GASSER MUST HAVES and cant haves?
Discussion in 'The Hokey Ass Message Board' started by DirtyDave, Aug 4, 2013.
  1. Danny G
    Danny G
    Carroll Caudle and Ridgeway ran modified production,I never knew of them running the gas cl***es. One of them came up with the idea of pouring the Edelbrock tr1 half full of epoxy because it had too much area for a little motor
  2. Larry T
    Larry T
    Yea, they were MP cars, but folks were talking about the early tunnelrams and they both ran them. Caudle did run Gas with his Vega (I've seen pictures of MP in this car too), but I realize that's later than what's allowed here.
    The early Edelbrocks were pretty notorious for gas puddling in the plenum and back firing. I think the epoxy helped with that too.
    loudbang and II FUNNY like this.
  3. seb fontana
    seb fontana
    from ct
    Grumpy did a lot of internal work, a real lot
  4. Larry T
    Larry T
    I don't see a problem here. :D
  5. seb fontana
    seb fontana
    from ct
    Never seen that secret! I seen some pics built in the top half by extended runners of a carb plate, don't know which came first.
  6. langy
    langy
    Guys there's a bit of a heated discussion going on at the NSRA uk forum, some of the g***er guys have fitted steering racks on the rear of their front axles and the organisers of our g***er cl*** want to ban them.
    So we're there any cars back in the day with a rack ???
    I can't think of any
  7. hotroddon
    hotroddon
    Langy - no pictures handy but I can guaranty you that racks on straight axles were used a bit in the G***er Era. When mounted to the axle you have to have a sliding shaft to make up for the travel that the rack will be going through as the suspension cycles and it's important to keep that well lubed so it doesn't seize up.
  8. D.N.D.
    D.N.D.
    Not in my day, never saw one
  9. langy
    langy
    Cheers for that, yeah I've fitted many setups myself and they work very well.
    What is needed is some cast iron evidence that they were used back then.
  10. wrenchbender
    wrenchbender
    Well folks I think I managed to get the bumper figured out what do guys think
  11. mad mikey
    mad mikey
    The bumper is perfect!
  12. loudbang
    Looks like you built a "traditional" tube bumper to me. :rolleyes: But add some cl*** and grind off the lettering on the caps.
  13. wrenchbender
    wrenchbender
    Actually I don't like the caps they are not right the shape is not correct so I'm looking for some old ones but they are hard to find if I can't find some I will definitely do that
  14. Deuced Up!
    Deuced Up!
    You might be able to grind on those caps and give them that more rounded edge look. I was as the hardware store this weekend looking at their caps and they look the same as what you have on there.
  15. D.N.D.
    D.N.D.
    Use a short section of the pipe, thread on a cap and turn off the ridge and a larger corner radius on a lathe for more of a custom made look
    DND
    loudbang and Baron like this.
  16. manicmachanic
    manicmachanic
    from Berwyn, IL
    The lathe is good. No sense spending hours with a grinder.
  17. wrenchbender
    wrenchbender
    I might just try that my lathe is big enough to chuck the cap in but I'm not sure there is enough material to change the radius like I want for as much as these things cost you would think there would be a lot of material but there isn't
  18. DirtyDave
    DirtyDave
    "The use of a variable rack was invented by Arthur Ernest Bishop,[2] in the 1970s, so as to improve vehicle response and steering "feel," especially at high speeds. He also created a low cost press forging process to manufacture the racks, eliminating the need to machine the gear teeth."
  19. DirtyDave
    DirtyDave
    Did a little ol' school body work today.
    Dog_Patch and loudbang like this.
  20. wrenchbender
    wrenchbender
    Well here is the best magic I can do on these ****py new caps before cutting through had to weld it up twice and start over lol these caps are about as crooked as you get but I guess it's not too bad now to copy it on the other one
  21. manicmachanic
    manicmachanic
    from Berwyn, IL
    Did t\you try looking at fence post tops for shape?
  22. wrenchbender
    wrenchbender
    Yes I did and they were way off the more I look at it the more I am ok with it
  23. Deuced Up!
    Deuced Up!
  24. hotroddon
    hotroddon
    Rack & Pinion steering has been around since the late 1800's on three wheeled cycles. Pierce Arrow had the first Power Version in 1926. BMW had manual versions in the 1930's and quite a few British cars were using R&P in the early 1950's. In the US the first widespread use would have been the Pinto in 1970 (Although most every internet source says, incorrectly, that it was 1974). I can remember seeing a FIAT Altered at Irwindale in the late 60's with R&D as I was fascinated by it's operation. It was either 67 or 68
  25. Baron
    Baron
    Nice work. Look 100% better.
  26. manicmachanic
    manicmachanic
    from Berwyn, IL
    It was just a thought. They still look good. To old brain fade don't remember what they looked like then. Where they more rounded?
  27. manicmachanic
    manicmachanic
    from Berwyn, IL
    A pipe with screw on caps just looks right.
  28. wrenchbender
    wrenchbender
    Thanks guys I think it just right
    Baron likes this.
  29. seb fontana
    seb fontana
    from ct
    I figure here is the place to ask..Rear axle wheel studs, how much is supposed to be sticking out of the lug nut? thanks..
  30. Baron
    Baron
    As long as the stud has 2 or 3 threads showing beyond the lug nut, it will p*** NHRA tech.
