounts?
  13. kasselyn29
    kasselyn29
    Looks good as far as steering issues go if you have any you may want to look into something called scrub radius. Can't see in your pictures but looks like could be a problem.
    '52 F-3 likes this.
  14. '52 F-3
    '52 F-3
    from Central PA
    your 100% right, it is terrible....
    the 1/2" adapter plates and those 1936 wheels combine to push the tire way out. I've been thinking about a custom adaptor plate to move wheels inward but no lightning bolt yet.
    If its un-drivable I can also get a regular offset pair of wheels.
    340; closer :)
  15. '52 F-3
    '52 F-3
    from Central PA
    got the control arm mounts tacked in place, plan to "smooth in" when I weld in boxing plates...
    also getting exhaust closer.
    Stogy and Hotrodmyk like this.
  16. 340HilbornDuster
    340HilbornDuster
    Adjustable Spring Shackle Mounts?
  17. '52 F-3
    '52 F-3
    from Central PA
    all good guesses, but it's the mount for the rear upper control arm, the 3 possible positions will allow a little adjustment.
  18. 340HilbornDuster
    340HilbornDuster
    Nice! (I guess My second guess "Scale" was better..)
    + they were in plane site on your last picture!
    Dig the cool details / Good Ideas on your rod!
    And I like the Traditional "Use what you got recipe"
    Keep Cranking
    '52 F-3 likes this.
  19. '52 F-3
    '52 F-3
    from Central PA
    got rear shocks mounted, made little brackets in the same style as the control arms and rear track bar mounts.....
    few more things and the body is coming back off.
    juan motime, Stogy, ROCKER77 and 3 others like this.
  20. '52 F-3
    '52 F-3
    from Central PA
    starting with some 1" aluminum hex bar.... ?
  21. '52 F-3
    '52 F-3
    from Central PA
    alittle under the weather, but my OCD got me to the garage to work on my prototype for acouple minutes. still need to shorten base, drill and tap.
  22. YJ4000
    YJ4000
    License plate cap screws?
  23. '52 F-3
    '52 F-3
    from Central PA
    I like to call them "acorn nuts"..... plan to make a few smaller ones for other little things (maybe the license plate)
    55Deso, Stogy, Ron Funkhouser and 2 others like this.
  24. YJ4000
    YJ4000
    Yes. After I posted and reread it that's what I meant. They look great!! The more I see you make on the lathe I may have to get a little more serious about finding one.
    Ryan.
  25. '52 F-3
    '52 F-3
    from Central PA
  26. '52 F-3
    '52 F-3
    from Central PA
    getting some of the 265 ***embled.... slowly.... got busy with life again.
    Had 2 bent/rusty harmonic balancer/pulleys to choose from. Found another great use for a little shop lathe, used to straighten out bends/dings and ensured straight.
    Stogy likes this.
  27. hd1084
    hd1084
    Looking great !! I just wish I had a tenth of your talent and patience that you have creating this great peace of work hot rod. Congrats on doing a bang up job and I'm sure you are going to have a real winner when you get her done. Enjoy watching your build....
    '52 F-3 likes this.
  28. '52 F-3
    '52 F-3
    from Central PA
    thanks for compliment, I hope spring can bring some good progress.
    I looked up Irwin, PA... kinda far from Jalopy Showdown. are you planning on a coming by chance? would like to see your Tudor.
    few updates pics; harmonics balancer pitting and seal groove was alittle worse than pic shows. installed a repair sleeve and decided to clear with engine paint.... also got the "Pea Green" paint back out of the locker............
  29. Barn Find
    Barn Find
    from Missouri
    I love the color and all the attention to detail.
  30. Tim
    Tim
    from KCMO
    Any details on how that trans mount bolts to the stock cross member? Looks pretty trick!
